1112contact service 1112 felt in water after clean & dry & pwr on contact service after ui setting same prob with flasch erasing error at 10 0*10000000...... i use UFS any help i'hve removed C2000 R2000 &R2205 same prob |
change ic cpu ........ |
plz flash with mt box maybe your problem is slove ok |
bro erase flash and flash it a good and latest flashfile your problem is solved...use jaf box......... |
B.r. Sunil. |
Sir the flash IC is glued not possible chnge or haet |
boss try flash by using griffin box i think your problem will solve |
Re-flash with latest version of MT-Box then do the Patch Sim.I have well done before. |
I think your set is water damage mainly this problem creates due to moisture or water lagged,first clean with iso prop alcohol then flash with latest ver.Also write good PM file.If same problem just simply **** UEm carefully. |
solve with local mode problem it ok 10000000000000000000000% |
jaff is the best box for that problem.. flash it with mcu,ppm and cnt. |
solution for u Quote:
hi if u r using ufs there is easyest solution just flash it with 1110 rh70 ver 3.42 all ur problem will be solved i have tried on atleast 18phones try it... REGARDS MAIMOON MOBILES |
Rehot the Flash IC using Flux and then fullflash it on JAF may be ur problem can solved. |
hi to all my 1600 cs problem after flashing set was dead in ufs showing like this any slution please help 1st Boot Ok, DCT4, UPP: 2201 2nd Boot Error: 4 Platform: 3, Error Data: B3 72 72 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Process Failed, Repowering Mobile thanks shaan |
