Nokia Digital Core Technology 4 ( DCT-4 ) DCT-4 Phones: 1100 , 1100 , 1101 , 1108 , 1110 , 1110 , 1110i , 1112 , 1112 , 1112i , 12i GSM Modul, 1600 , 1600 , 2112 , 2125i , 2126i , 2128i , 2255 , 2300 , 2300 , 2355 , 2600 , 2650 , 2651 , 2652 , 2760 Americas, 2760 Europe/Asia, 30 Terminal, 3100 , 3105 , 3108 , 3120 , 3120 , 3125 , 3128 , 3129 , 3152 , 3155 , 3155i , 3200 , 3205 , 3205i , 3220 , 3220 , 3300 , 3300 , 3320 , 3321 , 3360 , 3361 , 3510 , 3510i , 3520 , 3530 , 3560 , 3570 , 3585 , 3586 , 3586i , 3587 , 3587i , 3588i , 3589i , 3590 , 3595 , 3595i , 5070 , 5070 , 5100 , 5140 , 5140 , 5140i , 6010 , 6012 , 6015 , 6015i , 6016i , 6019i , 6020 , 6020 , 6021 , 6030 , 6030 , 6050 , 6060 , 6060 , 6061 , 6070 , 6070 , 6080 , 6080 , 610 Car Kit, 6100 , 6101 , 6101 , 6101 , 6102 , 6102 , 6102 , 6102 , 6103 , 6103 , 6108 , 6111 , 6112 , 6152 , 6155 , 6155i , 616 Car Kit, 6170 (TIKU) , 6170 (TIKU) , 6200 , 6220 , 6225 , 6225i , 6230 (TIKU) , 6230 (TIKU) , 6230i (TIKU) , 6235 (TIKU) , 6235i (TIKU) , 6236i , 6255 (TIKU) , 6255i (TIKU) , 6256 , 6256i , 6310 , 6310i , 6340 , 6340i , 6360 , 6370 , 6385 , 6500 , 6510 , 6560 , 6585 , 6590 , 6590i , 6610 , 6610i , 6650 , 6651 , 6800 , 6800 , 6810 , 6820 , 6820 , 6820i , 6822 , 6822 , 7200 , 7210 , 7250 , 7250i , 7260 , 7270 (TIKU), 7270 (TIKU) , 7280 (TIKU) , 7280 (TIKU) , 7360 , 7380 , 7600 (TIKU) , 7620 , 810 Car Kit, 8310 , 8390 , 8587 , 8800 (TIKU) , 8800 Sirocco Edition (TIKU) , 8801 (TIKU) , 8910 , 8910i , D211 , Nokia Remote Camera DCT-4+ (Plus) : 1200 , 1208 , 1208b , 1209 , 1650 , 1650b , 1680c-2b Classic, 2310 , 2600c , 2610 , 2610b , 2626 , 2630 Americas, 2630 Europe/Asia, 2670h Fold, 5000 , 5000 , 7070 |
08-18-2017, 08:27 | #1 (permalink) |
Junior Member Join Date: Aug 2017
Member: 2748732 Status: Offline Thanks Meter: 1 | unlock nokia 2310 with jaf box first, sorry i say/post something wrong or where i must not post but i try this morning to unlock a nokia 2310 and 1600 with jaf box 1.98.66 and i get this message. Searching for saved ini... Checking for file P..... Saved INI not found, loading INI list... Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code 0542495 Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-189\ Searching for default location of ini... Checking path: \Products\RM-189\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-189\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE i don't have ths .ini file, what i should do? p.s. i am biginner regards |
08-18-2017, 11:00 | #2 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | I move your thread in correct section . jaf is discontinued product , it's dead project now . anyway try to install flash file package into your pc for 2310 & 1600 . you can find ini files there according to it's product code . then try to unlock . |
08-18-2017, 14:40 | #3 (permalink) | |
Member: 2748732 Status: Offline Thanks Meter: 1 | Quote:
thank you very much, i will try. | |
08-20-2017, 12:24 | #4 (permalink) |
Member: 2748732 Status: Offline Thanks Meter: 1 | again me, done with nokia 1600. now i think i destroyed the nokia 2310 when i tried to upload new a flash. what can i do? i get this msg: MCU ID: 0x2201 FLASH ID0: 2A7E0001 <=> SPANSION -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 Done! Phone Restarted... p.s. the phone don't wanna start.. |
08-20-2017, 13:30 | #5 (permalink) |
Member: 2748732 Status: Offline Thanks Meter: 1 | i erased and i get this: how i flash, i can flash new firmware... Getting MCU ID MCU ID: 0x2201 FLASH ID0: 2A7E0001 <=> SPANSION -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 Done! Phone Restarted... Setting local mode... Failed! Aborting! Setting local mode... Failed! Aborting! Backing up PM Field 208 as RPL... Setting local mode... Failed! Aborting! Failed to backup imei... |
08-29-2017, 08:47 | #6 (permalink) |
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | it's don't need to be erased , anyway now you need to flash your set according to it's product code . you need to flash mcu,ppm,cnt files . also you need to write pm file of nokia 2310 after that you can able to do all ui settings . |
The Following User Says Thank You to .:SARCAR:. For This Useful Post: |
08-29-2017, 16:59 | #7 (permalink) | |
Thank you SARCAR, i did with successfully, now i have a problem with my j.a.f box i think, i can't read bb5 phone. Booting phone... Unknown field ID Error sync the phone. any idea? regards | |
08-29-2017, 20:27 | #8 (permalink) |
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | about bb5 booting , if you use fbus cable then you need 7pins fbus cable to boot properly . if you use usb cable then check or reinstall nokia connectivity cable driver . you just remember me about my old days ! plays with my jaf box ! it was a great third party tool back then . I make so much money from jaf . I never forgot such a great box !! |
