11-26-2008, 18:18 | #1 (permalink) |
Junior Member Join Date: Jan 2007
Member: 433524 Status: Offline Thanks Meter: 2 | 1112 china |
The Following User Says Thank You to azmatali441 For This Useful Post: |
03-04-2009, 08:14 | #4 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: B.DESH (narayangonj) Age: 39
Member: 648428 Status: Offline Thanks Meter: 846 | Quote:
Hi, infinity can solve chinese 1112 problem jast here is the log, after format if you see bad software then use repair bad software option simple.. COM7 [VCP0] selected module v2.68 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:E63D:000C boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 230400 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: TOP23_07A_PCB01_GPRS_MT6223P_S00.N1112_V5_53.BIN ver. sw 2: N1112_V5.53, 00000000 ffs offset/size: 00700000/00100000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00700000 flash: EC257E25062501:2AEA0000000000 checking area [00000000]: 00000000-007FFFFF... eeprom/ffs found near: 00700000 detecting eeprom/ffs size... eeprom/ffs size: 00100000 ffs chip: 00 eeprom/ffs area: 00000000:00700000-007FFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[TOP23_07A_PCB01_GPRS_MT6223P_S00.N1112_V5_53.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[TOP23_07A_PCB01_GPRS_MT6223P_S00.N1112_V5_53.BIN]_20081109-124251.B0E.bin flash: EC257E25062501:2AEA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done write ... write Done Finalization ... formatting... flash: EC257E25062501:2AEA0000000000 Finalization Done Finished, time used: 94 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! COM7 [VCP0] selected module v2.68 Action: repair "bad software" Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:E63D:000C Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E04 Date: 2000.00.00 Version: 1.0 Version: N1112_V5.53 Version: detecting structure #2... 0Done 44 byte(s) read imei: 35935300337233 connection Ok detecting structure #6 (mode-1)... 0Done 181 byte(s) read writing data... verification... verification Ok Finished, time used: 13 sec Remove/Install battery now ! ENJOY & POST RESULT | |
1112 china set no light help me orignol 1112 and china 1112 diffrent | shani72 | Chinese Models & Cloned Phones | 0 | 07-05-2009 03:09 |
needed pins outs 1112 china | multi_mobile | Infinity-Box | 6 | 12-18-2008 19:56 |
How to modify nokia 1100 cable for 1112 china | zeerik | Infinity-Box | 1 | 11-29-2008 15:20 |
need flash 1112 china | anis19 | Infinity-Box | 5 | 11-11-2008 19:49 |
