10-05-2006, 07:08 | #1 (permalink) |
Freak Poster Join Date: Apr 2006 Location: Inside PM
Member: 258154 Status: Offline Thanks Meter: 319 | 1110_1600_Insert Sim 99% working Solution Just Check this solution... 1) before removing the SIM IC first Remove the Charging/HF Socket.. and check is still asking for SIM..if yes change SIM IC..if not asking "Insert SIM" then make a jumper like below.. Adampur Hawks Last edited by adampurhawks; 10-05-2006 at 09:36. |
The Following 5 Users Say Thank You to adampurhawks For This Useful Post: |
10-07-2006, 06:24 | #5 (permalink) |
Member: 258154 Status: Offline Thanks Meter: 319 | Another Solution with the sim IC Here is the universal SIM Jumper Solution ....for DCT 4 Adampur Hawks |
The Following User Says Thank You to adampurhawks For This Useful Post: |
10-07-2006, 07:22 | #6 (permalink) |
Freak Poster Join Date: Sep 2003 Location: Romania - Hungary Age: 47
Member: 39503 Status: Offline Thanks Meter: 44 | Hy Before you do anything, first of all check if VSIM is not grounded (shorted to ground or low impedance 10-50 ohm) ... if it is change or remove C203 ... ( i had a lot of problems with those capacitors in "insert sim" situations) WBR golumbu |
10-07-2006, 14:40 | #8 (permalink) | |
Member: 258154 Status: Offline Thanks Meter: 319 | Quote:
Hey Man if u don know anything Just dont argument, if u dont know any thng abt this....people in the forum are not fool...ok...they are taking my advice...and i have also repaired 15 pcs..with this trick...i have told u that 1) First Remove this HF/Socket and then check the phone if still asking for insert Sim...if not then change the HF Socket..may be there is some kind of shorting.... If still asking for Insert SIM Card....then change the SIM IC Ok... Now open the screws of your mind and try and then Post me ur reply.. | |
11-08-2006, 23:31 | #10 (permalink) | |
Insane Poster Join Date: Sep 2004 Age: 50
Member: 83879 Status: Offline Thanks Meter: 4 | Quote:
Yes, ADAMPURHAWK u are right; In 1110,1600.6030 Insert Sim problem is owing to pcb is liquid damaged at bottom side, I also repair about 50 sets by just cleaning bottom connector ITS NOT BSI LINE FAULT IN 1110 | |
11-09-2006, 03:39 | #11 (permalink) | |
Junior Member Join Date: Jul 2006
Member: 316305 Status: Offline Thanks Meter: 1 | Quote:
this solution working for others ? | |
11-10-2006, 10:09 | #14 (permalink) | |
Junior Member Join Date: Nov 2006
Member: 386966 Status: Offline Thanks Meter: 1 | Quote:
What materials to be used for cleaning? | |
venus s1000 sim 2 not working - solution? | fkjason | Chinese Models & Cloned Phones | 0 | 07-19-2009 23:03 |
1000% working solution for w810 insert correct sim | dreameye | Sony Ericsson | 5 | 05-20-2009 05:25 |
