08-20-2005, 15:26 | #2 (permalink) |
No Life Poster Join Date: Dec 2001 Location: United Arab Emirates, Dubai Age: 52
Member: 7751 Status: Offline Thanks Meter: 74 | @shri This fault has been covered many times here, next time, do a SEARCH on the board before posting. Essetially you'll have to the do following... 1 : Check Fuse and charge line components. capasitors, diodes ect (see service manual) 2 : Check Connector and connector springs and the board pads 3 : If all ok, the only thing wrong is UEM 4 : After change of UEM, Write RPL, full erase flash, write MCU + PPM + PM files and your done. 5 : If you get the dreaded "blinking" just write different PM files, sometimes I've had to write like 5 different before finding a good one ! Regards |
08-20-2005, 16:13 | #3 (permalink) |
No Life Poster Join Date: Jul 2004 Location: BANDA ACEH INDONESIA
Member: 74519 Status: Offline Thanks Meter: 79 | Display info when charger is connected : "Not charging" 1. R206 Voltage on R206 towards D200 is ~0,8VDC when power is connected. (BSI must be 75K) if OK go to point 2 if NO Check :X105, R202, R206, C240. 2. R207 Voltage (use scope) on R207 towards D200 is ~0,9VDC at peak. (BSI must be 47K) if OK go to point 3 if NO Check : X105, R202, R207, C220. 3. R200 Voltage on R200 towards D200 same as VBAT voltage, if OK go to point 4 if NO Check :R200, PWB. Else defective D200 4. R200 Voltage rises slowly on R200 towards D200 when charger is connected. if OK go to point 5 if NO Check :PWB. Else defective D200 5. Check :PWB phone not responding charging? - Check :F100, L100, V100, C100,R200, System-connector. - Defective D200 or D400 |
1100 not charging | gbada | Nokia Hardware & Hardware Repair | 35 | 07-08-2012 14:48 |
1100 not charging and auto charging | gsmsikar | Nokia Hardware & Hardware Repair | 11 | 03-23-2009 23:30 |
1100 Not charging | bassboli | Nokia Hardware & Hardware Repair | 13 | 03-23-2009 20:07 |
1100 not charging solution? | etcelfon | Nokia Hardware & Hardware Repair | 4 | 07-30-2008 16:20 |
1100 not charging | jaaja | Nokia Digital Core Technology 4 ( DCT-4 ) | 5 | 03-07-2005 04:55 |
