05-02-2006, 16:08 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Age: 46
Member: 73797 Status: Offline Thanks Meter: 19 | 1100 still no signal???? if some one has idea plz help.?????? what measure shuold be next???? |
05-02-2006, 16:22 | #3 (permalink) | |
Freak Poster Join Date: Jun 2004 Age: 48
Member: 70518 Status: Offline Thanks Meter: 21 | Quote:
05-02-2006, 16:29 | #5 (permalink) |
No Life Poster Join Date: Nov 2001 Location: England Age: 41
Member: 7653 Status: Offline Thanks Meter: 823 | base band is MCU/processor/flash memories and all other components linked there. if you did search the forum before you go changing power amp/filters, you will find the trick to diagnose your fault. when network appear then drop, or network name only: make manual search for network. if all networks is find, then your problem is PA. if no networks is find: then you have problem in base band. |
05-02-2006, 16:30 | #6 (permalink) |
Member: 7653 Status: Offline Thanks Meter: 823 | but now, you have changed some components you make it more difficult. you may have caused additional faults due to bad component or soldering or excess heat.... |
05-02-2006, 16:47 | #7 (permalink) |
Member: 73797 Status: Offline Thanks Meter: 19 | as u mentioned. i manually searched for network, after long time(about 1 min) found network but when try to register it says no access. I m afraid I m wrongly changing P.A. It looks made of plastic. when i tried to change it required bit higher heat (on pt 5). May be it damaged during change???? Is there anyother method to replace such plasitic looking P./As. or i m rightly replacing it??? |
05-02-2006, 16:50 | #8 (permalink) | |
Junior Member Join Date: Jan 2005 Location: Italy Age: 47
Member: 110973 Status: Offline Thanks Meter: 0 | It tries to make these jumpers. antinna1100 bay samirsana.JPGIt tries to make these jumpers. I have resolved this way. Quote:
05-02-2006, 17:01 | #10 (permalink) |
Member: 7653 Status: Offline Thanks Meter: 823 | i dont think you can jumper the power amp effectively, it is an amplifier not just a staraight through connection... sallu, you can heat the plastic case IC's with heat 3 and air 3 with no damage (if you do not hold nozzle over for too long). please use plenty of flux over the IC to protect it some. i find liquid flux is the best, as you can get it under the IC. |
05-02-2006, 17:17 | #12 (permalink) |
Member: 73797 Status: Offline Thanks Meter: 19 | please mr Dave thnx very much. i take air 1 or 2. may it be the cause of damage. ut with air 3, i think air flow will be may disturb near by components Last edited by sallu; 05-02-2006 at 17:28. |
05-06-2006, 17:01 | #14 (permalink) |
Member: 73797 Status: Offline Thanks Meter: 19 | yea, my pm file ws not right. after writing good pm solved this problem of both 1100 and 2300 conclusion i got when operator name is on screen but no signal that is most probably pm file problem. |
iPhone 3g complete but no still no signals....plz help???? | Bismillah_mob | iPhone 2 / iPhone 3G / iPhone 3GS | 9 | 01-28-2010 12:53 |
821sc still no signal in the philippines | eljhay | UST Pro II | 1 | 06-20-2009 17:39 |
6101 after imei patch. shutdown and still no signal | dawgweed | Universalbox | 3 | 05-03-2008 09:07 |
U970 Unlocked Nvm Restored Still No Signal | TEKIN | ULT PRO | 2 | 09-30-2007 14:56 |
Pls Help my nokia 1100 has no signal! | redge | Nokia Hardware & Hardware Repair | 3 | 05-25-2006 10:54 |
