Old 12-20-2007, 11:06   #1 (permalink)
Member: 480959
Thanks Meter: 49
Arrow 1110, 1600, 2310 Contact Service After flash 100000% soution
Use older version of files or use existing version
1110--3.08 version 100% working
1600--3.34 version 100% working
2310 -- the same
The Following 22 Users Say Thank You to Sandeep_$tomar For This Useful Post:
Old 12-21-2007, 15:47   #2 (permalink)
thomp4pal's Avatar
Member: 292106
Sonork: 100.1582885
Thanks Meter: 116
not work for 1110i/1112, still contact service
The Following 3 Users Say Thank You to thomp4pal For This Useful Post:
Old 12-21-2007, 18:18   #3 (permalink)
Member: 465901
Thanks Meter: 45
it is workng thanks a lot
The Following User Says Thank You to ZENITHMOBILE For This Useful Post:
Old 12-21-2007, 18:30   #4 (permalink)
Member: 230911
Thanks Meter: 177
This Solution does not works always however in some cases it works.
The Following User Says Thank You to Kethey For This Useful Post:
Old 12-21-2007, 19:10   #5 (permalink)
Member: 18057
Thanks Meter: 64
ha ha ha wht solutions.. ???????? really,.. if u already flash with newer versons... or still same CONTACT SERVICE,. .so this is HARDWARE issue.... or .upp is responsible.. for this .. heat it . .reball it .. thts it.. nothing.. more.. against this
The Following User Says Thank You to akshay For This Useful Post:
Old 01-07-2008, 08:51   #6 (permalink)
Member: 131336
Thanks Meter: 7
Yup
Downgrade Just Work In Some Cases
Old 01-07-2008, 09:26   #7 (permalink)
mazmaz1's Avatar
Member: 339455
Sonork: 100.1589401
Thanks Meter: 86
Hello
This is solution
1 Full erase
2 full flash with good flash files
3 Write PM
4 Unlock
5 Default setting
If your phone stay in contact service same as befor flashing it has
hardware problume.
service the board for this issuse.
The Following 5 Users Say Thank You to mazmaz1 For This Useful Post:
Old 01-07-2008, 12:52   #8 (permalink)
hasanphone's Avatar
Member: 342931
Sonork: 100.1659224
Thanks Meter: 83
just write a good pm.100% ok.
The Following User Says Thank You to hasanphone For This Useful Post:
Old 01-07-2008, 13:11   #9 (permalink)
DIGITAL BABU's Avatar
Member: 420857
Sonork: 100.1576793
Thanks Meter: 1,734
Pls Update Verson Setup Than Flash
And 100% Ok
!!!!!!!enjoy!!!!!!!
The Following User Says Thank You to DIGITAL BABU For This Useful Post:
Old 01-07-2008, 19:36   #10 (permalink)
gsm st's Avatar
Member: 143007
Thanks Meter: 141
Originally Posted by mazmaz1 View Post
Hello
This is solution
1 Full erase
3 Write PM
4 Unlock
5 Default setting
hardware problume.
THIS SOLUTION IS 99% GOOD..THANKX ..
The Following 3 Users Say Thank You to gsm st For This Useful Post:
Old 01-07-2008, 20:00   #11 (permalink)
Member: 600877
Thanks Meter: 2
Hello
This is solution
1 Full erase
3 Write PM
4 Unlock
5 Default setting
hardware problume.
that is true or u can flash the phone with last version
The Following 2 Users Say Thank You to mahmoud el masr For This Useful Post:
Old 01-08-2008, 05:34   #12 (permalink)
WinD_VteC's Avatar
Member: 647414
Thanks Meter: 127
IT WAS WORK THANKS A LOT.... GOOD JOD ....
WinD
The Following User Says Thank You to WinD_VteC For This Useful Post:
Old 01-08-2008, 05:40   #13 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
If u done all these solution which are given above but ur problem not solve then u reball cpu ur problem will 100% solve i solve this problem in more than 50 handset ,.......................be careful while reballing cpu.....it is a tough job.....it need experince ,............good luck
The Following 2 Users Say Thank You to digitized For This Useful Post:
Old 01-09-2008, 20:41   #14 (permalink)
Member: 669218
Thanks Meter: 11
majority cases work otherwise not work bcoz it is hardware issu
The Following User Says Thank You to shahidkhan1 For This Useful Post:
Old 05-14-2008, 09:56   #15 (permalink)
Member: 235448
Thanks Meter: 18
full erase + flash + good pm + unlock + ui setting works for me
The Following 3 Users Say Thank You to Gworld For This Useful Post:
1110 [RH70] contact service after flash!!! SLIPLOCK Nokia Digital Core Technology 4 ( DCT-4 ) 58 11-05-2008 19:38
1110,1112,1600,2310 contact service 100% tested solution khan_mobiles HWK 1 09-07-2008 11:12
2310 contact service after downgrade !help ! crown Nokia Digital Core Technology 4 ( DCT-4 ) 19 11-27-2007 08:29
1110 contact service after flash but ok when boot from ufs mobilemani Nokia Digital Core Technology 4 ( DCT-4 ) 11 07-09-2007 07:59
Page generated in 0.29453 seconds with 10 queries
