Nokia 1280 Network OK But Call Failed Nokia 1280 Network OK But Call ( incoming and Outgoing ) Failed http://img641.imageshack.us/img641/1...butcallfai.png I Try To Write PM File , After Same Problem .... How to Solve This Problem .... |
Here is The Self Test Log : Phone Type: RM-647 SW version: V 06.20 01-12-10 RM-647 (c) Nokia ID Test name Startup Result 85 HOOK_KEY Y passed 86 ACCESSORY Y passed 83 RTC_32KHZ Y passed 84 GPIO_LIGHT Y passed 90 FLASHCHK Y passed 91 SECURITY Y passed 87 SIM_IF Y passed 88 SIM_INSERTED Y !no signal 33 SIM_LOCK Y passed 10 PPM_VALIDITY Y passed 42 RADIO Y passed 39 WARRANTY Y passed 81 PA Y passed 82 ADC1 Y passed 43 LCD Y passed 80 KEY Y passed |
main ic is reballing or heat problem is sove 100% |
Still Power Amplyfier IC damaged.. change please |
Did you check the settings for Called ID Hide? |
Check pf supply or other network related parts the voltage may be disconnect when you calling |
same problem 1280 full signal but call failed |
you change image http://http://www.4shared.com/photo/...H/netxs_2.html |
just rehot mian ic problem will be 100%%%%%%%%%%% solve |
here is 100% tested solution for nokia 1280 network ok call failed by dilip soni http://onlinejaisalmer.com/nokia-128...iled-solution/ |
Nokia 1280 Network OK But Call ( incoming and Outgoing ) Failed all suply is ok and i also change p.a filter main i.c but no result |
i have same problem in 1280 incoming call is OK but outgoing call failed plz give solution any one thanks................... |
replace sim ic and post result |
