Old 07-31-2008, 06:59   #1 (permalink)
Member: 601371
Thanks Meter: 12
Arrow 1112 local mode
i have a 1112 it was in not charging fault i was try to remove the double ristise which is normaly remove when it is local mode i break its uper two lads now the set is in local mode
ANy one plz give its solution
thanks n advance..
Old 07-31-2008, 17:21   #2 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,350
first try to remove small parts behind battery connector if problem not solved then post a clean picture of your pcb
Old 07-31-2008, 19:41   #3 (permalink)
mehedi.h.j's Avatar
Member: 324042
Sonork: 100.1578276
Thanks Meter: 3,504
thanks n advance..
Replace this resistor.
The Following User Says Thank You to mehedi.h.j For This Useful Post:
1112 local mode plz help rahat ali Nokia Hardware & Hardware Repair 12 07-10-2011 16:18
Nokia 1112 Local mode arorasatishkuma Nokia Hardware & Hardware Repair 17 09-21-2010 03:51
1112 local mode rahat ali Nokia Hardware & Hardware Repair 7 09-18-2010 21:29
1112 local mode Adityaram Nokia Hardware & Hardware Repair 0 04-28-2008 08:51
1112 local mode zeerik Nokia Hardware & Hardware Repair 8 09-03-2007 12:17
Page generated in 0.12902 seconds with 9 queries
