1110 ringer problem Hello friends, 1110 earpiece ok , printing ok works fine but ringer does not works , no ring sound plz help |
check the ringer ic sir.......... try reflow |
1 Attachment(s) bro, try this and also post your result i think it may helpful to you best of luck jimmy |
change ringr ic.it will work 4 u. |
replease ringer ic 1- test your ringer 2-cheak trak . 3- replease ringer ic 100% test ok |
1110 ringer problem 1 Attachment(s) Hi, you are saying ear sound ok but ringer sound problem only In that case jumper cannot solved your problem so see the picture And replace that ringer ic SOPNIL |
Not to change a ringer nor to make a jumper only you have to change ringer ic. Thank you. |
here is all of your solution in one click Here is all of your solution in one click just download this Repairing guide software http://0gnlhw.bay.livefilestore.com/...ren%20shot.PNG http://cid-5a8e5b06c4d8c175.skydrive...gsmhosting.exe |
with best wishes... |
Its okay fILE IS CLEAR GO SERCH BAR AND TYPE "GIFT FOR GSMHOSTIN" YOU CAN SERCH THIS FILE MANY PERSON DOWNLOAD THIS FILE WITHOUT ANY PROBLEM |
1110 change the big ringer ic 6lekic changed |
1110 ringer ways plz |
chaek i,c if not work then also chaek charging jack |
