Nokia 6230i Full PM Needed I want FULL pm of 6230i and its timer should be nil if possible |
1 Attachment(s) Rename TXT to PM :) it FUll PM |
PLS DON'T USE THIS ONE , THIS ONE NO CORRECT! br., Denis |
Anybody Have tested pm ? |
About 6230I PM , if u write a full PM, then the IMEI will be changed , and maybe the phone will can not power on . if u only wanted change the lifetime to ZERO, then only flash the record [88] the lens is 36 BR., Denis |
how can flash the record [88] I cannt understand what you explain. Do You have solution to zero lifetime for new models ???? |
Field: 88, Record: 0 [88] 0= 72 0 Edit above , and rename to x.pm . flash via tools BR., Denis |
GREAT MAN Thanks A Lot. |
BR., Denis |
thx bro... its really needed thanks a lot............ |
Is it also work with bb5 too ? |
@.::Gsmdenis::. very thanx dear i edit it on pm file and flash it and it's work plzz tell me that is this rule apply on all nokia model, without any full flashing |
