sir solve ufs software problem...... nokia 1661 flashing but this problem........ 1st Boot: Ok, DCT4, UPP: 2293 [Rh-122] [2.0.9.0] 2nd Boot: u3_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x017FFFFF,00EC2254,Sam K8S6415ET Algorithm: u3_amd.fia, Ver: 4.79.0 Algorithm Ok, MSID: 842CA1478C82EAC27B0AC8975A Decoded MSID: 3E4EBAE9-00EF9F2B-AA000000 Encoded FAID: 58A8DAAB-B1124D13-54761C45 IMAGE: rh122_003.100 Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00 Area2: 0x01010000-0x0179FFFF Erased, Time: 00:53 Area3: 0x017A0000-0x017EFFFF Erased, Time: 00:02 Area4: 0x01F00000-0x01FDFFFF Out of Chip Bounds MCU Flashing Completed, Time: 00:16 IMAGE: rh1220_nai03.10mg Area1: 0x01760000-0x0179FFFF Erased, Time: 00:01 CNT Flashing Completed, Time: 00:01 Extracting Contents Package ... Init Local Mode Failed Contents Package Extracting Failed: Process Failed, Repowering Mobile |
flash with high ver........ |
Dar bro. use easy cable. and flash it with mcuw v.5.91 |
thanks brother......... |
ek problem aur hai sir nokia 1209 flash device not supported........pls help |
rehot flash ic and check if not working reball the flash ic |
Extracting Contents Package ... Init Local Mode Failed Contents Package Extracting Failed: Process Failed, Repowering Mobile reheat flash ic and upp and uem problem will be slove |
Use Easy cable ur problm 100% will be solve |
full erase dari 0x01000000 sampe 0x01FFFFFF Pake JAF / UFS Erase Full Flash Write PM Ui setting |
sir pahle flash to pura le tabhi to ui setting kare........ 1st Boot: Ok, DCT4, UPP: 2293 [Rh-122] [2.0.9.0] 2nd Boot: u3_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x017FFFFF,00EC2254,Sam K8S6415ET Algorithm: u3_amd.fia, Ver: 4.79.0 Algorithm Ok, MSID: 842CA1478C82EAC27B0AC8975A Decoded MSID: 3E4EBAE9-00EF9F2B-AA000000 Encoded FAID: 58A8DAAB-B1124D13-54761C45 IMAGE: rh122_003.100 Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00 Area2: 0x01010000-0x0179FFFF Erased, Time: 00:53 Area3: 0x017A0000-0x017EFFFF Erased, Time: 00:02 Area4: 0x01F00000-0x01FDFFFF Out of Chip Bounds MCU Flashing Completed, Time: 00:16 IMAGE: rh1220_nai03.10mg Area1: 0x01760000-0x0179FFFF Erased, Time: 00:01 CNT Flashing Completed, Time: 00:01 Extracting Contents Package ... Init Local Mode Failed Contents Package Extracting Failed: Process Failed, Repowering Mobile |
sir pahle flash to pura le tabhi to ui setting kare........ sir hum decument picture kaise ishmein dal sakte hai...... |
