Nokia Digital Core Technology 4 ( DCT-4 ) DCT-4 Phones: 1100 , 1100 , 1101 , 1108 , 1110 , 1110 , 1110i , 1112 , 1112 , 1112i , 12i GSM Modul, 1600 , 1600 , 2112 , 2125i , 2126i , 2128i , 2255 , 2300 , 2300 , 2355 , 2600 , 2650 , 2651 , 2652 , 2760 Americas, 2760 Europe/Asia, 30 Terminal, 3100 , 3105 , 3108 , 3120 , 3120 , 3125 , 3128 , 3129 , 3152 , 3155 , 3155i , 3200 , 3205 , 3205i , 3220 , 3220 , 3300 , 3300 , 3320 , 3321 , 3360 , 3361 , 3510 , 3510i , 3520 , 3530 , 3560 , 3570 , 3585 , 3586 , 3586i , 3587 , 3587i , 3588i , 3589i , 3590 , 3595 , 3595i , 5070 , 5070 , 5100 , 5140 , 5140 , 5140i , 6010 , 6012 , 6015 , 6015i , 6016i , 6019i , 6020 , 6020 , 6021 , 6030 , 6030 , 6050 , 6060 , 6060 , 6061 , 6070 , 6070 , 6080 , 6080 , 610 Car Kit, 6100 , 6101 , 6101 , 6101 , 6102 , 6102 , 6102 , 6102 , 6103 , 6103 , 6108 , 6111 , 6112 , 6152 , 6155 , 6155i , 616 Car Kit, 6170 (TIKU) , 6170 (TIKU) , 6200 , 6220 , 6225 , 6225i , 6230 (TIKU) , 6230 (TIKU) , 6230i (TIKU) , 6235 (TIKU) , 6235i (TIKU) , 6236i , 6255 (TIKU) , 6255i (TIKU) , 6256 , 6256i , 6310 , 6310i , 6340 , 6340i , 6360 , 6370 , 6385 , 6500 , 6510 , 6560 , 6585 , 6590 , 6590i , 6610 , 6610i , 6650 , 6651 , 6800 , 6800 , 6810 , 6820 , 6820 , 6820i , 6822 , 6822 , 7200 , 7210 , 7250 , 7250i , 7260 , 7270 (TIKU), 7270 (TIKU) , 7280 (TIKU) , 7280 (TIKU) , 7360 , 7380 , 7600 (TIKU) , 7620 , 810 Car Kit, 8310 , 8390 , 8587 , 8800 (TIKU) , 8800 Sirocco Edition (TIKU) , 8801 (TIKU) , 8910 , 8910i , D211 , Nokia Remote Camera DCT-4+ (Plus) : 1200 , 1208 , 1208b , 1209 , 1650 , 1650b , 1680c-2b Classic, 2310 , 2600c , 2610 , 2610b , 2626 , 2630 Americas, 2630 Europe/Asia, 2670h Fold, 5000 , 5000 , 7070 |
10-05-2006, 15:34 | #1 (permalink) |
No Life Poster Join Date: Jun 2006
Member: 300043 Status: Offline Thanks Meter: 360 | Format ur fone without cables/pc/box In case of serious problems with your Nokia 7700/7710 (if e.g. your phone doesn't start or it is very unstable) use the following method to reformat the device. Please be aware that this function brings your phone back to a factory state, i.e. it removes all applications, files and data.
see the picture... http://www.yourfreespace.net/users/obaid/New%20Bitmap%20Image.JPG |
10-05-2006, 15:42 | #2 (permalink) |
Member: 300043 Status: Offline Thanks Meter: 360 | 6600 How to Format your Nokia 6600 If any of the problems listed below is happening to your phone: A. Blank screen phone unable to boot-up. B. Phone is only able to boot-up to "Nokia" screen (may flash "Nokia" 4 times also). C. Install a program but unable to uninstall it. D. Unable to delete certain files on C drive. --- WARNING: This will ERASE EVERYTHING on your phone --- If you have any files that are important to you, make backups. 1. Make sure you phone is fully charged. 2. Backup your contacts list and personal files to MMC memory card (if possible). 3. Switch-off your 6600 phone. 4. Press and hold these three keys together -Green dial key, -Star key (*) -Three key (3) then press the power on/off to switch on the 6600 phone. DO NOT let go the three keys until you see the "formatting" screen displayed 5. After a few minutes, the format will be complete. Your 6600 will now be at its original factory settings. Disclaimer: I will not be held responsible for anything that happens to your phone as a result of following my guide. Use this guide at your own discretion and risk. Last edited by LBOZ_GSM; 10-05-2006 at 15:55. |
10-05-2006, 15:48 | #3 (permalink) |
Member: 300043 Status: Offline Thanks Meter: 360 | How to Format Nokia Symbian Series 60 Phones Nokia Symbian Series 60-based phones have a copy of the OS present in the built-in ROM. When you format the phone, the OS gets restored from the ROM to the phone memory overwriting the existing setup. Steps
Tips
10-05-2006, 16:08 | #4 (permalink) |
Member: 300043 Status: Offline Thanks Meter: 360 | how to format a nokia 9300 (not tested) 1. Turn off phone and take out battery 2. Insert battery, and while it boots up press and hold Ctrl + Shift + F 3. After a few seconds you will be asked if you want to format or cancel I recommend having the device open when inserting the battery so you can press the combination quickly. Remember that this erases everything in the machine and it becomes like when you bought it. (I guess you know it, but mentioned it just in case). |
Unlock M110, E310, E250 WITHOUT CABLES OR BOX | Emmanuel 01 | UST Pro II | 10 | 06-24-2009 09:26 |
No need formate ur pc more then 10 years | sneha | Off Topic Zone | 0 | 04-16-2009 13:29 |
formate ur sigmatel without any software | neeraj1st | Chinese Models & Cloned Phones | 4 | 04-04-2009 19:28 |
Unlock ur GX10 without cable just codes | moustafatch | Sharp | 10 | 05-14-2003 16:08 |
