memory card corrupted or missing (nokia 3300) every time i connect my cable to my phone it says memory card missing or corrupted. does anyone know if this is fixable... if at all??:confused: |
solution try to format the memory card if u can it always used 2 happen 2 me!or turn off the fone that worked wit me :) |
My customer brought 3300 to me to flash russian language. Phone was 4.05. I upgarded version to 4.25 and immediately after version upgrade every time I switch phone on it showed me, that Memory card is missing or invalid. I downgraded phone back, and all became allright. Hope this will help you. |
or format the moemory card.. bR |
no just flash ADSP and really it will work ok it isn't currupter just need flash DSP only |
is there is any way to format memory card through Computer if memory card is locked then what to do |
memory corrupt 3300 i have also encountered same problem i tried to flash my phone trice but still nothing. is their any exact flashing solution for this or any idea on wat exact version to choose. |
same problem here, i already flash ADSP |
Check memory Card On Your Computer Is it Working Good ? If yes Take Copy From it & Format it on ur Phone.! |
card is oke. Works good in Nokia 6230i and already formatted 3 times |
3300 this is the way first switch on your fone with the card see if your able to access the card through dku-2 from pc see if you can view the card or see if its possible to access the card from extras and delete a file see if you can open the file then its better if you flash ADSP or check the ADSP in your fone and flash that version Flash into your fone should solve all the problems coz UFS aint have no ADSP flashing.......... regards |
hey mak Quote:
i flash the phone with JAF including ADSP and still the problem |
lol remember not to flash phone with memory card in it, i done that with the 3300 aswell and screwed up the card, not to intrude in thread but where would i get a cheap 3300 keypad membrane I used UFS on it aswell and thats what happened |
So it isn't possible to fix the phone anymore :P? |
