Old 03-08-2007, 09:09   #1 (permalink)
hafizjee's Avatar
Member: 234653
Thanks Meter: 83
Question 1110, 1110i, 1112 Speaker Problem
i have Nokia 1110
i connect Hands Free with this set, but when i disconnect the Hands Free, a small CAR appear on display and Loud Speaker, Ringer, Ear Speaker volume becomes off
please help me with pic
Thank you
The Following 7 Users Say Thank You to hafizjee For This Useful Post:
Old 03-08-2007, 10:16   #2 (permalink)
makkah mobile's Avatar
Member: 226363
Sonork: 03--4899925
Thanks Meter: 569
1st u clean ur bottm area of noard change ur bottom with new one and take any original handfree of 6030 . and do this trick put remove put remove again and again and last one last time put again and make a valls 4 15 mints ur problem will b solve
The Following 3 Users Say Thank You to makkah mobile For This Useful Post:
Old 03-08-2007, 10:25   #3 (permalink)
..::Mr_Fone::..'s Avatar
Member: 364745
Thanks Meter: 719
hi dear your set handfree pro i have some sultion but this is a por in gsmhosting no uploding attechmengment option not open .then look mic point to near 4 copster only 1 remove r2010 remove balke coler regstince . and i hope youer set is ok...::mr fone::..
The Following User Says Thank You to ..::Mr_Fone::.. For This Useful Post:
Old 03-08-2007, 10:28   #4 (permalink)
Member: 463844
1110 showing car
Originally Posted by hafizjee View Post
i have Nokia 1110
Thank you
change charging socket
The Following User Says Thank You to naresh rawal For This Useful Post:
Old 03-08-2007, 11:16   #5 (permalink)
sonuveene's Avatar
Member: 308760
Thanks Meter: 47
Thumbs up 1110,1600
i have Nokia 1110
Thank you
frnd try this solution.......................
The Following 6 Users Say Thank You to sonuveene For This Useful Post:
Old 03-14-2007, 03:18   #6 (permalink)
shakeelajmal's Avatar
Member: 51639
Thanks Meter: 76
no luck man that solution not work .. i check it change it remove but still in handsfree mode .. 1112 and 2310 both are in handsfree mode is there any other solutions so slove this problem waiting for your reply...
The Following 2 Users Say Thank You to shakeelajmal For This Useful Post:
Old 03-14-2007, 07:14   #7 (permalink)
Member: 76716
Thanks Meter: 15
Try this
Try this way. I got this solution from This forum only.1100 Car Prob solution.jpg
The Following 4 Users Say Thank You to parvezjk For This Useful Post:
Old 03-14-2007, 07:45   #8 (permalink)
Member: 432364
Thanks Meter: 270
i have Nokia 1110
Thank you
Change charging connector and post result.So many times I have solved this problem by changing charing connector.
B.r.
Sunil.
The Following 2 Users Say Thank You to ..::Sunil::.. For This Useful Post:
Old 03-29-2007, 11:34   #9 (permalink)
TheRascal's Avatar
Member: 108398
Thanks Meter: 8
I have similar problem. On startip the phone is in HF mode without the connector
The Following 2 Users Say Thank You to TheRascal For This Useful Post:
Old 03-29-2007, 12:04   #10 (permalink)
Member: 365088
Thanks Meter: 2
thanks for your pics
The Following 2 Users Say Thank You to ebuk For This Useful Post:
Old 03-29-2007, 18:29   #11 (permalink)
Member: 190856
Thanks Meter: 27
only change ringer crystal ic
The Following 2 Users Say Thank You to gameland For This Useful Post:
Old 03-31-2007, 05:33   #12 (permalink)
Member: 350571
Thanks Meter: 920
try this
i have Nokia 1110
Thank you
try the all above members solutions ( if not ok )
flash the mobile
The Following 2 Users Say Thank You to sree krishna For This Useful Post:
Old 03-31-2007, 06:29   #13 (permalink)
jaggi's Avatar
Member: 258480
Thanks Meter: 14
just change charging socket ur problem will b solved.............................
The Following 2 Users Say Thank You to jaggi For This Useful Post:
Old 03-31-2007, 06:40   #14 (permalink)
Registered User
Member: 189506
Sonork: 100.1576871
Thanks Meter: 126
jaggi is right
The Following 2 Users Say Thank You to bhogpurmail For This Useful Post:
Old 03-31-2007, 06:53   #15 (permalink)
Member: 190856
Thanks Meter: 27
i have Nokia 1110
Thank you
bro check this .................
The Following 5 Users Say Thank You to gameland For This Useful Post:
Nokia 1110,1110i ,1112,etc malikkk Nokia Digital Core Technology 4 ( DCT-4 ) 14 04-19-2008 15:49
1110 1110i 1112 1600 etc problem israrudin Nokia Digital Core Technology 4 ( DCT-4 ) 27 01-23-2008 19:37
1110, 1110i, 1112 and 1600 resolution problem murtaza_nns Nokia Digital Core Technology 4 ( DCT-4 ) 33 06-10-2007 16:59
1110,1110i.1112,contrast failed kabirhossain Nokia Digital Core Technology 4 ( DCT-4 ) 2 12-26-2006 16:16
Page generated in 0.51549 seconds with 10 queries
