8310-- i need exparts help???? Hi all, i have a 8310 set which is in Contac Service.Then i try to repair it by flashing but after flash it stay in same position.I have used griffin,prodigy etc.But here i give a strange syntom which has been occured by Prodigy.That is - when i plug the set by the prodigy cable & try to power on then phone's display shows local mode.when i use "Factory Default Setting" then the phone automatically turns on from local mode condition & shows insert card clearly, But after that if i unplug the cable from the set & put up the battery & try to power on then it shows Contac service".So pls help me to repair the problem. proxy_gsm:( :( :( |
give me the imei # and nework your on press *#06# and give me serial number email me at [email protected] i'll give you unlock code |
@eugkong The guy does NOT want his mobile unlocked, he's asking about "Contact Service" which is quite a different thing !! @ proxy_gsm In my exsperinece this is a fault caused by UEM, try to reflow or even better reball/replace it ! Regards |
thx for your advice.i will be try as you then post reply. proxy_gsm |
i think we must check the battery connector and vbb line first befor go to the uem sir cuz the phone working o.k by 4.8 to 5 v o.k but its give contact service when you use 3.6 battery volt i faced a starnge case that i changed the battery with full new one the phone work o.k but its return to contact service am i right :D |
