05-15-2008, 16:29 | #6 (permalink) | |
Insane Poster Join Date: Feb 2007 Location: Abu Dhabi,UAE
Member: 447572 Status: Offline Thanks Meter: 5 | Quote:
Yeah.... its d common problem of 1100,2300,2600 fones though UPP & UEM r sealed after longtime of usage so its Harware problem mate & its really risky to remove 1 of those components,practice is required. | |
05-16-2008, 10:26 | #7 (permalink) |
Junior Member Join Date: Mar 2008
Member: 727825 Status: Offline Thanks Meter: 2 | just a suggestion. why don't u try to erase full flash with ufs? after that don't make ui setting. write pm first, init sim lock. then u can make ui setting. if not working then u have hardware problem. chek batt conn, sim conn, and use original batt. |
05-16-2008, 19:44 | #9 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,349 | reball or change flash ic & check because 20 days ago I already repair a 1100 same like your post result |
05-18-2008, 10:05 | #12 (permalink) | |
I advise u to practice removing sealed Uem,UPP as possible as u can coz time will come u will encounter hardware problem & its ur chance to do it alone. | |
N96 only log nokia & restart | Naeem touheed | Nokia Base Band 5 ( BB-5 ) | 2 | 06-30-2009 06:06 |
N76 hang nokia & reboot | ijogo | Nokia Hardware & Hardware Repair | 12 | 03-21-2009 16:08 |
Nokia 6680 Hangs & Restarts | valentine aquil | Nokia Hardware & Hardware Repair | 7 | 08-02-2008 11:57 |
Nokia 1110i Hang & Restart | Ankit Verma | Nokia Hardware & Hardware Repair | 2 | 05-31-2008 06:03 |
Nokia 6680 Hang & Restart | zakir375 | Nokia Hardware & Hardware Repair | 10 | 12-13-2007 16:50 |
