*************************************** Connecting to : 59.148.208.118 Welcome to ATF SX4 Server v1.40 >> Connection accepted MCU: V 10.60 10-06-10 RM-635 (c) Nokia IMEI: 354860049274722 Model : Nokia 2690 Product Serial Number: 0F432E7AI Product Code : 0592107 Module Code : 0204458 Basic Production Code: 0589255 Default SN Type : 0 MCU SW Version : V 10.60 10-06-10 RM-635 (c) Nokia UAB BT MCM Version : 2.31-SP2.26 PPM Version : V 10.60 10-06-10 RM-635 (c) Nokia HW Version : 3000 RFIC Version : 06560601 DSP Version : ICPR72_10w06 LCD Version : SUEZ Content Pack Version : Content: uab_black V 10.60 10-06-10 RM-635 (c) Nokia AHNE Version : 30 Retu Version : 16 Tahvo Version : 22 ******** Reading SimLock ******** CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : FAILED > Try SX4 "PM AUTH" > Then Write PM 1 and 309 SECURITY_CODE : 12345 PHONE_MODE : TEST MODE ================================================ Dynamic Camera Configuration ================================================ DCC ID : NI00IIIIRR0301022E05 DCC Ver: 003002 Status : OK Read challenge key from phone Step 1 Step 2 PM AUTH SUCCESSFUL Selected PM File: C:\AdvanceBox Turbo Flasher\Nokia\PM Files\SX4\354860049274722_0-400_11812.pm Start Uploading PM... Field : 1 Sub : 0 Byte(s): 12 - Ok Field : 1 Sub : 1 Byte(s): 72 - Ok Field : 1 Sub : 2 Byte(s): 72 - Ok Field : 1 Sub : 3 Byte(s): 72 - Ok Field : 1 Sub : 4 Byte(s): 72 - Ok Field : 1 Sub : 5 Byte(s): 276 - Ok Field : 1 Sub : 6 Byte(s): 276 - Ok Field : 1 Sub : 7 Byte(s): 276 - Ok Field : 1 Sub : 8 Byte(s): 276 - Ok Field : 1 Sub : 9 Byte(s): 384 - Ok Field : 1 Sub : 10 Byte(s): 384 - Ok Field : 1 Sub : 11 Byte(s): 384 - Ok Field : 1 Sub : 12 Byte(s): 384 - Ok Field : 1 Sub : 13 Byte(s): 384 - Ok Field : 1 Sub : 14 Byte(s): 384 - Ok Field : 1 Sub : 15 Byte(s): 384 - Ok Field : 1 Sub : 16 Byte(s): 384 - Ok Field : 1 Sub : 17 Byte(s): 32 - Ok Field : 1 Sub : 19 Byte(s): 16 - Ok Field : 2 Sub : 0 Byte(s): 440 - Ok Field : 4 Sub : 1 Byte(s): 800 - Ok Field : 4 Sub : 3 Byte(s): 12 - Ok Field : 4 Sub : 4 Byte(s): 8 - Ok Field : 4 Sub : 5 Byte(s): 8 - Ok Field : 4 Sub : 6 Byte(s): 8 - Ok Field : 4 Sub : 9 Byte(s): 8 - Ok Field : 4 Sub : 18 Byte(s): 80 - Ok Field : 4 Sub : 19 Byte(s): 4 - Ok Field : 4 Sub : 28 Byte(s): 4 - Ok Field : 8 Sub : 0 Byte(s): 4 - Ok Field : 8 Sub : 1 Byte(s): 16 - Ok Field : 8 Sub : 2 Byte(s): 16 - Ok Field : 8 Sub : 3 Byte(s): 128 - Ok Field : 8 Sub : 4 Byte(s): 128 - Ok Field : 8 Sub : 8 Byte(s): 8 - Ok Field : 8 Sub : 9 Byte(s): 8 - Ok Field : 8 Sub : 10 Byte(s): 24 - Ok Field : 11 Sub : 0 Byte(s): 4 - Ok Field : 11 Sub : 1 Byte(s): 4 - Ok Field : 11 Sub : 2 Byte(s): 4 - Ok Field : 11 Sub : 3 Byte(s): 4 - Ok Field : 11 Sub : 4 Byte(s): 4 - Ok Field : 11 Sub : 5 Byte(s): 8 - Ok Field : 11 Sub : 6 Byte(s): 4 - Ok Field : 11 Sub : 7 Byte(s): 4 - Ok Field : 11 Sub : 8 Byte(s): 4 - Ok Field : 11 Sub : 9 Byte(s): 4 - Ok Field : 11 Sub : 10 Byte(s): 4 - Ok Field : 11 Sub : 11 Byte(s): 4 - Ok Field : 11 Sub : 12 Byte(s): 4 - Ok Field : 11 Sub : 13 Byte(s): 4 - Ok Field : 11 Sub : 14 Byte(s): 4 - Ok Field : 11 Sub : 15 Byte(s): 4 - Ok Field : 11 Sub : 16 Byte(s): 4 - Ok Field : 11 Sub : 17 Byte(s): 4 - Ok Field : 11 Sub : 18 Byte(s): 16 - Ok Field : 11 Sub : 19 Byte(s): 32 - Ok Field : 11 Sub : 20 Byte(s): 32 - Ok Field : 11 Sub : 21 Byte(s): 4 - Ok Field : 11 Sub : 22 Byte(s): 4 - Ok Field : 11 Sub : 23 Byte(s): 4 - Ok Field : 11 Sub : 24 Byte(s): 4 - Ok Field : 11 Sub : 25 Byte(s): 4 - Ok Field : 11 Sub : 26 Byte(s): 4 - Ok Field : 11 Sub : 27 Byte(s): 4 - Ok Field : 11 Sub : 28 Byte(s): 4 - Ok Field : 11 Sub : 29 Byte(s): 4 - Ok Field : 11 Sub : 30 Byte(s): 4 - Ok Field : 11 Sub : 31 Byte(s): 4 - Ok Field : 11 Sub : 32 Byte(s): 4 - Ok Field : 11 Sub : 33 Byte(s): 4 - Ok Field : 11 Sub : 34 Byte(s): 4 - Ok Field : 11 Sub : 35 Byte(s): 4 - Ok Field : 11 Sub : 36 Byte(s): 4 - Ok Field : 11 Sub : 37 Byte(s): 4 - Ok Field : 11 Sub : 38 Byte(s): 4 - Ok Field : 11 Sub : 39 Byte(s): 4 - Ok Field : 11 Sub : 40 Byte(s): 4 - Ok Field : 11 Sub : 41 Byte(s): 4 - Ok Field : 11 Sub : 42 Byte(s): 4 - Ok Field : 11 Sub : 43 Byte(s): 4 - Ok Field : 11 Sub : 44 Byte(s): 4 - Ok Field : 11 Sub : 45 Byte(s): 4 - Ok Field : 11 Sub : 46 Byte(s): 4 - Ok Field : 11 Sub : 47 Byte(s): 4 - Ok Field : 11 Sub : 48 Byte(s): 4 - Ok Field : 11 Sub : 49 Byte(s): 4 - Ok Field : 11 Sub : 50 Byte(s): 4 - Ok Field : 11 Sub : 51 Byte(s): 4 - Ok Field : 11 Sub : 52 Byte(s): 4 - Ok Field : 11 Sub : 53 Byte(s): 4 - Ok Field : 11 Sub : 54 Byte(s): 4 - Ok Field : 11 Sub : 55 Byte(s): 4 - Ok Field : 11 Sub : 56 Byte(s): 4 - Ok Field : 11 Sub : 57 Byte(s): 4 - Ok Field : 11 Sub : 58 Byte(s): 4 - Ok Field : 11 Sub : 59 Byte(s): 4 - Ok Field : 11 Sub : 60 Byte(s): 4 - Ok Field : 11 Sub : 61 Byte(s): 4 - Ok Field : 11 Sub : 62 Byte(s): 4 - Ok Field : 11 Sub : 63 Byte(s): 4 - Ok Field : 11 Sub : 64 Byte(s): 4 - Ok Field : 11 Sub : 65 Byte(s): 4 - Ok Field : 11 Sub : 66 Byte(s): 4 - Ok Field : 11 Sub : 67 Byte(s): 4 - Ok Field : 11 Sub : 68 Byte(s): 4 - Ok Field : 11 Sub : 69 Byte(s): 4 - Ok Field : 11 Sub : 70 Byte(s): 4 - Ok Field : 11 Sub : 71 Byte(s): 4 - Ok Field : 11 Sub : 72 Byte(s): 16 - Ok Field : 11 Sub : 73 Byte(s): 4 - Ok Field : 11 Sub : 74 Byte(s): 4 - Ok Field : 11 Sub : 75 Byte(s): 16 - Ok Field : 12 Sub : 0 Byte(s): 104 - Ok Field : 13 Sub : 0 Byte(s): 4 - Ok Field : 13 Sub : 1 Byte(s): 4 - Ok Field : 13 Sub : 2 Byte(s): 4 - Ok Field : 13 Sub : 3 Byte(s): 4 - Ok Field : 13 Sub : 4 Byte(s): 4 - Ok Field : 13 Sub : 5 Byte(s): 4 - Ok Field : 13 Sub : 6 Byte(s): 4 - Ok Field : 13 Sub : 7 Byte(s): 4 - Ok Field : 13 Sub : 8 Byte(s): 4 - Ok Field : 13 Sub : 9 Byte(s): 4 - Ok Field : 13 Sub : 10 Byte(s): 4 - Ok Field : 13 Sub : 11 Byte(s): 48 - Ok Field : 13 Sub : 12 Byte(s): 4 - Ok Field : 13 Sub : 13 Byte(s): 4 - Ok Field : 13 Sub : 14 Byte(s): 4 - Ok Field : 13 Sub : 15 Byte(s): 888 - Ok Field : 13 Sub : 16 Byte(s): 4 - Ok Field : 13 Sub : 17 Byte(s): 4 - Ok Field : 13 Sub : 18 Byte(s): 4 - Ok Field : 13 Sub : 19 Byte(s): 8 - Ok Field : 13 Sub : 20 Byte(s): 4 - Ok Field : 13 Sub : 21 Byte(s): 4 - Ok Field : 13 Sub : 22 Byte(s): 4 - Ok Field : 13 Sub : 23 Byte(s): 4 - Ok Field : 13 Sub : 24 Byte(s): 4 - Ok Field : 13 Sub : 25 Byte(s): 4 - Ok Field : 13 Sub : 26 Byte(s): 4 - Ok Field : 13 Sub : 27 Byte(s): 4 - Ok Field : 13 Sub : 28 Byte(s): 4 - Ok Field : 13 Sub : 29 Byte(s): 4 - Ok Field : 13 Sub : 30 Byte(s): 4 - Ok Field : 13 Sub : 31 Byte(s): 4 - Ok Field : 13 Sub : 32 Byte(s): 4 - Ok Field : 13 Sub : 33 Byte(s): 4 - Ok Field : 13 Sub : 34 Byte(s): 4 - Ok Field : 13 Sub : 35 Byte(s): 4 - Ok Field : 13 Sub : 36 Byte(s): 4 - Ok Field : 13 Sub : 37 Byte(s): 4 - Ok Field : 13 Sub : 38 Byte(s): 4 - Ok Field : 13 Sub : 39 Byte(s): 4 - Ok Field : 13 Sub : 40 Byte(s): 4 - Ok Field : 13 Sub : 41 Byte(s): 4 - Ok Field : 13 Sub : 42 Byte(s): 4 - Ok Field : 13 Sub : 43 Byte(s): 4 - Ok Field : 13 Sub : 44 Byte(s): 4 - Ok Field : 13 Sub : 45 Byte(s): 4 - Ok Field : 13 Sub : 46 Byte(s): 4 - Ok Field : 13 Sub : 47 Byte(s): 4 - Ok Field : 13 Sub : 48 Byte(s): 4 - Ok Field : 13 Sub : 49 Byte(s): 4 - Ok Field : 13 Sub : 50 Byte(s): 4 - Ok Field : 13 Sub : 51 Byte(s): 4 - Ok Field : 13 Sub : 52 Byte(s): 4 - Ok Field : 13 Sub : 53 Byte(s): 4 - Ok Field : 13 Sub : 54 Byte(s): 4 - Ok Field : 13 Sub : 55 Byte(s): 4 - Ok Field : 13 Sub : 56 Byte(s): 4 - Ok Field : 13 Sub : 57 Byte(s): 4 - Ok Field : 13 Sub : 58 Byte(s): 4 - Ok Field : 13 Sub : 59 Byte(s): 4 - Ok Field : 13 Sub : 60 Byte(s): 4 - Ok Field : 13 Sub : 61 Byte(s): 4 - Ok Field : 13 Sub : 62 Byte(s): 4 - Ok Field : 13 Sub : 63 Byte(s): 4 - Ok Field : 13 Sub : 64 Byte(s): 4 - Ok Field : 13 Sub : 65 Byte(s): 4 - Ok Field : 13 Sub : 66 Byte(s): 4 - Ok Field : 13 Sub : 67 Byte(s): 4 - Ok Field : 13 Sub : 68 Byte(s): 4 - Ok Field : 13 Sub : 69 Byte(s): 4 - Ok Field : 13 Sub : 70 Byte(s): 4 - Ok Field : 13 Sub : 71 Byte(s): 4 - Ok Field : 13 Sub : 72 Byte(s): 4 - Ok Field : 13 Sub : 73 Byte(s): 4 - Ok Field : 13 Sub : 74 Byte(s): 4 - Ok Field : 13 Sub : 75 Byte(s): 4 - Ok Field : 13 Sub : 76 Byte(s): 4 - Ok Field : 13 Sub : 77 Byte(s): 4 - Ok Field : 13 Sub : 78 Byte(s): 4 - Ok Field : 13 Sub : 79 Byte(s): 4 - Ok Field : 13 Sub : 80 Byte(s): 4 - Ok Field : 13 Sub : 81 Byte(s): 4 - Ok Field : 13 Sub : 82 Byte(s): 4 - Ok Field : 13 Sub : 83 Byte(s): 4 - Ok Field : 13 Sub : 84 Byte(s): 4 - Ok Field : 13 Sub : 85 Byte(s): 4 - Ok Field : 13 Sub : 86 Byte(s): 4 - Ok Field : 13 Sub : 87 Byte(s): 4 - Ok Field : 13 Sub : 88 Byte(s): 4 - Ok Field : 13 Sub : 89 Byte(s): 4 - Ok Field : 13 Sub : 90 Byte(s): 4 - Ok Field : 13 Sub : 91 Byte(s): 4 - Ok Field : 13 Sub : 92 Byte(s): 4 - Ok Field : 13 Sub : 93 Byte(s): 4 - Ok Field : 13 Sub : 94 Byte(s): 4 - Ok Field : 13 Sub : 95 Byte(s): 4 - Ok Field : 13 Sub : 96 Byte(s): 4 - Ok Field : 13 Sub : 97 Byte(s): 4 - Ok Field : 13 Sub : 98 Byte(s): 4 - Ok Field : 13 Sub : 99 Byte(s): 4 - Ok Field : 13 Sub : 100 Byte(s): 4 - Ok Field : 13 Sub : 101 Byte(s): 4 - Ok Field : 13 Sub : 102 Byte(s): 4 - Ok Field : 13 Sub : 103 Byte(s): 4 - Ok Field : 13 Sub : 104 Byte(s): 4 - Ok Field : 13 Sub : 105 Byte(s): 4 - Ok Field : 13 Sub : 106 Byte(s): 4 - Ok Field : 13 Sub : 107 Byte(s): 4 - Ok Field : 13 Sub : 108 Byte(s): 4 - Ok Field : 13 Sub : 109 Byte(s): 4 - Ok Field : 13 Sub : 110 Byte(s): 4 - Ok Field : 13 Sub : 111 Byte(s): 4 - Ok Field : 13 Sub : 112 Byte(s): 4 - Ok Field : 13 Sub : 113 Byte(s): 4 - Ok Field : 13 Sub : 114 Byte(s): 4 - Ok Field : 13 Sub : 115 Byte(s): 4 - Ok Field : 13 Sub : 116 Byte(s): 4 - Ok Field : 13 Sub : 117 Byte(s): 4 - Ok Field : 13 Sub : 118 Byte(s): 4 - Ok Field : 13 Sub : 119 Byte(s): 4 - Ok Field : 13 Sub : 120 Byte(s): 4 - Ok Field : 13 Sub : 121 Byte(s): 4 - Ok Field : 13 Sub : 122 Byte(s): 4 - Ok Field : 13 Sub : 123 Byte(s): 8 - Ok Field : 13 Sub : 124 Byte(s): 4 - Ok Field : 13 Sub : 125 Byte(s): 4 - Ok Field : 13 Sub : 126 Byte(s): 4 - Ok Field : 13 Sub : 127 Byte(s): 4 - Ok Field : 13 Sub : 128 Byte(s): 4 - Ok Field : 13 Sub : 129 Byte(s): 4 - Ok Field : 13 Sub : 130 Byte(s): 4 - Ok Field : 13 Sub : 131 Byte(s): 4 - Ok Field : 13 Sub : 132 Byte(s): 4 - Ok Field : 13 Sub : 133 Byte(s): 4 - Ok Field : 13 Sub : 134 Byte(s): 4 - Ok Field : 13 Sub : 135 Byte(s): 4 - Ok Field : 13 Sub : 136 Byte(s): 4 - Ok Field : 13 Sub : 137 Byte(s): 4 - Ok Field : 13 Sub : 138 Byte(s): 4 - Ok Field : 13 Sub : 139 Byte(s): 4 - Ok Field : 13 Sub : 140 Byte(s): 4 - Ok Field : 13 Sub : 141 Byte(s): 4 - Ok Field : 13 Sub : 142 Byte(s): 4 - Ok Field : 13 Sub : 143 Byte(s): 4 - Ok Field : 13 Sub : 144 Byte(s): 4 - Ok Field : 13 Sub : 145 Byte(s): 8 - Ok Field : 13 Sub : 146 Byte(s): 4 - Ok Field : 13 Sub : 147 Byte(s): 4 - Ok Field : 13 Sub : 148 Byte(s): 4 - Ok Field : 13 Sub : 149 Byte(s): 4 - Ok Field : 13 Sub : 150 Byte(s): 4 - Ok Field : 13 Sub : 151 Byte(s): 4 - Ok Field : 13 Sub : 152 Byte(s): 4 - Ok Field : 13 Sub : 153 Byte(s): 4 - Ok Field : 13 Sub : 154 Byte(s): 4 - Ok Field : 13 Sub : 155 Byte(s): 4 - Ok Field : 13 Sub : 156 Byte(s): 4 - Ok Field : 13 Sub : 157 Byte(s): 4 - Ok Field : 13 Sub : 158 Byte(s): 4 - Ok Field : 13 Sub : 159 Byte(s): 4 - Ok Field : 13 Sub : 160 Byte(s): 4 - Ok Field : 13 Sub : 161 Byte(s): 4 - Ok Field : 13 Sub : 162 Byte(s): 4 - Ok Field : 13 Sub : 163 Byte(s): 4 - Ok Field : 13 Sub : 164 Byte(s): 4 - Ok Field : 13 Sub : 165 Byte(s): 4 - Ok Field : 13 Sub : 166 Byte(s): 4 - Ok Field : 13 Sub : 167 Byte(s): 8 - Ok Field : 13 Sub : 168 Byte(s): 4 - Ok Field : 13 Sub : 169 Byte(s): 4 - Ok Field : 13 Sub : 170 Byte(s): 4 - Ok Field : 13 Sub : 171 Byte(s): 4 - Ok Field : 13 Sub : 172 Byte(s): 4 - Ok Field : 13 Sub : 173 Byte(s): 4 - Ok Field : 13 Sub : 174 Byte(s): 4 - Ok Field : 13 Sub : 175 Byte(s): 4 - Ok Field : 13 Sub : 176 Byte(s): 4 - Ok Field : 13 Sub : 177 Byte(s): 4 - Ok Field : 13 Sub : 178 Byte(s): 4 - Ok Field : 13 Sub : 179 Byte(s): 4 - Ok Field : 13 Sub : 180 Byte(s): 4 - Ok Field : 13 Sub : 181 Byte(s): 4 - Ok Field : 13 Sub : 182 Byte(s): 4 - Ok Field : 13 Sub : 183 Byte(s): 4 - Ok Field : 13 Sub : 184 Byte(s): 4 - Ok Field : 13 Sub : 185 Byte(s): 4 - Ok Field : 13 Sub : 186 Byte(s): 4 - Ok Field : 13 Sub : 187 Byte(s): 4 - Ok Field : 13 Sub : 188 Byte(s): 4 - Ok Field : 13 Sub : 189 Byte(s): 4 - Ok Field : 13 Sub : 190 Byte(s): 4 - Ok Field : 13 Sub : 191 Byte(s): 4 - Ok Field : 13 Sub : 192 Byte(s): 4 - Ok Field : 13 Sub : 193 Byte(s): 4 - Ok Field : 13 Sub : 194 Byte(s): 4 - Ok Field : 13 Sub : 195 Byte(s): 4 - Ok Field : 13 Sub : 196 Byte(s): 12 - Ok Field : 31 Sub : 4 Byte(s): 16 - Ok Field : 42 Sub : 0 Byte(s): 4 - Ok Field : 42 Sub : 1 Byte(s): 12 - Ok Field : 42 Sub : 2 Byte(s): 36 - Ok Field : 42 Sub : 3 Byte(s): 36 - Ok Field : 42 Sub : 4 Byte(s): 36 - Ok Field : 42 Sub : 5 Byte(s): 36 - Ok Field : 42 Sub : 6 Byte(s): 36 - Ok Field : 42 Sub : 7 Byte(s): 40 - Ok Field : 42 Sub : 8 Byte(s): 40 - Ok Field : 42 Sub : 9 Byte(s): 40 - Ok Field : 42 Sub : 10 Byte(s): 40 - Ok Field : 42 Sub : 11 Byte(s): 40 - Ok Field : 42 Sub : 12 Byte(s): 40 - Ok Field : 42 Sub : 13 Byte(s): 40 - Ok Field : 42 Sub : 14 Byte(s): 40 - Ok Field : 42 Sub : 15 Byte(s): 40 - Ok Field : 42 Sub : 16 Byte(s): 40 - Ok Field : 42 Sub : 17 Byte(s): 40 - Ok Field : 42 Sub : 18 Byte(s): 40 - Ok Field : 42 Sub : 19 Byte(s): 40 - Ok Field : 42 Sub : 20 Byte(s): 40 - Ok Field : 42 Sub : 21 Byte(s): 40 - Ok Field : 42 Sub : 22 Byte(s): 40 - Ok Field : 42 Sub : 23 Byte(s): 40 - Ok Field : 42 Sub : 24 Byte(s): 40 - Ok Field : 42 Sub : 25 Byte(s): 40 - Ok Field : 42 Sub : 26 Byte(s): 40 - Ok Field : 50 Sub : 0 Byte(s): 4 - Ok Field : 54 Sub : 0 Byte(s): 4 - Ok Field : 66 Sub : 0 Byte(s): 484 - Ok Field : 66 Sub : 1 Byte(s): 240 - Ok Field : 66 Sub : 2 Byte(s): 240 - Ok Field : 66 Sub : 3 Byte(s): 4 - Ok Field : 66 Sub : 4 Byte(s): 4 - Ok Field : 66 Sub : 5 Byte(s): 240 - Ok Field : 66 Sub : 6 Byte(s): 4 - Ok Field : 66 Sub : 7 Byte(s): 4 - Ok Field : 66 Sub : 8 Byte(s): 4 - Ok Field : 66 Sub : 9 Byte(s): 4 - Ok Field : 66 Sub : 10 Byte(s): 240 - Ok Field : 66 Sub : 11 Byte(s): 240 - Ok Field : 66 Sub : 12 Byte(s): 4 - Ok Field : 66 Sub : 16 Byte(s): 4 - Ok Field : 66 Sub : 18 Byte(s): 4 - Ok Field : 66 Sub : 20 Byte(s): 4 - Ok Field : 66 Sub : 22 Byte(s): 4 - Ok Field : 66 Sub : 24 Byte(s): 4 - Ok Field : 66 Sub : 26 Byte(s): 4 - Ok Field : 66 Sub : 28 Byte(s): 4 - Ok Field : 66 Sub : 30 Byte(s): 4 - Ok Field : 66 Sub : 32 Byte(s): 4 - Ok Field : 66 Sub : 54 Byte(s): 8 - Ok Field : 66 Sub : 55 Byte(s): 8 - Ok Field : 66 Sub : 56 Byte(s): 8 - Ok Field : 66 Sub : 57 Byte(s): 8 - Ok Field : 66 Sub : 58 Byte(s): 8 - Ok Field : 66 Sub : 59 Byte(s): 8 - Ok Field : 66 Sub : 60 Byte(s): 8 - Ok Field : 66 Sub : 61 Byte(s): 8 - Ok Field : 66 Sub : 62 Byte(s): 8 - Ok Field : 66 Sub : 63 Byte(s): 8 - Ok Field : 66 Sub : 64 Byte(s): 8 - Ok Field : 66 Sub : 65 Byte(s): 8 - Ok Field : 66 Sub : 66 Byte(s): 8 - Ok Field : 66 Sub : 67 Byte(s): 8 - Ok Field : 66 Sub : 68 Byte(s): 8 - Ok Field : 66 Sub : 69 Byte(s): 8 - Ok Field : 66 Sub : 71 Byte(s): 8 - Ok Field : 66 Sub : 72 Byte(s): 8 - Ok Field : 66 Sub : 73 Byte(s): 24016 - Ok Field : 66 Sub : 74 Byte(s): 6144 - Ok Field : 66 Sub : 75 Byte(s): 300 - Ok Field : 66 Sub : 76 Byte(s): 60 - Ok Field : 66 Sub : 79 Byte(s): 60000 - Skipped Field : 66 Sub : 81 Byte(s): 4 - Ok Field : 66 Sub : 82 Byte(s): 4 - Ok Field : 66 Sub : 83 Byte(s): 4 - Ok Field : 66 Sub : 85 Byte(s): 4 - Ok Field : 66 Sub : 86 Byte(s): 4 - Ok Field : 66 Sub : 87 Byte(s): 4 - Ok Field : 66 Sub : 89 Byte(s): 4 - Ok Field : 66 Sub : 94 Byte(s): 8 - Ok Field : 66 Sub : 97 Byte(s): 4 - Ok Field : 66 Sub : 98 Byte(s): 4 - Ok Field : 66 Sub : 99 Byte(s): 4 - Ok Field : 66 Sub : 100 Byte(s): 4 - Ok Field : 66 Sub : 101 Byte(s): 4 - Ok Field : 66 Sub : 102 Byte(s): 8 - Ok Field : 66 Sub : 104 Byte(s): 4 - Ok Field : 66 Sub : 111 Byte(s): 120 - Ok Field : 66 Sub : 112 Byte(s): 4 - Ok Field : 66 Sub : 114 Byte(s): 32 - Ok Field : 66 Sub : 115 Byte(s): 4 - Ok Field : 66 Sub : 116 Byte(s): 20 - Ok Field : 66 Sub : 118 Byte(s): 8 - Ok Field : 66 Sub : 119 Byte(s): 8 - Ok Field : 66 Sub : 120 Byte(s): 8 - Ok Field : 66 Sub : 122 Byte(s): 8 - Ok Field : 88 Sub : 0 Byte(s): 36 - Ok Field : 96 Sub : 0 Byte(s): 4 - Ok Field : 96 Sub : 1 Byte(s): 20 - Ok Field : 107 Sub : 0 Byte(s): 24 - Ok Field : 107 Sub : 1 Byte(s): 92 - Ok Field : 107 Sub : 2 Byte(s): 72 - Ok Field : 107 Sub : 3 Byte(s): 72 - Ok Field : 107 Sub : 25 Byte(s): 132 - Ok Field : 107 Sub : 26 Byte(s): 12 - Ok Field : 116 Sub : 0 Byte(s): 4 - Ok Field : 116 Sub : 1 Byte(s): 12 - Ok Field : 116 Sub : 2 Byte(s): 36 - Ok Field : 116 Sub : 3 Byte(s): 36 - Ok Field : 116 Sub : 4 Byte(s): 36 - Ok Field : 116 Sub : 5 Byte(s): 36 - Ok Field : 116 Sub : 6 Byte(s): 36 - Ok Field : 116 Sub : 7 Byte(s): 40 - Ok Field : 116 Sub : 8 Byte(s): 40 - Ok Field : 116 Sub : 9 Byte(s): 40 - Ok Field : 116 Sub : 10 Byte(s): 40 - Ok Field : 116 Sub : 11 Byte(s): 40 - Ok Field : 116 Sub : 12 Byte(s): 40 - Ok Field : 116 Sub : 13 Byte(s): 40 - Ok Field : 116 Sub : 14 Byte(s): 40 - Ok Field : 116 Sub : 15 Byte(s): 40 - Ok Field : 116 Sub : 16 Byte(s): 40 - Ok Field : 117 Sub : 0 Byte(s): 4 - Ok Field : 117 Sub : 1 Byte(s): 4 - Ok Field : 117 Sub : 2 Byte(s): 8 - Ok Field : 117 Sub : 3 Byte(s): 4 - Ok Field : 117 Sub : 5 Byte(s): 12 - Ok Field : 117 Sub : 6 Byte(s): 8 - Ok Field : 117 Sub : 13 Byte(s): 4 - Ok Field : 117 Sub : 14 Byte(s): 4 - Ok Field : 117 Sub : 16 Byte(s): 40 - Ok Field : 120 Sub : 0 Byte(s): 944 - Ok Field : 120 Sub : 1 Byte(s): 160 - Ok Field : 120 Sub : 2 Byte(s): 132 - Ok Field : 120 Sub : 3 Byte(s): 112 - Ok Field : 153 Sub : 0 Byte(s): 68 - Ok Field : 153 Sub : 1 Byte(s): 68 - Ok Field : 153 Sub : 2 Byte(s): 68 - Ok Field : 153 Sub : 3 Byte(s): 68 - Ok Field : 153 Sub : 4 Byte(s): 68 - Ok Field : 153 Sub : 5 Byte(s): 68 - Ok Field : 193 Sub : 2 Byte(s): 8 - Ok Field : 193 Sub : 3 Byte(s): 32 - Ok Field : 193 Sub : 4 Byte(s): 32 - Ok Field : 193 Sub : 9 Byte(s): 64 - Ok Field : 217 Sub : 0 Byte(s): 32 - Ok Field : 218 Sub : 0 Byte(s): 4 - Ok Field : 238 Sub : 1 Byte(s): 4 - Ok Field : 239 Sub : 0 Byte(s): 4 - Ok Field : 239 Sub : 1 Byte(s): 3060 - Ok Field : 301 Sub : 0 Byte(s): 4 - Ok Field : 301 Sub : 1 Byte(s): 12 - Ok Field : 301 Sub : 2 Byte(s): 36 - Ok Field : 301 Sub : 3 Byte(s): 36 - Ok Field : 301 Sub : 4 Byte(s): 36 - Ok Field : 301 Sub : 5 Byte(s): 36 - Ok Field : 301 Sub : 6 Byte(s): 36 - Ok Field : 301 Sub : 7 Byte(s): 40 - Ok Field : 301 Sub : 8 Byte(s): 40 - Ok Field : 301 Sub : 9 Byte(s): 40 - Ok Field : 301 Sub : 10 Byte(s): 40 - Ok Field : 301 Sub : 11 Byte(s): 40 - Ok Field : 301 Sub : 12 Byte(s): 40 - Ok Field : 301 Sub : 13 Byte(s): 40 - Ok Field : 301 Sub : 14 Byte(s): 40 - Ok Field : 301 Sub : 15 Byte(s): 40 - Ok Field : 301 Sub : 16 Byte(s): 40 - Ok Field : 308 Sub : 0 Byte(s): 4 - Failed Field : 308 Sub : 1 Byte(s): 8192 - Failed Field : 308 Sub : 2 Byte(s): 4 - Failed Field : 308 Sub : 3 Byte(s): 4 - Failed Field : 308 Sub : 4 Byte(s): 4 - Failed Field : 308 Sub : 5 Byte(s): 12 - Failed Field : 308 Sub : 6 Byte(s): 4 - Failed Field : 308 Sub : 7 Byte(s): 4 - Failed Field : 308 Sub : 8 Byte(s): 4 - Failed Field : 308 Sub : 9 Byte(s): 40 - Failed Field : 309 Sub : 1 Byte(s): 4 - Ok Field : 309 Sub : 2 Byte(s): 12 - Ok Field : 309 Sub : 4 Byte(s): 12 - Ok Field : 309 Sub : 5 Byte(s): 12 - Ok Field : 309 Sub : 7 Byte(s): 12 - Ok Field : 309 Sub : 8 Byte(s): 12 - Ok Field : 309 Sub : 17 Byte(s): 12 - Ok Field : 309 Sub : 22 Byte(s): 12 - Ok Field : 322 Sub : 0 Byte(s): 4 - Ok Field : 334 Sub : 0 Byte(s): 4 - Ok Field : 339 Sub : 0 Byte(s): 512 - Ok Field : 339 Sub : 1 Byte(s): 512 - Ok Field : 341 Sub : 0 Byte(s): 4 - Ok Field : 341 Sub : 3 Byte(s): 4 - Ok Field : 341 Sub : 4 Byte(s): 4392 - Ok Field : 345 Sub : 0 Byte(s): 12 - Ok Field : 354 Sub : 0 Byte(s): 4 - Ok Field : 355 Sub : 1 Byte(s): 1432 - Ok Field : 356 Sub : 0 Byte(s): 4 - Ok Field : 362 Sub : 0 Byte(s): 4 - Ok Field : 362 Sub : 1 Byte(s): 120 - Ok PM Upload Done!... MCU: V 10.60 10-06-10 RM-635 (c) Nokia IMEI: 354860049274722 Model : Nokia 2690 Product Serial Number: 0F432E7AI Product Code : 0592107 Module Code : 0204458 Basic Production Code: 0589255 Default SN Type : 0 MCU SW Version : V 10.60 10-06-10 RM-635 (c) Nokia UAB BT MCM Version : 2.31-SP2.26 PPM Version : V 10.60 10-06-10 RM-635 (c) Nokia HW Version : 3000 RFIC Version : 06560601 DSP Version : ICPR72_10w06 LCD Version : SUEZ Content Pack Version : Content: uab_black V 10.60 10-06-10 RM-635 (c) Nokia AHNE Version : 30 Retu Version : 16 Tahvo Version : 22 ******** Reading SimLock ******** CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST MODE ================================================ Dynamic Camera Configuration ================================================ DCC ID : NI00IIIIRR0301022E05 DCC Ver: 003002 Status : OK |
nokia 2690 contact service solution |
nokia 2690 contact service solution *************************************** Connecting to : 59.148.208.118 Welcome to ATF SX4 Server v1.40 >> Connection accepted MCU: V 10.60 10-06-10 RM-635 (c) Nokia IMEI: 354860049274722 Model : Nokia 2690 Product Serial Number: 0F432E7AI Product Code : 0592107 Module Code : 0204458 Basic Production Code: 0589255 Default SN Type : 0 MCU SW Version : V 10.60 10-06-10 RM-635 (c) Nokia UAB BT MCM Version : 2.31-SP2.26 PPM Version : V 10.60 10-06-10 RM-635 (c) Nokia HW Version : 3000 RFIC Version : 06560601 DSP Version : ICPR72_10w06 LCD Version : SUEZ Content Pack Version : Content: uab_black V 10.60 10-06-10 RM-635 (c) Nokia AHNE Version : 30 Retu Version : 16 Tahvo Version : 22 ******** Reading SimLock ******** CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : FAILED > Try SX4 "PM AUTH" > Then Write PM 1 and 309 SECURITY_CODE : 12345 PHONE_MODE : TEST MODE ================================================ Dynamic Camera Configuration ================================================ DCC ID : NI00IIIIRR0301022E05 DCC Ver: 003002 Status : OK Read challenge key from phone Step 1 Step 2 PM AUTH SUCCESSFUL Selected PM File: C:\AdvanceBox Turbo Flasher\Nokia\PM Files\SX4\354860049274722_0-400_11812.pm Start Uploading PM... Field : 1 Sub : 0 Byte(s): 12 - Ok Field : 1 Sub : 1 Byte(s): 72 - Ok Field : 1 Sub : 2 Byte(s): 72 - Ok Field : 1 Sub : 3 Byte(s): 72 - Ok Field : 1 Sub : 4 Byte(s): 72 - Ok Field : 1 Sub : 5 Byte(s): 276 - Ok Field : 1 Sub : 6 Byte(s): 276 - Ok Field : 1 Sub : 7 Byte(s): 276 - Ok Field : 1 Sub : 8 Byte(s): 276 - Ok Field : 1 Sub : 9 Byte(s): 384 - Ok Field : 1 Sub : 10 Byte(s): 384 - Ok Field : 1 Sub : 11 Byte(s): 384 - Ok Field : 1 Sub : 12 Byte(s): 384 - Ok Field : 1 Sub : 13 Byte(s): 384 - Ok Field : 1 Sub : 14 Byte(s): 384 - Ok Field : 1 Sub : 15 Byte(s): 384 - Ok Field : 1 Sub : 16 Byte(s): 384 - Ok Field : 1 Sub : 17 Byte(s): 32 - Ok Field : 1 Sub : 19 Byte(s): 16 - Ok Field : 2 Sub : 0 Byte(s): 440 - Ok Field : 4 Sub : 1 Byte(s): 800 - Ok Field : 4 Sub : 3 Byte(s): 12 - Ok Field : 4 Sub : 4 Byte(s): 8 - Ok Field : 4 Sub : 5 Byte(s): 8 - Ok Field : 4 Sub : 6 Byte(s): 8 - Ok Field : 4 Sub : 9 Byte(s): 8 - Ok Field : 4 Sub : 18 Byte(s): 80 - Ok Field : 4 Sub : 19 Byte(s): 4 - Ok Field : 4 Sub : 28 Byte(s): 4 - Ok Field : 8 Sub : 0 Byte(s): 4 - Ok Field : 8 Sub : 1 Byte(s): 16 - Ok Field : 8 Sub : 2 Byte(s): 16 - Ok Field : 8 Sub : 3 Byte(s): 128 - Ok Field : 8 Sub : 4 Byte(s): 128 - Ok Field : 8 Sub : 8 Byte(s): 8 - Ok Field : 8 Sub : 9 Byte(s): 8 - Ok Field : 8 Sub : 10 Byte(s): 24 - Ok Field : 11 Sub : 0 Byte(s): 4 - Ok Field : 11 Sub : 1 Byte(s): 4 - Ok Field : 11 Sub : 2 Byte(s): 4 - Ok Field : 11 Sub : 3 Byte(s): 4 - Ok Field : 11 Sub : 4 Byte(s): 4 - Ok Field : 11 Sub : 5 Byte(s): 8 - Ok Field : 11 Sub : 6 Byte(s): 4 - Ok Field : 11 Sub : 7 Byte(s): 4 - Ok Field : 11 Sub : 8 Byte(s): 4 - Ok Field : 11 Sub : 9 Byte(s): 4 - Ok Field : 11 Sub : 10 Byte(s): 4 - Ok Field : 11 Sub : 11 Byte(s): 4 - Ok Field : 11 Sub : 12 Byte(s): 4 - Ok Field : 11 Sub : 13 Byte(s): 4 - Ok Field : 11 Sub : 14 Byte(s): 4 - Ok Field : 11 Sub : 15 Byte(s): 4 - Ok Field : 11 Sub : 16 Byte(s): 4 - Ok Field : 11 Sub : 17 Byte(s): 4 - Ok Field : 11 Sub : 18 Byte(s): 16 - Ok Field : 11 Sub : 19 Byte(s): 32 - Ok Field : 11 Sub : 20 Byte(s): 32 - Ok Field : 11 Sub : 21 Byte(s): 4 - Ok Field : 11 Sub : 22 Byte(s): 4 - Ok Field : 11 Sub : 23 Byte(s): 4 - Ok Field : 11 Sub : 24 Byte(s): 4 - Ok Field : 11 Sub : 25 Byte(s): 4 - Ok Field : 11 Sub : 26 Byte(s): 4 - Ok Field : 11 Sub : 27 Byte(s): 4 - Ok Field : 11 Sub : 28 Byte(s): 4 - Ok Field : 11 Sub : 29 Byte(s): 4 - Ok Field : 11 Sub : 30 Byte(s): 4 - Ok Field : 11 Sub : 31 Byte(s): 4 - Ok Field : 11 Sub : 32 Byte(s): 4 - Ok Field : 11 Sub : 33 Byte(s): 4 - Ok Field : 11 Sub : 34 Byte(s): 4 - Ok Field : 11 Sub : 35 Byte(s): 4 - Ok Field : 11 Sub : 36 Byte(s): 4 - Ok Field : 11 Sub : 37 Byte(s): 4 - Ok Field : 11 Sub : 38 Byte(s): 4 - Ok Field : 11 Sub : 39 Byte(s): 4 - Ok Field : 11 Sub : 40 Byte(s): 4 - Ok Field : 11 Sub : 41 Byte(s): 4 - Ok Field : 11 Sub : 42 Byte(s): 4 - Ok Field : 11 Sub : 43 Byte(s): 4 - Ok Field : 11 Sub : 44 Byte(s): 4 - Ok Field : 11 Sub : 45 Byte(s): 4 - Ok Field : 11 Sub : 46 Byte(s): 4 - Ok Field : 11 Sub : 47 Byte(s): 4 - Ok Field : 11 Sub : 48 Byte(s): 4 - Ok Field : 11 Sub : 49 Byte(s): 4 - Ok Field : 11 Sub : 50 Byte(s): 4 - Ok Field : 11 Sub : 51 Byte(s): 4 - Ok Field : 11 Sub : 52 Byte(s): 4 - Ok Field : 11 Sub : 53 Byte(s): 4 - Ok Field : 11 Sub : 54 Byte(s): 4 - Ok Field : 11 Sub : 55 Byte(s): 4 - Ok Field : 11 Sub : 56 Byte(s): 4 - Ok Field : 11 Sub : 57 Byte(s): 4 - Ok Field : 11 Sub : 58 Byte(s): 4 - Ok Field : 11 Sub : 59 Byte(s): 4 - Ok Field : 11 Sub : 60 Byte(s): 4 - Ok Field : 11 Sub : 61 Byte(s): 4 - Ok Field : 11 Sub : 62 Byte(s): 4 - Ok Field : 11 Sub : 63 Byte(s): 4 - Ok Field : 11 Sub : 64 Byte(s): 4 - Ok Field : 11 Sub : 65 Byte(s): 4 - Ok Field : 11 Sub : 66 Byte(s): 4 - Ok Field : 11 Sub : 67 Byte(s): 4 - Ok Field : 11 Sub : 68 Byte(s): 4 - Ok Field : 11 Sub : 69 Byte(s): 4 - Ok Field : 11 Sub : 70 Byte(s): 4 - Ok Field : 11 Sub : 71 Byte(s): 4 - Ok Field : 11 Sub : 72 Byte(s): 16 - Ok Field : 11 Sub : 73 Byte(s): 4 - Ok Field : 11 Sub : 74 Byte(s): 4 - Ok Field : 11 Sub : 75 Byte(s): 16 - Ok Field : 12 Sub : 0 Byte(s): 104 - Ok Field : 13 Sub : 0 Byte(s): 4 - Ok Field : 13 Sub : 1 Byte(s): 4 - Ok Field : 13 Sub : 2 Byte(s): 4 - Ok Field : 13 Sub : 3 Byte(s): 4 - Ok Field : 13 Sub : 4 Byte(s): 4 - Ok Field : 13 Sub : 5 Byte(s): 4 - Ok Field : 13 Sub : 6 Byte(s): 4 - Ok Field : 13 Sub : 7 Byte(s): 4 - Ok Field : 13 Sub : 8 Byte(s): 4 - Ok Field : 13 Sub : 9 Byte(s): 4 - Ok Field : 13 Sub : 10 Byte(s): 4 - Ok Field : 13 Sub : 11 Byte(s): 48 - Ok Field : 13 Sub : 12 Byte(s): 4 - Ok Field : 13 Sub : 13 Byte(s): 4 - Ok Field : 13 Sub : 14 Byte(s): 4 - Ok Field : 13 Sub : 15 Byte(s): 888 - Ok Field : 13 Sub : 16 Byte(s): 4 - Ok Field : 13 Sub : 17 Byte(s): 4 - Ok Field : 13 Sub : 18 Byte(s): 4 - Ok Field : 13 Sub : 19 Byte(s): 8 - Ok Field : 13 Sub : 20 Byte(s): 4 - Ok Field : 13 Sub : 21 Byte(s): 4 - Ok Field : 13 Sub : 22 Byte(s): 4 - Ok Field : 13 Sub : 23 Byte(s): 4 - Ok Field : 13 Sub : 24 Byte(s): 4 - Ok Field : 13 Sub : 25 Byte(s): 4 - Ok Field : 13 Sub : 26 Byte(s): 4 - Ok Field : 13 Sub : 27 Byte(s): 4 - Ok Field : 13 Sub : 28 Byte(s): 4 - Ok Field : 13 Sub : 29 Byte(s): 4 - Ok Field : 13 Sub : 30 Byte(s): 4 - Ok Field : 13 Sub : 31 Byte(s): 4 - Ok Field : 13 Sub : 32 Byte(s): 4 - Ok Field : 13 Sub : 33 Byte(s): 4 - Ok Field : 13 Sub : 34 Byte(s): 4 - Ok Field : 13 Sub : 35 Byte(s): 4 - Ok Field : 13 Sub : 36 Byte(s): 4 - Ok Field : 13 Sub : 37 Byte(s): 4 - Ok Field : 13 Sub : 38 Byte(s): 4 - Ok Field : 13 Sub : 39 Byte(s): 4 - Ok Field : 13 Sub : 40 Byte(s): 4 - Ok Field : 13 Sub : 41 Byte(s): 4 - Ok Field : 13 Sub : 42 Byte(s): 4 - Ok Field : 13 Sub : 43 Byte(s): 4 - Ok Field : 13 Sub : 44 Byte(s): 4 - Ok Field : 13 Sub : 45 Byte(s): 4 - Ok Field : 13 Sub : 46 Byte(s): 4 - Ok Field : 13 Sub : 47 Byte(s): 4 - Ok Field : 13 Sub : 48 Byte(s): 4 - Ok Field : 13 Sub : 49 Byte(s): 4 - Ok Field : 13 Sub : 50 Byte(s): 4 - Ok Field : 13 Sub : 51 Byte(s): 4 - Ok Field : 13 Sub : 52 Byte(s): 4 - Ok Field : 13 Sub : 53 Byte(s): 4 - Ok Field : 13 Sub : 54 Byte(s): 4 - Ok Field : 13 Sub : 55 Byte(s): 4 - Ok Field : 13 Sub : 56 Byte(s): 4 - Ok Field : 13 Sub : 57 Byte(s): 4 - Ok Field : 13 Sub : 58 Byte(s): 4 - Ok Field : 13 Sub : 59 Byte(s): 4 - Ok Field : 13 Sub : 60 Byte(s): 4 - Ok Field : 13 Sub : 61 Byte(s): 4 - Ok Field : 13 Sub : 62 Byte(s): 4 - Ok Field : 13 Sub : 63 Byte(s): 4 - Ok Field : 13 Sub : 64 Byte(s): 4 - Ok Field : 13 Sub : 65 Byte(s): 4 - Ok Field : 13 Sub : 66 Byte(s): 4 - Ok Field : 13 Sub : 67 Byte(s): 4 - Ok Field : 13 Sub : 68 Byte(s): 4 - Ok Field : 13 Sub : 69 Byte(s): 4 - Ok Field : 13 Sub : 70 Byte(s): 4 - Ok Field : 13 Sub : 71 Byte(s): 4 - Ok Field : 13 Sub : 72 Byte(s): 4 - Ok Field : 13 Sub : 73 Byte(s): 4 - Ok Field : 13 Sub : 74 Byte(s): 4 - Ok Field : 13 Sub : 75 Byte(s): 4 - Ok Field : 13 Sub : 76 Byte(s): 4 - Ok Field : 13 Sub : 77 Byte(s): 4 - Ok Field : 13 Sub : 78 Byte(s): 4 - Ok Field : 13 Sub : 79 Byte(s): 4 - Ok Field : 13 Sub : 80 Byte(s): 4 - Ok Field : 13 Sub : 81 Byte(s): 4 - Ok Field : 13 Sub : 82 Byte(s): 4 - Ok Field : 13 Sub : 83 Byte(s): 4 - Ok Field : 13 Sub : 84 Byte(s): 4 - Ok Field : 13 Sub : 85 Byte(s): 4 - Ok Field : 13 Sub : 86 Byte(s): 4 - Ok Field : 13 Sub : 87 Byte(s): 4 - Ok Field : 13 Sub : 88 Byte(s): 4 - Ok Field : 13 Sub : 89 Byte(s): 4 - Ok Field : 13 Sub : 90 Byte(s): 4 - Ok Field : 13 Sub : 91 Byte(s): 4 - Ok Field : 13 Sub : 92 Byte(s): 4 - Ok Field : 13 Sub : 93 Byte(s): 4 - Ok Field : 13 Sub : 94 Byte(s): 4 - Ok Field : 13 Sub : 95 Byte(s): 4 - Ok Field : 13 Sub : 96 Byte(s): 4 - Ok Field : 13 Sub : 97 Byte(s): 4 - Ok Field : 13 Sub : 98 Byte(s): 4 - Ok Field : 13 Sub : 99 Byte(s): 4 - Ok Field : 13 Sub : 100 Byte(s): 4 - Ok Field : 13 Sub : 101 Byte(s): 4 - Ok Field : 13 Sub : 102 Byte(s): 4 - Ok Field : 13 Sub : 103 Byte(s): 4 - Ok Field : 13 Sub : 104 Byte(s): 4 - Ok Field : 13 Sub : 105 Byte(s): 4 - Ok Field : 13 Sub : 106 Byte(s): 4 - Ok Field : 13 Sub : 107 Byte(s): 4 - Ok Field : 13 Sub : 108 Byte(s): 4 - Ok Field : 13 Sub : 109 Byte(s): 4 - Ok Field : 13 Sub : 110 Byte(s): 4 - Ok Field : 13 Sub : 111 Byte(s): 4 - Ok Field : 13 Sub : 112 Byte(s): 4 - Ok Field : 13 Sub : 113 Byte(s): 4 - Ok Field : 13 Sub : 114 Byte(s): 4 - Ok Field : 13 Sub : 115 Byte(s): 4 - Ok Field : 13 Sub : 116 Byte(s): 4 - Ok Field : 13 Sub : 117 Byte(s): 4 - Ok Field : 13 Sub : 118 Byte(s): 4 - Ok Field : 13 Sub : 119 Byte(s): 4 - Ok Field : 13 Sub : 120 Byte(s): 4 - Ok Field : 13 Sub : 121 Byte(s): 4 - Ok Field : 13 Sub : 122 Byte(s): 4 - Ok Field : 13 Sub : 123 Byte(s): 8 - Ok Field : 13 Sub : 124 Byte(s): 4 - Ok Field : 13 Sub : 125 Byte(s): 4 - Ok Field : 13 Sub : 126 Byte(s): 4 - Ok Field : 13 Sub : 127 Byte(s): 4 - Ok Field : 13 Sub : 128 Byte(s): 4 - Ok Field : 13 Sub : 129 Byte(s): 4 - Ok Field : 13 Sub : 130 Byte(s): 4 - Ok Field : 13 Sub : 131 Byte(s): 4 - Ok Field : 13 Sub : 132 Byte(s): 4 - Ok Field : 13 Sub : 133 Byte(s): 4 - Ok Field : 13 Sub : 134 Byte(s): 4 - Ok Field : 13 Sub : 135 Byte(s): 4 - Ok Field : 13 Sub : 136 Byte(s): 4 - Ok Field : 13 Sub : 137 Byte(s): 4 - Ok Field : 13 Sub : 138 Byte(s): 4 - Ok Field : 13 Sub : 139 Byte(s): 4 - Ok Field : 13 Sub : 140 Byte(s): 4 - Ok Field : 13 Sub : 141 Byte(s): 4 - Ok Field : 13 Sub : 142 Byte(s): 4 - Ok Field : 13 Sub : 143 Byte(s): 4 - Ok Field : 13 Sub : 144 Byte(s): 4 - Ok Field : 13 Sub : 145 Byte(s): 8 - Ok Field : 13 Sub : 146 Byte(s): 4 - Ok Field : 13 Sub : 147 Byte(s): 4 - Ok Field : 13 Sub : 148 Byte(s): 4 - Ok Field : 13 Sub : 149 Byte(s): 4 - Ok Field : 13 Sub : 150 Byte(s): 4 - Ok Field : 13 Sub : 151 Byte(s): 4 - Ok Field : 13 Sub : 152 Byte(s): 4 - Ok Field : 13 Sub : 153 Byte(s): 4 - Ok Field : 13 Sub : 154 Byte(s): 4 - Ok Field : 13 Sub : 155 Byte(s): 4 - Ok Field : 13 Sub : 156 Byte(s): 4 - Ok Field : 13 Sub : 157 Byte(s): 4 - Ok Field : 13 Sub : 158 Byte(s): 4 - Ok Field : 13 Sub : 159 Byte(s): 4 - Ok Field : 13 Sub : 160 Byte(s): 4 - Ok Field : 13 Sub : 161 Byte(s): 4 - Ok Field : 13 Sub : 162 Byte(s): 4 - Ok Field : 13 Sub : 163 Byte(s): 4 - Ok Field : 13 Sub : 164 Byte(s): 4 - Ok Field : 13 Sub : 165 Byte(s): 4 - Ok Field : 13 Sub : 166 Byte(s): 4 - Ok Field : 13 Sub : 167 Byte(s): 8 - Ok Field : 13 Sub : 168 Byte(s): 4 - Ok Field : 13 Sub : 169 Byte(s): 4 - Ok Field : 13 Sub : 170 Byte(s): 4 - Ok Field : 13 Sub : 171 Byte(s): 4 - Ok Field : 13 Sub : 172 Byte(s): 4 - Ok Field : 13 Sub : 173 Byte(s): 4 - Ok Field : 13 Sub : 174 Byte(s): 4 - Ok Field : 13 Sub : 175 Byte(s): 4 - Ok Field : 13 Sub : 176 Byte(s): 4 - Ok Field : 13 Sub : 177 Byte(s): 4 - Ok Field : 13 Sub : 178 Byte(s): 4 - Ok Field : 13 Sub : 179 Byte(s): 4 - Ok Field : 13 Sub : 180 Byte(s): 4 - Ok Field : 13 Sub : 181 Byte(s): 4 - Ok Field : 13 Sub : 182 Byte(s): 4 - Ok Field : 13 Sub : 183 Byte(s): 4 - Ok Field : 13 Sub : 184 Byte(s): 4 - Ok Field : 13 Sub : 185 Byte(s): 4 - Ok Field : 13 Sub : 186 Byte(s): 4 - Ok Field : 13 Sub : 187 Byte(s): 4 - Ok Field : 13 Sub : 188 Byte(s): 4 - Ok Field : 13 Sub : 189 Byte(s): 4 - Ok Field : 13 Sub : 190 Byte(s): 4 - Ok Field : 13 Sub : 191 Byte(s): 4 - Ok Field : 13 Sub : 192 Byte(s): 4 - Ok Field : 13 Sub : 193 Byte(s): 4 - Ok Field : 13 Sub : 194 Byte(s): 4 - Ok Field : 13 Sub : 195 Byte(s): 4 - Ok Field : 13 Sub : 196 Byte(s): 12 - Ok Field : 31 Sub : 4 Byte(s): 16 - Ok Field : 42 Sub : 0 Byte(s): 4 - Ok Field : 42 Sub : 1 Byte(s): 12 - Ok Field : 42 Sub : 2 Byte(s): 36 - Ok Field : 42 Sub : 3 Byte(s): 36 - Ok Field : 42 Sub : 4 Byte(s): 36 - Ok Field : 42 Sub : 5 Byte(s): 36 - Ok Field : 42 Sub : 6 Byte(s): 36 - Ok Field : 42 Sub : 7 Byte(s): 40 - Ok Field : 42 Sub : 8 Byte(s): 40 - Ok Field : 42 Sub : 9 Byte(s): 40 - Ok Field : 42 Sub : 10 Byte(s): 40 - Ok Field : 42 Sub : 11 Byte(s): 40 - Ok Field : 42 Sub : 12 Byte(s): 40 - Ok Field : 42 Sub : 13 Byte(s): 40 - Ok Field : 42 Sub : 14 Byte(s): 40 - Ok Field : 42 Sub : 15 Byte(s): 40 - Ok Field : 42 Sub : 16 Byte(s): 40 - Ok Field : 42 Sub : 17 Byte(s): 40 - Ok Field : 42 Sub : 18 Byte(s): 40 - Ok Field : 42 Sub : 19 Byte(s): 40 - Ok Field : 42 Sub : 20 Byte(s): 40 - Ok Field : 42 Sub : 21 Byte(s): 40 - Ok Field : 42 Sub : 22 Byte(s): 40 - Ok Field : 42 Sub : 23 Byte(s): 40 - Ok Field : 42 Sub : 24 Byte(s): 40 - Ok Field : 42 Sub : 25 Byte(s): 40 - Ok Field : 42 Sub : 26 Byte(s): 40 - Ok Field : 50 Sub : 0 Byte(s): 4 - Ok Field : 54 Sub : 0 Byte(s): 4 - Ok Field : 66 Sub : 0 Byte(s): 484 - Ok Field : 66 Sub : 1 Byte(s): 240 - Ok Field : 66 Sub : 2 Byte(s): 240 - Ok Field : 66 Sub : 3 Byte(s): 4 - Ok Field : 66 Sub : 4 Byte(s): 4 - Ok Field : 66 Sub : 5 Byte(s): 240 - Ok Field : 66 Sub : 6 Byte(s): 4 - Ok Field : 66 Sub : 7 Byte(s): 4 - Ok Field : 66 Sub : 8 Byte(s): 4 - Ok Field : 66 Sub : 9 Byte(s): 4 - Ok Field : 66 Sub : 10 Byte(s): 240 - Ok Field : 66 Sub : 11 Byte(s): 240 - Ok Field : 66 Sub : 12 Byte(s): 4 - Ok Field : 66 Sub : 16 Byte(s): 4 - Ok Field : 66 Sub : 18 Byte(s): 4 - Ok Field : 66 Sub : 20 Byte(s): 4 - Ok Field : 66 Sub : 22 Byte(s): 4 - Ok Field : 66 Sub : 24 Byte(s): 4 - Ok Field : 66 Sub : 26 Byte(s): 4 - Ok Field : 66 Sub : 28 Byte(s): 4 - Ok Field : 66 Sub : 30 Byte(s): 4 - Ok Field : 66 Sub : 32 Byte(s): 4 - Ok Field : 66 Sub : 54 Byte(s): 8 - Ok Field : 66 Sub : 55 Byte(s): 8 - Ok Field : 66 Sub : 56 Byte(s): 8 - Ok Field : 66 Sub : 57 Byte(s): 8 - Ok Field : 66 Sub : 58 Byte(s): 8 - Ok Field : 66 Sub : 59 Byte(s): 8 - Ok Field : 66 Sub : 60 Byte(s): 8 - Ok Field : 66 Sub : 61 Byte(s): 8 - Ok Field : 66 Sub : 62 Byte(s): 8 - Ok Field : 66 Sub : 63 Byte(s): 8 - Ok Field : 66 Sub : 64 Byte(s): 8 - Ok Field : 66 Sub : 65 Byte(s): 8 - Ok Field : 66 Sub : 66 Byte(s): 8 - Ok Field : 66 Sub : 67 Byte(s): 8 - Ok Field : 66 Sub : 68 Byte(s): 8 - Ok Field : 66 Sub : 69 Byte(s): 8 - Ok Field : 66 Sub : 71 Byte(s): 8 - Ok Field : 66 Sub : 72 Byte(s): 8 - Ok Field : 66 Sub : 73 Byte(s): 24016 - Ok Field : 66 Sub : 74 Byte(s): 6144 - Ok Field : 66 Sub : 75 Byte(s): 300 - Ok Field : 66 Sub : 76 Byte(s): 60 - Ok Field : 66 Sub : 79 Byte(s): 60000 - Skipped Field : 66 Sub : 81 Byte(s): 4 - Ok Field : 66 Sub : 82 Byte(s): 4 - Ok Field : 66 Sub : 83 Byte(s): 4 - Ok Field : 66 Sub : 85 Byte(s): 4 - Ok Field : 66 Sub : 86 Byte(s): 4 - Ok Field : 66 Sub : 87 Byte(s): 4 - Ok Field : 66 Sub : 89 Byte(s): 4 - Ok Field : 66 Sub : 94 Byte(s): 8 - Ok Field : 66 Sub : 97 Byte(s): 4 - Ok Field : 66 Sub : 98 Byte(s): 4 - Ok Field : 66 Sub : 99 Byte(s): 4 - Ok Field : 66 Sub : 100 Byte(s): 4 - Ok Field : 66 Sub : 101 Byte(s): 4 - Ok Field : 66 Sub : 102 Byte(s): 8 - Ok Field : 66 Sub : 104 Byte(s): 4 - Ok Field : 66 Sub : 111 Byte(s): 120 - Ok Field : 66 Sub : 112 Byte(s): 4 - Ok Field : 66 Sub : 114 Byte(s): 32 - Ok Field : 66 Sub : 115 Byte(s): 4 - Ok Field : 66 Sub : 116 Byte(s): 20 - Ok Field : 66 Sub : 118 Byte(s): 8 - Ok Field : 66 Sub : 119 Byte(s): 8 - Ok Field : 66 Sub : 120 Byte(s): 8 - Ok Field : 66 Sub : 122 Byte(s): 8 - Ok Field : 88 Sub : 0 Byte(s): 36 - Ok Field : 96 Sub : 0 Byte(s): 4 - Ok Field : 96 Sub : 1 Byte(s): 20 - Ok Field : 107 Sub : 0 Byte(s): 24 - Ok Field : 107 Sub : 1 Byte(s): 92 - Ok Field : 107 Sub : 2 Byte(s): 72 - Ok Field : 107 Sub : 3 Byte(s): 72 - Ok Field : 107 Sub : 25 Byte(s): 132 - Ok Field : 107 Sub : 26 Byte(s): 12 - Ok Field : 116 Sub : 0 Byte(s): 4 - Ok Field : 116 Sub : 1 Byte(s): 12 - Ok Field : 116 Sub : 2 Byte(s): 36 - Ok Field : 116 Sub : 3 Byte(s): 36 - Ok Field : 116 Sub : 4 Byte(s): 36 - Ok Field : 116 Sub : 5 Byte(s): 36 - Ok Field : 116 Sub : 6 Byte(s): 36 - Ok Field : 116 Sub : 7 Byte(s): 40 - Ok Field : 116 Sub : 8 Byte(s): 40 - Ok Field : 116 Sub : 9 Byte(s): 40 - Ok Field : 116 Sub : 10 Byte(s): 40 - Ok Field : 116 Sub : 11 Byte(s): 40 - Ok Field : 116 Sub : 12 Byte(s): 40 - Ok Field : 116 Sub : 13 Byte(s): 40 - Ok Field : 116 Sub : 14 Byte(s): 40 - Ok Field : 116 Sub : 15 Byte(s): 40 - Ok Field : 116 Sub : 16 Byte(s): 40 - Ok Field : 117 Sub : 0 Byte(s): 4 - Ok Field : 117 Sub : 1 Byte(s): 4 - Ok Field : 117 Sub : 2 Byte(s): 8 - Ok Field : 117 Sub : 3 Byte(s): 4 - Ok Field : 117 Sub : 5 Byte(s): 12 - Ok Field : 117 Sub : 6 Byte(s): 8 - Ok Field : 117 Sub : 13 Byte(s): 4 - Ok Field : 117 Sub : 14 Byte(s): 4 - Ok Field : 117 Sub : 16 Byte(s): 40 - Ok Field : 120 Sub : 0 Byte(s): 944 - Ok Field : 120 Sub : 1 Byte(s): 160 - Ok Field : 120 Sub : 2 Byte(s): 132 - Ok Field : 120 Sub : 3 Byte(s): 112 - Ok Field : 153 Sub : 0 Byte(s): 68 - Ok Field : 153 Sub : 1 Byte(s): 68 - Ok Field : 153 Sub : 2 Byte(s): 68 - Ok Field : 153 Sub : 3 Byte(s): 68 - Ok Field : 153 Sub : 4 Byte(s): 68 - Ok Field : 153 Sub : 5 Byte(s): 68 - Ok Field : 193 Sub : 2 Byte(s): 8 - Ok Field : 193 Sub : 3 Byte(s): 32 - Ok Field : 193 Sub : 4 Byte(s): 32 - Ok Field : 193 Sub : 9 Byte(s): 64 - Ok Field : 217 Sub : 0 Byte(s): 32 - Ok Field : 218 Sub : 0 Byte(s): 4 - Ok Field : 238 Sub : 1 Byte(s): 4 - Ok Field : 239 Sub : 0 Byte(s): 4 - Ok Field : 239 Sub : 1 Byte(s): 3060 - Ok Field : 301 Sub : 0 Byte(s): 4 - Ok Field : 301 Sub : 1 Byte(s): 12 - Ok Field : 301 Sub : 2 Byte(s): 36 - Ok Field : 301 Sub : 3 Byte(s): 36 - Ok Field : 301 Sub : 4 Byte(s): 36 - Ok Field : 301 Sub : 5 Byte(s): 36 - Ok Field : 301 Sub : 6 Byte(s): 36 - Ok Field : 301 Sub : 7 Byte(s): 40 - Ok Field : 301 Sub : 8 Byte(s): 40 - Ok Field : 301 Sub : 9 Byte(s): 40 - Ok Field : 301 Sub : 10 Byte(s): 40 - Ok Field : 301 Sub : 11 Byte(s): 40 - Ok Field : 301 Sub : 12 Byte(s): 40 - Ok Field : 301 Sub : 13 Byte(s): 40 - Ok Field : 301 Sub : 14 Byte(s): 40 - Ok Field : 301 Sub : 15 Byte(s): 40 - Ok Field : 301 Sub : 16 Byte(s): 40 - Ok Field : 308 Sub : 0 Byte(s): 4 - Failed Field : 308 Sub : 1 Byte(s): 8192 - Failed Field : 308 Sub : 2 Byte(s): 4 - Failed Field : 308 Sub : 3 Byte(s): 4 - Failed Field : 308 Sub : 4 Byte(s): 4 - Failed Field : 308 Sub : 5 Byte(s): 12 - Failed Field : 308 Sub : 6 Byte(s): 4 - Failed Field : 308 Sub : 7 Byte(s): 4 - Failed Field : 308 Sub : 8 Byte(s): 4 - Failed Field : 308 Sub : 9 Byte(s): 40 - Failed Field : 309 Sub : 1 Byte(s): 4 - Ok Field : 309 Sub : 2 Byte(s): 12 - Ok Field : 309 Sub : 4 Byte(s): 12 - Ok Field : 309 Sub : 5 Byte(s): 12 - Ok Field : 309 Sub : 7 Byte(s): 12 - Ok Field : 309 Sub : 8 Byte(s): 12 - Ok Field : 309 Sub : 17 Byte(s): 12 - Ok Field : 309 Sub : 22 Byte(s): 12 - Ok Field : 322 Sub : 0 Byte(s): 4 - Ok Field : 334 Sub : 0 Byte(s): 4 - Ok Field : 339 Sub : 0 Byte(s): 512 - Ok Field : 339 Sub : 1 Byte(s): 512 - Ok Field : 341 Sub : 0 Byte(s): 4 - Ok Field : 341 Sub : 3 Byte(s): 4 - Ok Field : 341 Sub : 4 Byte(s): 4392 - Ok Field : 345 Sub : 0 Byte(s): 12 - Ok Field : 354 Sub : 0 Byte(s): 4 - Ok Field : 355 Sub : 1 Byte(s): 1432 - Ok Field : 356 Sub : 0 Byte(s): 4 - Ok Field : 362 Sub : 0 Byte(s): 4 - Ok Field : 362 Sub : 1 Byte(s): 120 - Ok PM Upload Done!... MCU: V 10.60 10-06-10 RM-635 (c) Nokia IMEI: 354860049274722 Model : Nokia 2690 Product Serial Number: 0F432E7AI Product Code : 0592107 Module Code : 0204458 Basic Production Code: 0589255 Default SN Type : 0 MCU SW Version : V 10.60 10-06-10 RM-635 (c) Nokia UAB BT MCM Version : 2.31-SP2.26 PPM Version : V 10.60 10-06-10 RM-635 (c) Nokia HW Version : 3000 RFIC Version : 06560601 DSP Version : ICPR72_10w06 LCD Version : SUEZ Content Pack Version : Content: uab_black V 10.60 10-06-10 RM-635 (c) Nokia AHNE Version : 30 Retu Version : 16 Tahvo Version : 22 ******** Reading SimLock ******** CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST MODE ================================================ Dynamic Camera Configuration ================================================ DCC ID : NI00IIIIRR0301022E05 DCC Ver: 003002 Status : OK contact service solution |
nokia every mobile sim solution same solution...:)) |
thanks........................ |
sir muje mx box ko intiletion karna battai na plz |
