Old 03-24-2006, 10:53   #1 (permalink)
Member: 249217
6600 Dead
I Have a 6600.After flashing it was not ok.pls help me
Old 03-24-2006, 11:02   #2 (permalink)
Member: 243896
Thanks Meter: 10
you have check power out puts(VBB,VXO,VECORE) & Other power on connections
Old 03-27-2006, 15:33   #3 (permalink)
Member: 246407
Thanks Meter: 3
You Check Voltage And Battery Connector After Removing Battery Put Charger And Check If You Get Battery Voltage On Battery Connector Then Try To Flashing The Phone If Problem Not Solved Then This Is Hardware Problem Then Check Input And Output Voltage Of Uem And Check Crystal Oscillator Flash Ic And Cpu
Old 03-27-2006, 15:34   #4 (permalink)
Member: 246407
Thanks Meter: 3
Also After Flashing Use Format User Area
Old 03-31-2006, 08:53   #5 (permalink)
nishaon's Avatar
Member: 225229
Thanks Meter: 90
Sir,
After erasing my 6600 is dead now, just 1st boot ok noyhing else. so when I try to flash with UFS3 the following error shows:
1st Boot Ok, WD2, UPP: 1081
Fl0: 0x00000000-0x007FFFFF,002088C0,St M28W640
Fl1: 0x02000000-0x027FFFFF,002088C0,St M28W640
Fl2: 0x04000000-0x047FFFFF,002088C0,St M28W640
Fl3: 0x06000000-0x067FFFFF,002088C0,St M28W640
Algorithm: w3_st_i.fia, w3_cbusb.fia, Ver: 4.49.0
Algorithm Ok, MSID: 84C1D35DD48B53B2B053A2C09B
Decoded MSID: 3E4EBAF7-0017BF1A-A9000000
Encoded FAID: C80F8100-36EA1189-8340A06C
Cbus Boot Error: 9
Error Data1:
00000000: 00 96 84 C1 D3 5D D4 8B 53 B2 B0 53 A2 C0 9B 26 .....]..S..S...&
00000010: 00 C0 88 00 00 21 01 10 00 04 20 00 C0 88 00 00 .....!.... .....
00000020: 21 01 10 00 06 20 00 C0 88 00 00 21 01 10 00 FF !.... .....!....
00000030: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 93 ................
Error Data2:
00000000: B3 72 72 C0 88 00 00 21 01 10 00 02 20 00 C0 88 .rr....!.... ...
00000010: 00 00 21 01 10 00 04 20 00 C0 88 00 00 21 01 10 ..!.... .....!..
00000020: 00 06 20 00 C0 88 00 00 21 01 10 00 FF FF FF FF .. .....!.......
00000030: FF FF FF FF FF FF FF FF FF FF FF FF 93 D3 72 00 ..............r.
Before taking screenshot, expand this window !
Process Failed, Repowering Mobile
can you please help me to solve the problem, please please......
[email protected]
Old 03-31-2006, 08:58   #6 (permalink)
Member: 149576
Thanks Meter: 57
Originally Posted by nishaon
Sir,
Cbus Boot Error: 9
Error Data1:
Error Data2:
[email protected]
try flash again the phone and "uncheck" the enable BT flashing. post result
Old 03-31-2006, 09:16   #7 (permalink)
Member: 248333
maybe fia end bt.........
nokia 6600 dead taking flashing,but still dead sandeepmtc Nokia Hardware & Hardware Repair 0 08-24-2007 17:53
6600 flashing error now 6600 dead kabeermaster25 Nokia Hardware & Hardware Repair 25 04-08-2006 02:31
6600 dead.......... zdob Griffin 16 11-08-2004 09:38
6600 dead after flashing with new 4.09.1 mohd_anan WD2 & APE (Symbian Phones) 7 04-26-2004 06:55
6600 Dead marukiaro Nokia Digital Core Technology 4 ( DCT-4 ) 7 02-24-2004 00:26
Page generated in 0.18874 seconds with 9 queries
