1110 dead 1110 dead when i am trying to flash its shows like this what is the prolem Getting MCU ID MCU ID: 0x2201 FLASH ID0: 00010000 <=> Flash -> not used Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 0 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: 00 00 00 01 00 02 00 03 00 04 00 05 00 06 00 07 Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 Done! Phone Restarted... Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\products\rh-93\rh93_06.010 PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\products\rh-93\rh93_06.010 PPM Flash file: C:\Program Files\Nokia\Phoenix\products\rh-93\rh93_06.01ad CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,French,German,Turkish Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\products\rh-93\rh93_06.010 PPM Flash file: C:\Program Files\Nokia\Phoenix\products\rh-93\rh93_06.01ad CNT Flash file: C:\Program Files\Nokia\Phoenix\products\rh-93\rh930_nai6.01ad ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,French,German,Turkish Backing up PM Field 208 as RPL... Setting local mode... Failed! Aborting! Failed to backup imei... MCU: C:\Program Files\Nokia\Phoenix\products\rh-93\rh93_06.010 Booting phone... MCU ID: 0x2201 BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A0 Boot is ready... FLASH ID0: 00010000 <=> Flash -> not used Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 0 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: 00 00 00 01 00 02 00 03 00 04 00 05 00 06 00 07 Flash ID is 0x01000000 Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7518; Loader chk: a6 Loader is ready... P-key nokia module version 01.02 MSID: 843076CF00AC0E049202E43B99 MSID decoded: 3E4EBAE9004A3017A9000000 FAID: 4C3806E93920BD2385F0D24D Operation took 0 minutes 12 seconds... Erasing... Found 5 interval(s) to erase Erasing area: 01000000 - 0100FFFF... Erasing area: 01010000 - 013BFFFF... Erasing area: 013C0000 - 013EFFFF... Erasing area: 017C0000 - 017EFFFF... Erasing area: 01FC0000 - 01FEFFFF... Operation took 0 minutes 10 seconds... Writing... Permanent Data Restore FAILED! Operation took 9 minutes 55 seconds... Restarting MCU... Failed! Aborting! |
rehot rem and upp carfully then try flas |
dear clean pcb and rehot it specialy uem and flash ic then first erase and flash |
thanks i just washed the pcb and rehot uem and flash and then flashed...my problem cleared now anyway thanks the both who respond to my thread |
