Old 10-02-2010, 16:59   #1 (permalink)
.RAM's Avatar
Member: 1017629
Thanks Meter: 73
1200 contect service help
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
ASIC ID: 0x2292 [UPPCosto ver: 1.3]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30
Performing Flash Authentication ...OK
UEM ID: 0043349BA3BDA66
ASIC type: 11
UEM Imei: 35984301919999
Phone Type: RH-99
SW Version: V 5.23 10-03-08 RH-99 (c) NMP
Imei plain: 35984301919999-1
Product Code: 0546960
Cellular System: GSM
ASIC ID: 0x2292, type: 11
Ppm Id: MG
Language Pack:
- not available.
Imei net: 35984301919999
Version: SIMLOCK SERVER
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 800000000001000B
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
Invalid UEM Data, No RPL backup will be made for this phone
The Following User Says Thank You to .RAM For This Useful Post:
Old 10-02-2010, 18:11   #2 (permalink)
guddu ahmad's Avatar
Member: 1345926
Sonork: 100.1671229
Thanks Meter: 176
ASIC type: 11
Phone Type: RH-99
Ppm Id: MG
Language Pack:
- not available.
Counter: 0/3, 0/10
wash bord 24 hours in alma & heating then softwear .softwear is ok but contact sarvic then remove ragistans .problem 100% solved
Old 10-02-2010, 18:18   #3 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
Thanks Meter: 11,976
brother re hot uem post result .
Old 10-02-2010, 20:06   #4 (permalink)
abdurrahimsagar's Avatar
Member: 734476
Sonork: 100.1604415
Thanks Meter: 2,485
re hot upp post result.......................
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:04
Winlock 1.10 - Help rdmfs Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 06-25-1999 08:21
Page generated in 0.18489 seconds with 9 queries
