Phon Restricted Hi friend nk 6020 phone restricted helpme pls good solution thanx advance |
clean battry connector heat the board with low heat and set full factory default |
Thx for replay [QUOTE=amoltelecom]clean battry connector heat the board with low heat and set full factory default * all ready i tryed by ui seting |
just chek ur phone imei number without inserting simcard. . . . it may be ?????????????????? |
unlock your phone bro! or your imei 1s???????????? |
Heating is not the solution.Check its imei first,if ok then go for ui settings by using proper cable.If imei wrong write rpl after changing uem |
Nice Hi nice replay raj_bhatia66 nice thanx i solved |
change uem ok""""""""""""""""""""""""""""""""""" |
just unlock phone will be okkkkkkkkkkkk |
