Nokia Digital Core Technology 4 ( DCT-4 ) DCT-4 Phones: 1100 , 1100 , 1101 , 1108 , 1110 , 1110 , 1110i , 1112 , 1112 , 1112i , 12i GSM Modul, 1600 , 1600 , 2112 , 2125i , 2126i , 2128i , 2255 , 2300 , 2300 , 2355 , 2600 , 2650 , 2651 , 2652 , 2760 Americas, 2760 Europe/Asia, 30 Terminal, 3100 , 3105 , 3108 , 3120 , 3120 , 3125 , 3128 , 3129 , 3152 , 3155 , 3155i , 3200 , 3205 , 3205i , 3220 , 3220 , 3300 , 3300 , 3320 , 3321 , 3360 , 3361 , 3510 , 3510i , 3520 , 3530 , 3560 , 3570 , 3585 , 3586 , 3586i , 3587 , 3587i , 3588i , 3589i , 3590 , 3595 , 3595i , 5070 , 5070 , 5100 , 5140 , 5140 , 5140i , 6010 , 6012 , 6015 , 6015i , 6016i , 6019i , 6020 , 6020 , 6021 , 6030 , 6030 , 6050 , 6060 , 6060 , 6061 , 6070 , 6070 , 6080 , 6080 , 610 Car Kit, 6100 , 6101 , 6101 , 6101 , 6102 , 6102 , 6102 , 6102 , 6103 , 6103 , 6108 , 6111 , 6112 , 6152 , 6155 , 6155i , 616 Car Kit, 6170 (TIKU) , 6170 (TIKU) , 6200 , 6220 , 6225 , 6225i , 6230 (TIKU) , 6230 (TIKU) , 6230i (TIKU) , 6235 (TIKU) , 6235i (TIKU) , 6236i , 6255 (TIKU) , 6255i (TIKU) , 6256 , 6256i , 6310 , 6310i , 6340 , 6340i , 6360 , 6370 , 6385 , 6500 , 6510 , 6560 , 6585 , 6590 , 6590i , 6610 , 6610i , 6650 , 6651 , 6800 , 6800 , 6810 , 6820 , 6820 , 6820i , 6822 , 6822 , 7200 , 7210 , 7250 , 7250i , 7260 , 7270 (TIKU), 7270 (TIKU) , 7280 (TIKU) , 7280 (TIKU) , 7360 , 7380 , 7600 (TIKU) , 7620 , 810 Car Kit, 8310 , 8390 , 8587 , 8800 (TIKU) , 8800 Sirocco Edition (TIKU) , 8801 (TIKU) , 8910 , 8910i , D211 , Nokia Remote Camera DCT-4+ (Plus) : 1200 , 1208 , 1208b , 1209 , 1650 , 1650b , 1680c-2b Classic, 2310 , 2600c , 2610 , 2610b , 2626 , 2630 Americas, 2630 Europe/Asia, 2670h Fold, 5000 , 5000 , 7070 |
12-24-2002, 13:17 | #1 (permalink) |
Freak Poster Join Date: Sep 2000 Location: verona, vr, italy
Member: 2158 Status: Offline Thanks Meter: 5 | 6310i v5.10 Flashing problem Then i re flashed with V4.80 and when i turn on the phone, the phone ask to me one restriction code (showing: some restriction are on please put in restriction code). I turn off the phone and then when i turn on the phone CONTACT SERVICE! Grrrrrr!!! I try to reflash it with v5.10 but nothing! This **** CONTACT SERVICE dont go! I tried F-bus by maestro but nothing .... Whats Hell I can Do? I appreciate all suggestions! Ciao Alex |
12-24-2002, 13:48 | #2 (permalink) |
Insane Poster Join Date: Feb 2001 Location: Apeldoorn, The Netherlands
Member: 3428 Status: Offline Thanks Meter: 0 | I had the same. First downgrade to v4.80. Then you need to get the phone in test mode. Then you have to unlock the phone with JIC unlocker. The phone is now simlockfree and no CS anymore. Now you can upgrade the phone to v5.10 (and later to v5.22). The problem I had was that I couldn't get the phone in test mode. I hadn't a F-bus cable. With Neelix II it wasn't any problem. Only remove simlock and the phone works. |
12-24-2002, 15:06 | #3 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Tutuban Age: 68
Member: 10635 Status: Offline Thanks Meter: 10 | @xxxpaga, Even if you can revive your phone with cheap DCT4 Flasher, your BT will not work... BUt use N2 to reinstall BT, it will be fine.. BR, Epic |
12-24-2002, 16:32 | #4 (permalink) |
Freak Poster Join Date: Jan 2002 Location: Indonesia Age: 51
Member: 8794 Status: Offline Thanks Meter: 10 | Before I did the same as yours.Just reflash again with the same mcu 510,(don't take out the cable,leave it in local mode) and then Reset lock. Good luck |
12-26-2002, 17:43 | #8 (permalink) |
No Life Poster Join Date: Nov 2001
Member: 7352 Status: Offline Thanks Meter: 13 | i brought a Nokia DCT 4 MCU/PPM flasher so that i could unlock 8310 v5.57 and other new version that cant be unlocked e.g 6310, 6510, 3510, 7210 etc i tried to unlock a 8310 v5.57 so i tried to down grade it to v5.55 but i get a message shown below and i cant down grade it. no loader for this flash,or model [0x0001257E] - 0x0120 |
12-26-2002, 18:24 | #9 (permalink) |
Member: 2158 Status: Offline Thanks Meter: 5 | I try to re-flash with v4.80 and v5.10 and when the phone goes in local mode i leave and try to reset lock but i receive SP command error and when i try to reset locks when phone show contact service the software read imei, phone version and then write :communication error...... what's hell Please help me |
12-26-2002, 18:27 | #10 (permalink) |
Member: 2158 Status: Offline Thanks Meter: 5 | And i try jic unlocker but software dont see the phone, i try to put it in test mode with wire and phone show test mode but jic dont connect phone! why? |
12-26-2002, 18:59 | #11 (permalink) |
Member: 2158 Status: Offline Thanks Meter: 5 | hi, problem solved!! I downgraded phone to 4.80 and then i put in test mode with one wire and use unlock/fix button of dct4flasher and phone work ok but bluethoot don't work! then i downgrade phone to v4.08 and push unlock/fix and now bluethoot work ok!!! |
12-28-2002, 04:01 | #14 (permalink) |
Member: 2158 Status: Offline Thanks Meter: 5 | Hi, where can i download windctv2.0 and pro flasher? can you send to me? my e-mail is [email protected] |
Please unlock code 6310i v5.10 | MobilMan | Phone Unlocking Codes & Maps | 2 | 02-19-2003 18:22 |
Unlock 6310i v5.10 with JIC mbus unlocker | Falck | Nokia Digital Core Technology 4 ( DCT-4 ) | 5 | 12-26-2002 10:02 |
6310i v5.10 unlock | GvS | Nokia Digital Core Technology 4 ( DCT-4 ) | 4 | 11-30-2002 18:24 |
Nokia 6310i 5.10 flash problem!!! | libik2009 | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 11-13-2002 01:01 |
Support for 6310i v5.10 / 7210-6610 JAVA etc... | din | Nokia Digital Core Technology 4 ( DCT-4 ) | 4 | 11-11-2002 16:24 |
