05-23-2006, 15:17 | #2 (permalink) |
No Life Poster Join Date: Feb 2003 Location: on the Moon ;) Age: 47
Member: 21937 Status: Offline Thanks Meter: 279 | check charging fuse , check charging components near fuse. reflaw uem , flash , write good pm in this order 1 after the oder if first didnt fix |
05-23-2006, 15:23 | #4 (permalink) | |
No Life Poster Join Date: Dec 2001 Location: In front of my computer
Member: 7741 Status: Offline Thanks Meter: 111 | [QUOTE=Genpa_sukru] Quote:
06-15-2006, 06:46 | #5 (permalink) |
Banned Join Date: Jun 2004 Location: GSM HEAVEN Age: 36
Member: 69984 Status: Offline Thanks Meter: 170 | Hi all mate,, nice work.... help me to repair charging problem in 1110, when insert charger no result.. and charging ways (+ve) does not connect any where in circut.. please send me solution. urgent. URGENT - Many friends are facing this problem... help us. WBR A@DIL |
06-15-2006, 09:13 | #9 (permalink) | |
Freak Poster Join Date: Jul 2004 Location: always around
Member: 74338 Status: Offline Thanks Meter: 11 | Quote:
after the flashing is complete, i did write a good 1600 clean pm and woo ... when i inserted the charger into the phone, it started charging. that is to say pm can affect both 1110 and 1600 respectively. it solved my problem and it might help you. 1110 and 1600 are in the forum just in case you don't have one. just give it a try. good luck and best regards dennis1 | |
06-16-2006, 20:25 | #10 (permalink) | |
Junior Member Join Date: Apr 2006 Location: hyderabad, india
Member: 260823 Status: Offline Thanks Meter: 11 | 1110 not charging Quote:
The Following User Says Thank You to aanish For This Useful Post: |
07-03-2006, 20:13 | #12 (permalink) |
No Life Poster Join Date: May 2003
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | in a 1110 set it was water damaged , then after cleaning it it shows LOCAL MODE , then after searching the forum i connect a jumper near the battery connector , then the set started working well but without LED light and NOT CHARGING, how to repair it ? |
07-28-2006, 14:54 | #14 (permalink) | |
Member: 7741 Status: Offline Thanks Meter: 111 | Quote:
can u show me how u connect the jumpernear the battery connector? TIA | |
1110 not charging solution | vishu222 | Nokia Hardware & Hardware Repair | 11 | 12-26-2012 10:54 |
1110 not charging | ijazali | Nokia Hardware & Hardware Repair | 15 | 04-25-2009 11:16 |
hi all plz help 1110 not charging | abualia | Nokia Hardware & Hardware Repair | 6 | 05-24-2008 11:52 |
1110 not charging | williamvirk | Nokia Hardware & Hardware Repair | 2 | 08-17-2006 19:36 |
1110 not charging | ijazali | Nokia Hardware & Hardware Repair | 0 | 06-24-2006 07:40 |
