08-25-2009, 03:25 | #1 (permalink) |
No Life Poster Join Date: Jun 2008 Location: Punjabi University India
Member: 788946 Status: Offline Sonork: 100.1682685 Thanks Meter: 502 | 1200 Contents Package Extracting Failed |
08-25-2009, 05:34 | #2 (permalink) |
No Life Poster Join Date: Mar 2009 Location: Basti, I N D I A Age: 34
Member: 988641 Status: Offline Sonork: sanjay chaudhary Thanks Meter: 342 | bro, rehot flash then try to software....................... |
The Following User Says Thank You to s.s.s.s. For This Useful Post: |
08-25-2009, 08:44 | #6 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: ludhiana~india Age: 38
Member: 163833 Status: Offline Sonork: 100.1579554 Thanks Meter: 5,700 | Quote:
first u can try with easy cable with hwk ... if then not solve u have to reball or then change flash ic..... | |
09-28-2010, 12:31 | #8 (permalink) |
Junior Member Join Date: Sep 2010
Member: 1403387 Status: Offline Sonork: [email protected] Thanks Meter: 0 | Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: FBFF FBFF FBFF FBFF FBFF FBFF FBFF FBFF Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0084F0B5A3BDA66 ASIC type: 11 UEM Imei: 35353302146539 Processing file: rh99_05.910 as MCU [DCT4,DCT4 ALGORITHM] size: 2.27 MB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: FBFF FBFF FBFF FBFF FBFF FBFF FBFF FBFF Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0084F0B5:2984DA60 Area [01000000-0100FFFF] erased in 1.110 s Area [01010000-013AFFFF] erased in 1 min 3.671 s Area [013B0000-013EFFFF] erased in 4.406 s Area [017C0000-017EFFFF] erased in 0.156 s Area [01FC0000-01FEFFFF] erased in 0.156 s Flash programming ... Programming completed in 16.953 s File Processed in 1 min 34.703 s Processing file: rh990_nai5.91mg as CNT [DCT4,DCT4 ALGORITHM] size: 151.96 KB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: A97E B21A 1BBE 0BE2 7958 6BE4 DBEE 6114 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0084F0B5:2984DA60 Area [01380000-013AFFFF] erased in 3.344 s Flash programming ... Programming completed in 1.250 s Content extract fail, continue anyway ... File Processed in 33.109 s Processing file: rh99_05.91mg as PPM [DCT4,DCT4 ALGORITHM] size: 989.20 KB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: A97E B21A 1BBE 0BE2 7958 6BE4 DBEE 6114 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0084F0B5:2984DA60 Area [01240000-0124FFFF] erased in 1.109 s Area [01250000-0137FFFF] erased in 20.969 s Flash programming ... Programming completed in 7.485 s File Processed in 39.985 s Flashing completed in 3 min 40.188 s plz help no for on the phone |
nokia 1200 Contents Package Extracting Failed: Process Failed, Repowering Mobile | romey_singh2 | HWK | 39 | 08-03-2017 13:04 |
Contents Package Extracting Failed | DonaldDuck69 | Twisterflasher | 32 | 08-06-2010 07:49 |
1200 Contents Package Extracting Failed | sr8787 | Nokia Hardware & Hardware Repair | 10 | 08-25-2009 03:23 |
1200 Contents Package Extracting Failed | sr8787 | Nokia Hardware & Hardware Repair | 1 | 08-20-2009 09:23 |
