Old 11-03-2007, 14:20   #1 (permalink)
Member: 520724
Thanks Meter: 349
1110,1112,1600 etc. LCD light solution
Hi mates and aslamualikum.
after this i want to help u if ur 1110,1112,1600 or any other set like this and u can solve its lcd light problem by using my solution if u need
u need no light ic in this procedure
http://www.*******.com/image_preview.php?i=5&u=11449950
The Following 13 Users Say Thank You to abdul4gsm For This Useful Post:
Old 11-03-2007, 15:51   #2 (permalink)
reji's Avatar
Member: 227127
Thanks Meter: 241
did u tested this jumper?
The Following 5 Users Say Thank You to reji For This Useful Post:
Old 11-03-2007, 16:11   #3 (permalink)
reji's Avatar
Member: 227127
Thanks Meter: 241
dear abdul4gsm,
on ur jumper solution, u r shorting the VFLASH 2.8v to VBAT.
is this cause any problem?
The Following 2 Users Say Thank You to reji For This Useful Post:
Old 11-19-2007, 11:45   #4 (permalink)
zullu2004's Avatar
Member: 146635
Sonork: 100.1651273
Thanks Meter: 261
tested on nokia 1600 with no light at all
100 % driver problem, but
jumper solution tested, NOT WORKING, no light at all
anyone else ?
The Following 4 Users Say Thank You to zullu2004 For This Useful Post:
Old 11-19-2007, 15:05   #5 (permalink)
Vijendra Saini's Avatar
Member: 398557
Sonork: 100.1578489
Thanks Meter: 1,516
Nothing to do any silly Idea change only light IC
The Following 3 Users Say Thank You to Vijendra Saini For This Useful Post:
Old 12-11-2007, 18:02   #6 (permalink)
erkan06us's Avatar
Member: 174769
Thanks Meter: 19
tested on 1112. solution does not work!..
The Following 2 Users Say Thank You to erkan06us For This Useful Post:
Old 12-11-2007, 18:29   #7 (permalink)
sopnil's Avatar
Member: 528679
Thanks Meter: 268
I Will Say Change Light Ic..............is The Best
The Following 4 Users Say Thank You to sopnil For This Useful Post:
Old 12-11-2007, 18:44   #8 (permalink)
Member: 358277
Thanks Meter: 476
1600 light solution
bro here is tested solution for 1600 light.also both leds will work.check solution.if any problem? pm me .
File Type: jpg New%2520solution%2520nokia%25201112%2520LIGHTWAYs.jpg (43.3 KB, 4899 views)
The Following 15 Users Say Thank You to jai2008 For This Useful Post:
Old 12-11-2007, 19:11   #9 (permalink)
Member: 625521
Thanks Meter: 8
We have experienced light always works
The Following 3 Users Say Thank You to freeman11 For This Useful Post:
Old 12-11-2007, 19:35   #10 (permalink)
bocahklaten's Avatar
Member: 295100
Thanks Meter: 212
Yes It's work... I always do this sol..
The Following 2 Users Say Thank You to bocahklaten For This Useful Post:
Old 12-11-2007, 22:14   #11 (permalink)
Member: 625521
Thanks Meter: 8
What I mean is that the lighting is not extinguished
The Following 2 Users Say Thank You to freeman11 For This Useful Post:
Old 12-11-2007, 22:17   #12 (permalink)
Member: 625521
Thanks Meter: 8
The solution is incomplete,
but thank you
Old 12-12-2007, 05:05   #13 (permalink)
Member: 56996
Thanks Meter: 9
first u need to chk the vbat connection if its still have a connection if there is, then the jai2008 sol. is write but if dont then go for abdul4gsm....tested by me many times........so last thing u need to read sytimatic diagram b4 applying different trics and trace the connection hope it help to all....
br
opaw
The Following 2 Users Say Thank You to opaw For This Useful Post:
Old 12-12-2007, 06:00   #14 (permalink)
Member: 6758
Thanks Meter: 294
this sol work 100 % in 2310 .
1 remov old chip and chek V bat
2 add LTYN chip from old samsung LCD
The Following 9 Users Say Thank You to Prima For This Useful Post:
Old 12-12-2007, 06:04   #15 (permalink)
Member: 647811
Thanks Meter: 2
plesa solwed prblem 1110 lcd light
The Following 2 Users Say Thank You to zaibali_2007 For This Useful Post:
nokia 1110 1112 1600 2310 PA network solution m zubair Nokia Hardware & Hardware Repair 6 08-03-2010 05:58
1110-1112-1600-2310 lcd gone 4 sec 100% solve mobiletuch Nokia Hardware & Hardware Repair 7 02-05-2010 08:49
1110,1112,1600,2310 insert sim solution m zubair Nokia Hardware & Hardware Repair 0 11-25-2009 23:05
new light solution for 1110,1112,1600 etc for new members tabarat1 Nokia Hardware & Hardware Repair 7 04-01-2009 08:24
Page generated in 0.24481 seconds with 10 queries
