1100 dead after writting PM file (URGENT) 1100 dead after writting PM file (URGENT)>>>RH18>>>NEED HELP????????? |
flash with higher version and then write good (100%) ok pm file. SET WILL BE OK;) |
1) flash with erase flash file 2) flash with RH18 last version 3) write 1100 pm 4) make UI setting and good luck |
1100 pm file is here may be the pm file is not good so try with new pm file. this is not a hardware problem. |
try to erase file and then flash it again and good pm good luck |
erase file then flash that low version and then flash again ar latest version u set will be ok ..and then u cant write pm that problem is by UEM |
yes 1- full erase 2- full flash in higher version 3- write a good pm file, and then it will be ok, goog luck |
do like SALNAI will be ok |
erase flash, flash with v08.110. . write a good pm, full factory default,then init simlocks. br, |
only flash with latest file 100% work |
hi can i ask question about 1100 |
if you are confuse try to full erase, now the mobule is dead, now full flashing with high version, and then try to remove the cable and check it if it is now power on, if ther is power, connect to cable again and write pm, after writing pm try to power on, if no power means your pm file is not good, |
1100 dead after writting PM file (URGENT) |
write good pm bro everything will be ok after flashing with erase file |
