Convert 1208b RH-106 to 1208 RH-105 Success!!! Convert 1208b RH-106 to 1208 RH-105 Success!!! Getting MCU ID MCU ID: 0x2292 FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.01 Done! Phone Restarted... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 4.00 10-19-07 RH-106 (c) NMP HW version: 4201 PCI version: UEM version: 2341 UPP version: 8850 RFIC version: 0700 DSP version: P06w45.v41 LCD version: SDI:NAXv89 S6B33BD PPM version: V 4.00 10-19-07 RH-106 (c) NMP UB ADSP SW version: V 4.00\n10-19-07\nRH-106\n(c) NMP\nub_lta Production serial number: GAH902815 Product code: 0551854 Module code: 0203485 Basic production code: 0515530 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 01138600151**** IMEI spare to net: 0A 11 83 06 10 15 91 07 IMEI SV to net: 03 11 83 06 10 15 91 47 F1 Master Code: 5732401157 Phone type: RH-106, Software version: 4.00, Language Pack: UB User code: ÿ# Block 1: Lock 1: CLOSED -> Lock Data: 71610F Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RH-106.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0551854 No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Done! ------------------------- http://img81.imageshack.us/img81/415...hingsp6.th.jpg http://img81.imageshack.us/img81/415...lashingsp6.jpg Flash with RH-105 1208 flashfile [img=http://img261.imageshack.us/img261/9948/120bflashtf1.th.jpg] http://img261.imageshack.us/img261/9...0bflashtf1.jpg write 1208 PM Unlock! FILES SET FOR FLASHING: MCU Flash file: C:\Uni\Files\Nokia\DCT-4\1208.RH-105\4.00\rh105_04.000 PPM Flash file: C:\Uni\Files\Nokia\DCT-4\1208.RH-105\4.00\rh105_04.00aa CNT Flash file: C:\Uni\Files\Nokia\DCT-4\1208.RH-105\4.00\rh1050_nai4.00aa ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Backing up PM Field 208 as RPL... Setting local mode... Reading IMEI... Reading IMEI data... IMEI data corrupt... Failed to backup imei... MCU: C:\Uni\Files\Nokia\DCT-4\1208.RH-105\4.00\rh105_04.000 Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x28882000 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_st_i.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x4B38; Loader chk: df Loader is ready... P-key nokia module version 01.01 MSID: 84DCE0DBB76BE3D5CC04FCD0B6 MSID decoded: 3E4EBAE9009E8F2FA8000000 FAID: 91102539C8EACEE15FA9D36D Operation took 0 minutes 13 seconds... Erasing... Found 5 interval(s) to erase Erasing area: 01000000 - 0100FFFF... Erasing area: 01010000 - 013AFFFF... Erasing area: 013B0000 - 013EFFFF... Erasing area: 017C0000 - 017EFFFF... Erasing area: 01FC0000 - 01FEFFFF... Operation took 1 minutes 16 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 14 seconds... Restarting MCU... PPM: C:\Uni\Files\Nokia\DCT-4\1208.RH-105\4.00\rh105_04.00aa Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x28882000 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_st_i.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x4B38; Loader chk: df Loader is ready... P-key nokia module version 01.01 MSID: 84F3A63D908E1799E8C7763B37 MSID decoded: 3E4EBAE9009E8F2FA9000000 FAID: D4B18E97129EC78C8492E431 Operation took 0 minutes 13 seconds... Erasing PPM... Found 2 interval(s) to erase Erasing area: 01240000 - 0124FFFF... Erasing area: 01250000 - 0137FFFF... Operation took 0 minutes 24 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 7 seconds... Restarting MCU... CNT: C:\Uni\Files\Nokia\DCT-4\1208.RH-105\4.00\rh1050_nai4.00aa Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x28882000 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_st_i.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x4B38; Loader chk: df Loader is ready... P-key nokia module version 01.01 MSID: 84DCE0DBB76BE3D5CC04FCD0B6 MSID decoded: 3E4EBAE9009E8F2FA8000000 FAID: 91102539C8EACEE15FA9D36D Operation took 0 minutes 13 seconds... Erasing Content Pack... Found 1 interval(s) to erase Erasing area: 01380000 - 013AFFFF... Operation took 0 minutes 4 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 1 seconds... Restarting MCU... Operation took 0 minutes 0 seconds... Flashing Done! Operation took 2 minutes 55 seconds... After flash processing... Waiting for phone to boot... Reading... Phone type: RH-105, Software version: 4.00 IMEI: 01138600151**** Product Code: 0551854 Resetting PPC... Done! ----------------------- After flash processing... Waiting for phone to boot... Reading... Phone type: RH-105, Software version: 4.00 IMEI: 01138600151**** Product Code: 0551854 Resetting PPC... Done! Powering the phone... Unlocking... IMEI: 01138600151**** ASIC: b SW version: 4.00 Selected flash file: C:\Uni\Files\Nokia\DCT-4\1208.RH-105\4.00\rh105_04.000 Decrypting flash... Encrypting.... CHK Patch found - Unlock Patch found and are not in same block Patch status: 02 MCU ID: 0x2292 Algo is ready... P-key nokia module version 01.01 Erasing area: 011E0000 - 011FFFFF... Erasing area: 011E0000 - 011FFFFF... Unlocking... Checking locks... Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Done! DCT4 unlock counter: 131 [img=http://img385.imageshack.us/img385/3162/120bunlockfz0.th.jpg] http://img385.imageshack.us/img385/3...bunlockfz0.jpg Remove two filters and replace with capacitors or put two jumpers... Done.. |
sir i have flashed it on mt box and unlock with ub box but no signal agter uploding pm and doing hardware please send me good pm for signal which u have [email protected] |
yes and flashed it with rh-105 ver 4.11 |
Remove two filters and replace with capacitors or put two jumpers plz send pic.............. |
nokia 1208 rh106 can I flash rh106 version with a rh105 version ? then unlock it where do I get the flash file ? |
Pls post detail how to convert Nokia 1208B to 1208 normal |
please post picture of these two filters for rh105/6 to convert to gsm pls |
please post picture b greatttttttttttttttttttttttttt man give the picture |
Convert 1208b RH-106 to 1208 RH-105 Success MCU Nokia Version: 1.126, and up to date. SMCU Nokia Version: 1.44, and up to date. Switching from Normal to Local mode... Local mode set. Reading Info... MCU Version: V 5.32 Date: 05-18-08 Type: RH-106 (Unknown) Additional_1: (c) NMP PPM Version: V 5.32 Date: 05-18-08 Type: RH-106 (Unknown) Additional_1: (c) NMP Pack: UB Product code: 0563363 Production serial: RAS877569 Hardware version: 0337 Original IMEI: 011540-00-******** IMEI: 011540-00-******** Asic type: 11 Profile bits: 8000000000010002 Lockinfo: 3102000000000000 Lock version: 1 SIMLock service: SIMLOCK SERVER [010001070202] Writing SP info Failed, patching software... -------------------------------------------------------------------------------- TDCT4UnlockThread 2.7.7.2090 finished at: 2009/05/20 11:25:01 Terminated with error: Patch file [RH-106_5.32.pat] for this version not found [00011A82].00011A86 MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Device opened at USB->Universal Box [UBQYPVQ8] then flashed with rh 105 /////////////////////////////////////////////////////////////// DCT4 [DCT4 ALGORITHM] UCP File: rh1050_nai4.11ae 118 kB MSB: [01] Speed: [100k, 6500k, 6500k, 51k] Baud. Supported Hardwares: [2292] DCT4 [DCT4 ALGORITHM] PPM File: rh105_04.11ae 1 119 kB Languages: English, French, German, Italian MSB: [01] Speed: [100k, 6500k, 6500k, 51k] Baud. Supported Hardwares: [2292] DCT4 [DCT4 ALGORITHM] MCU File: rh105_04.110 2 317 kB MSB: [01] Speed: [100k, 6500k, 6500k, 51k] Baud. Supported Hardwares: [2292] DCT4 [DCT4 ALGORITHM] UCP File: rh1050_nai5.53ae 118 kB MSB: [01] Speed: [100k, 6500k, 6500k, 51k] Baud. Supported Hardwares: [2292] DCT4 [DCT4 ALGORITHM] PPM File: rh105_05.53ae 1 124 kB Languages: English, French, German, Italian MSB: [01] Speed: [100k, 6500k, 6500k, 51k] Baud. Supported Hardwares: [2292] DCT4 [DCT4 ALGORITHM] MCU File: rh105_05.530 2 326 kB MSB: [01] Speed: [100k, 6500k, 6500k, 51k] Baud. Supported Hardwares: [2292] TDCT4FlashPhoneThread 2.7.7.2090 started at: 2009/05/20 11:33:02 -------------------------------------------------------------------------------- MCU Nokia Version: 1.126, and up to date. SMCU Nokia Version: 1.44, and up to date. Input power: 12,07V OK. Hardware ID: 2292 Boot Loader: u3_2nd.fia 2 kB Version: 4.77.0 Supported Hardwares: [3040, 2292, 2293, 3162, 3166, 3168] Max Flash Devices: 2 Flash ID 1: 00208828 - 0000 Rev: 0321 Manufacturer: ST MSB: 01 SectorSize: 0x010000 Flash ID 2: 00000001 - 0000 Rev: 0000 Manufacturer: Unused MSB: 02 SectorSize: 0x000001 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flash Loader: u3_st_i.fia 19 kB Version: 4.77.0 Supported Hardwares: [3040, 2292, 2293, 3162, 3166, 3168] ASIC Type: 11 MSID: 84-23FCAD90FDC4D456CEEE6C92 CobbaID: 00182DEC; 2984DA60 FAID: A78FD331247B4A2F15CC8DD3 Erase time: 1:05,6 sec. Flashing MCU file: rh105_05.530 Flash time: 21,1 sec. After MCU Flash Delay: 5000 msec. Input power: 12,01V OK. Hardware ID: 2292 Boot Loader: u3_2nd.fia 2 kB Version: 4.77.0 Supported Hardwares: [3040, 2292, 2293, 3162, 3166, 3168] Max Flash Devices: 2 Flash ID 1: 00208828 - 0000 Rev: 0321 Manufacturer: ST MSB: 01 SectorSize: 0x010000 Flash ID 2: 00000001 - 0000 Rev: 0000 Manufacturer: Unused MSB: 02 SectorSize: 0x000001 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flash Loader: u3_st_i.fia 19 kB Version: 4.77.0 Supported Hardwares: [3040, 2292, 2293, 3162, 3166, 3168] MSID: 84-F7B556432185969A963E0751 CobbaID: 00182DEC; 2984DA60 FAID: F6121C04C198AA2EC0A0E62F Erase time: 3,1 sec. Flashing UCP file: rh1050_nai5.53ae Flash time: 1,4 sec. Before Extract Delay: 5000 msec. Storing UCP. Timeout: 90 sec. Store time: 0,0 sec. Input power: 12,09V OK. Hardware ID: 2292 Boot Loader: u3_2nd.fia 2 kB Version: 4.77.0 Supported Hardwares: [3040, 2292, 2293, 3162, 3166, 3168] Max Flash Devices: 2 Flash ID 1: 00208828 - 0000 Rev: 0321 Manufacturer: ST MSB: 01 SectorSize: 0x010000 Flash ID 2: 00000001 - 0000 Rev: 0000 Manufacturer: Unused MSB: 02 SectorSize: 0x000001 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flash Loader: u3_st_i.fia 19 kB Version: 4.77.0 Supported Hardwares: [3040, 2292, 2293, 3162, 3166, 3168] MSID: 84-F7B556432185969A963E0751 CobbaID: 00182DEC; 2984DA60 FAID: F6121C04C198AA2EC0A0E62F Erase time: 20,10 sec. Flashing PPM file: rh105_05.53ae Flash time: 10,3 sec. Total time: 2:39,6 sec. After Flash Delay: 15000 msec. Set Defaults Timeout: 250 sec. Setting defaults (it can take a minunte, or more)... Set defaults time: 0,5 sec. Reading Info... MCU Version: V 5.53 Date: 07-08-08 Type: RH-105 (1208) Additional_1: (c) NMP [Nokia 1208 CABLE 1100] PPM Version: V 5.53 Date: 07-08-08 Type: RH-105 (1208) Additional_1: (c) NMP Pack: AE Product code: 0563363 Production serial: RAS877569 Hardware version: 0337 Original IMEI: 011540-00-******** IMEI: 011540-00-******** Asic type: 11 Profile bits: 8000000000010002 Lockinfo: 3102000000000000 Lock version: 1 SIMLock service: SIMLOCK SERVER [010001070202] Set Defaults Timeout: 250 sec. Setting defaults (it can take a minunte, or more)... Set defaults time: 0,6 sec. -------------------------------------------------------------------------------- TDCT4FlashPhoneThread 2.7.7.2090 finished at: 2009/05/20 11:36:00 Done. TDCT4UnlockThread 2.7.7.2090 started at: 2009/05/20 11:36:06 -------------------------------------------------------------------------------- MCU Nokia Version: 1.126, and up to date. SMCU Nokia Version: 1.44, and up to date. Reading Info... MCU Version: V 5.53 Date: 07-08-08 Type: RH-105 (1208) Additional_1: (c) NMP [Nokia 1208 CABLE 1100] PPM Version: V 5.53 Date: 07-08-08 Type: RH-105 (1208) Additional_1: (c) NMP Pack: AE Product code: 0563363 Production serial: RAS877569 Hardware version: 0337 Original IMEI: 011540-00-******** IMEI: 011540-00-******** Asic type: 11 Profile bits: 8000000000010002 Lockinfo: 3102000000000000 Lock version: 1 SIMLock service: SIMLOCK SERVER [010001070202] Writing SP info Failed, patching software... Connecting to server: US1 Asking service availability... Connecting to server: US1 Credits: 50 Credits left: 50 Input power: 12,07V OK. Hardware ID: 2292 Boot Loader: u3_2nd.fia 2 kB Version: 4.77.0 Supported Hardwares: [3040, 2292, 2293, 3162, 3166, 3168] Max Flash Devices: 2 Flash ID 1: 00208828 - 0000 Rev: 0321 Manufacturer: ST MSB: 01 SectorSize: 0x010000 Flash ID 2: 00000001 - 0000 Rev: 0000 Manufacturer: Unused MSB: 02 SectorSize: 0x000001 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flash Loader: u3_st_i.fia 19 kB Version: 4.77.0 Supported Hardwares: [3040, 2292, 2293, 3162, 3166, 3168] ASIC Type: 11 MSID: 84-23FCAD90FDC4D456CEEE6C92 CobbaID: 00182DEC; 2984DA60 FAID: A78FD331247B4A2F15CC8DD3 Erase time: 4,4 sec. Flashing file: RH-105_5.53.imp Flash time: 2,8 sec. After MCU Flash Delay: 5000 msec. Total time: 19,7 sec. Reading Info... MCU Version: V 5.53 Date: 07-08-08 Type: RH-105 (1208) Additional_1: (c) NMP [Nokia 1208 CABLE 1100] PPM Version: V 5.53 Date: 07-08-08 Type: RH-105 (1208) Additional_1: (c) NMP Pack: AE Product code: 0563363 Production serial: RAS877569 Hardware version: 0337 Original IMEI: 011540-00-******** IMEI: 011540-00-******** Asic type: 11 Profile bits: 0000000000010000 Lockinfo: 0000000000000000 Lock version: 1 SIMLock service: SIMLOCK SERVER [010001070202] Calculating SP area Writing SP info Write lock succeeded Please detach the phone! Please attach the next phone! :p |
1 Attachment(s) i refresh , this picture show filters ;) |
1208b filters good job than ,but i need 1208b filters remove pictures,thanks |
please, someone can upload the a good PM for 1208? |
i need 1208b filters remove pictures urgent |
thankx for share good news................ |
