03-26-2010, 16:17 | #1 (permalink) |
No Life Poster Join Date: May 2008
Member: 774169 Status: Offline Thanks Meter: 123 | 1200 / 1208 dead . i have 1200 and some 1208 which are dead . board is very fresh . whenever i short bsi line with ground and set switches on but says not charging when charger is inserted . to some of then i tried doing flashing but that too fails in middle resulting complete death of the unit . any having tested solution pls post waiting regards [email protected] |
The Following User Says Thank You to mukeshdurg For This Useful Post: |
03-26-2010, 16:41 | #2 (permalink) | ||
No Life Poster Join Date: Sep 2008 Location: Living with mobile phones
Member: 856803 Status: Offline Sonork: 100.1592550 Thanks Meter: 151 | Quote:
Quote: Try this solution,Hope it will help u Gud luck BR, ..::MOBILES::.. | ||
The Following 2 Users Say Thank You to ..::MOBILES::.. For This Useful Post: |
03-26-2010, 22:42 | #3 (permalink) | |
Registered User Join Date: Aug 2009
Member: 1087294 Status: Offline Thanks Meter: 252 | Quote:
post result | |
04-01-2010, 14:06 | #5 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 403881 Status: Offline Thanks Meter: 80 | Yes many set says following with JAF Getting MCU ID Phone didn't answer with TX line low after UEM reset! Causes: 1. put a 27-33 pico capacitor in connector b/w mbus-gnd. 2. UEM damaged -> replace uem. MCU ID: 0xDDDD Failed! Aborting! Done! Phone Restarted... Any one can suggest its solution? |
04-05-2011, 11:52 | #6 (permalink) |
Freak Poster Join Date: Mar 2009 Location: srilanka Age: 39
Member: 996647 Status: Offline Sonork: 100.1617492 Thanks Meter: 74 | Yes many set says following with JAF Getting MCU ID Phone didn't answer with TX line low after UEM reset! Causes: 1. put a 27-33 pico capacitor in connector b/w mbus-gnd. 2. UEM damaged -> replace uem. MCU ID: 0xDDDD Failed! Aborting! Done! Phone Restarted... |
04-05-2011, 11:53 | #7 (permalink) |
Member: 996647 Status: Offline Sonork: 100.1617492 Thanks Meter: 74 | Getting MCU ID Phone didn't answer with TX line low after UEM reset! Causes: 1. put a 27-33 pico capacitor in connector b/w mbus-gnd. 2. UEM damaged -> replace uem. MCU ID: 0xDDDD Failed! Aborting! Done! Phone Restarted... |
Play mp3 ring tones in nokia 1200,1208 | khanmobiles0003 | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 03-29-2010 18:50 |
1200 1208 dead soloution | imranieman | Nokia Hardware & Hardware Repair | 0 | 02-13-2009 16:42 |
new SOLUTION 2008 1208 1200 1650 DEAD | GSMONNITIN | Nokia Hardware & Hardware Repair | 26 | 12-12-2008 16:02 |
1200 1208 dead | vicky kumar | Nokia Hardware & Hardware Repair | 9 | 06-15-2008 10:34 |
