07-16-2011, 02:38 | #1 (permalink) |
Junior Member Join Date: Aug 2010
Member: 1379311 Status: Offline Thanks Meter: 0 | n73 no network after flash Using device: AdvanceBox Turbo Flasher Library version: 1.0.0.9274(01-03-2011), 1.0.0.15761(01-03-2011) APE Data : SYSTEM ASIC ID: 17100708 [OMAP1710 ver: 2.0] ASIC MODE ID: 00 PUBLIC ID: 989B1F5A86D53A6C053019C9378B6CFC55DCB6B3 ROOT KEY HASH: 49A97E826B93BA20B7ED0B082475C00500000000 ROM ID: 1DFD66132C872FD4 CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 1F20010DE3F101548CA4343414AAFFAC3733F21E ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 22E8 - 0000 6921 [Samsung K8S2815ETB,128 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC TransmissionMode: DDR&TX2 SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500 Supported Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 FlashID0: 00EC 00A1 - 0080 0015 [Samsung KAL00T00EM-DGYY/66,1 Gbits] type: NAND,APE ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: h3_sam_nand_xsr.fg [OMAP1710 UNISTORE-II-1.2.1 ALG] version: 1.49.0 revision: 0.0 size: 0x13AA0 Supported Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 APE PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Processing MCU file: N73_4.0850.43.0.1_western_C00_PRD_cc.fpsx [BB5,BB5 ALGORITHM,BB5,OMAP1710 UNISTORE-II-1.2.1 ALG] size: 46.93 MB Supported Ids: 0103192101003000, 010C192101003000 Supported Ids: 17100708 Partitioning ...OK Erase size: 91.38 MB CMT NOR area [00080000-0073194D] CMT NOR area [00000000-0005FFFF] CMT NOR area [001E0000-001FFFFF] CMT NOR area [00880000-00FEFFFF] APE NAND area [00000000-0007FFFF] APE NAND area [00080000-000FFFFF] APE NAND area [00100000-0025FFFF] APE NAND area [003C0000-04E1FFFF] erased in 46.578 sTransmissionMode: DDR&TX2 Flash programming ... CMT PAPUBKEYS: 5E8D0D504A0902E261268C14FCD8A2C9093523BC (Rap Certificate 26 v1) written. APE PAPUBKEYS: 5E8D0D504A0902E261268C14FCD8A2C9093523BC (Ape Certificate 26 v1) written. Programming completed in 1 min 36.047 s Processing PPM file: N73_rofx_4.0839.42.2.1_PRD.V12 [BB5,BB5 ALGORITHM,BB5,OMAP1710 UNISTORE-II-1.2.1 ALG] size: 13.26 MB Supported Ids: 0000000000000000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000 Supported Ids: 17100700, 17100701, 17100702, 17100708 Partitioning ...OK Erase size: 21.00 MB APE NAND area [03920000-04E1FFFF] erased in 0.328 sTransmissionMode: DDR&TX2 Flash programming ... Programming completed in 44.812 s Processing CNT file: N73_userarea_4.0839.42.2.1.U01 [BB5,BB5 ALGORITHM,BB5,OMAP1710 UNISTORE-II-1.2.1 ALG] size: 11.46 MB Supported Ids: 0000000000000000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000 Supported Ids: 17100708 Erase size: 46.50 MB APE NAND area [04E20000-07C9FFFF] erased in 0.688 sTransmissionMode: DDR&TX2 Flash programming ... Programming completed in 18.563 s Total time for flashing process(boot+erase+write) was 3 min 35.718 s After Flash Processing ... Reseting Factory Values OK. Phone Type: RM-133 (Nokia N73) SW Version: V 05wk47v62 05-12-08 RM-133 (c) Nokia. Imei plain: 35897301061461-4 Product Code: 0529607 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 358973010614614 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 2.297 s |
07-16-2011, 05:56 | #2 (permalink) |
Freak Poster Join Date: Aug 2007 Location: india (hyd)
Member: 565996 Status: Offline Thanks Meter: 13 | hi sar n73 cange compent i hopp worke ImageShack® - Online Photo and Video Hosting reply meeeeee sar |
The Following User Says Thank You to riyaz_deva For This Useful Post: |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
no one can unlock 6110 05.40 25-5-99 | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 09-22-1999 08:03 |
