101 blinking on nokia after flash same....? 101 blinking on Nokia after flash same problem any one who solve this problem complete software then factory reset also imei ok LCD ok no water damage.. but still blinking any idea ....? Guljee:confused: |
Modreater plz responce me... Quote:
where is all master witch is doing and giving help here moderate plz answer... Guljee:confused: |
flashi with different box,,,,,,100% solve your problems |
chek is there bluetooth ic??? if yes remove it and post result. |
Give normal heat in cpu............then flash....... |
can u post self test i think atf can solve ur problem |
u all are let set return to customer :confused: sory but get solution any one plz shear .........thanks Guljee:) |
your lcd ok but change lcd your problem solved 100% try it |
Give normal heat in cpu.[IMG]http://www.***********/g.gif[/IMG] |
just rehot cpu tested many times |
