Old 03-07-2010, 06:49   #1 (permalink)
Member: 859900
Sonork: 100.1603641
Thanks Meter: 5
Cool 1100 IMEI Repair Successfully by MXkey
ASIC ID: 0x2201 [UPP_2M ver: 2]
SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0
Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164
FlashID0: 0020 8823 [ST 58WR016FU,8 Mbits] page size: 64 K type: NOR area: 01000000-010FFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C20
Performing Flash Authentication ...OK
UEM ID: 009BF66A:2984DA60
ASIC type: 2
UEM Imei: 35253100550967
Connecting to server ...OK, Login ...
Hello C0804704, you have 2010 credits left.
RPL saved to "C:\mobileEx\3.3\data\backup\RPL\35253100550967.RP L"
Programming FLASH Imei ...
FLASH programmed successfully.
Phone Type: RH-38
SW Version: V 7.36 21-11-05 RH-38 (c) NMP 1100c
Imei plain: 3525310055
Product Code: 0512815
Cellular System: GSM
ASIC ID: 0x2201, type: 2
Ppm Id: QA
Language Pack:
English,Chinese Simpl.
Imei net: 35253100550967
Version:
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000000002
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
The Following 4 Users Say Thank You to nabindra For This Useful Post:
Old 03-07-2010, 07:31   #2 (permalink)
Member: 1149774
Sonork: 0313-9541047
Thanks Meter: 1,163
keep it upppppppppppppp
Old 03-07-2010, 08:55   #3 (permalink)
bgreat's Avatar
Member: 727235
Thanks Meter: 1,210
good work brother................
Old 03-07-2010, 10:42   #4 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 699
Originally Posted by nabindra View Post
Phone Type: RH-38
i m confused here i think 1100 type rh-18 not a rh-38
Old 03-07-2010, 10:48   #5 (permalink)
Member: 1121946
Thanks Meter: 4
Bro 1100b type rh-38
The Following User Says Thank You to mondal38 For This Useful Post:
Old 10-12-2011, 16:25   #6 (permalink)
m.awais.as's Avatar
Member: 1284347
Sonork: 100.1592292
Thanks Meter: 976
use ATF BOX
just click repair imei option your problem will b solve
br,
AM_GSM_CELL...:::AWAIS.AS:::...
Old 05-18-2012, 05:38   #7 (permalink)
Member: 1710210
Thanks Meter: 35
ASIC type: 2
Phone Type: RH-38
Ppm Id: QA
Language Pack:
Version:
Counter: 0/3, 0/10
bro please tell how can i do this. whts the procedure
MXBOX - Successfully Unlocked/repaired/flashed Phones By MXBOX kabirhossain MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3969 10-05-2016 05:13
[MXKEY - INFO] Successfully Unlocked/repaired Phones By MXKey kamranas MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 03-12-2010 09:55
POST. Successfully SD,Security Repaired Phones By MXKey 786786 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 23 02-20-2010 14:19
6233 Successfully repaired Phones By MXKey who_i MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 02-07-2010 12:06
Page generated in 0.31233 seconds with 8 queries
