1112 rh-93 key '3' not working hi all. rh-93 key 3 not working. i have try to clean the PCB b4,,, dont tell me to change the IC keypad to fix this prob. i need scematic for 1112 keypad ways i'v allready use the search button b4 write this thread,, and i did not found any scematic for 1112/1110 keypad. REGARD |
hallooooo,,,,, only key 3 can not work. the others is fine. can you help me please? |
change the key paid ic |
r u resold keypad IC or change keypad IC no any other solution is here |
i think if this ic problm,,,,, is not just '3' (three) key in trobl... i means if ic is broke........... key 1,2,3 and soft key or 3,6,9,# must be in troble too. am i wrong? |
i do flashing with some version, , , , , , prob still same,, can not fix by software i think UPP is damage any way, thank for suggestion |
1 Attachment(s) Quote:
rehot this IC which is in white area 100% solution |
can not fix the problm REGARDS |
for sure keypad ic malfulction..... try to replace it.... |
Thank for all. REGARD |
