cheap flasher and dead 6310i & 6510 I have two telephones 6310i and 6510, which after reduction of the versions are not included at increasing on more high versions devices also are not included and do not enter not in test not in local modes. As possible restore the given devices. |
for 6510, just re-heat flash, uem and upp then flash again. as for 6310i since uem and upp are underfilled with silicon, you cant re-heat it. |
Use Griffin to flash MCU & PPM again. Just a small bug of the Cheap DCT4 flasher, nothing big! |
I flash Prodygi - does not work, do not enter not in local not in test to mode. |
OK, if you don't have Griffin. Now try to use your Cheap DCT4 flasher again. Try to flash 6310i with V4.48, V5.01 ........... one-by-one. Same case apply to your 6510. Just try it ! |
