03-03-2011, 10:13 | #1 (permalink) |
No Life Poster Join Date: Jan 2004 Age: 43
Member: 50643 Status: Offline Thanks Meter: 117 | 1200 no power on my phone 1200 fbus cable flashing ok , test mode not ok and battery no power on ( Fbus cable with Mbus pinout busy ) easy cable flashin ok, test mode ok, UI settings ok, normal mode ok, but battery no power on I changed UEM same problem changed CPU same problem change Xtal same problem battery connector was checked BSI lines was checked power on button and line was checked What is this error please help |
03-03-2011, 12:18 | #3 (permalink) |
Registered User Join Date: Dec 2009 Location: HABARADUWA - Sri Lanka Age: 39
Member: 1179630 Status: Offline Sonork: 100.1644820 Thanks Meter: 80 | Are you change UPP & UEM????? True Phone Still alive are you ginius I did them seperatly 2 phones Both Death and only one 3310 alive for 2 weeks ater change power IC |
03-04-2011, 11:37 | #5 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | ok , try to replace lcd connector on pwb , if same try to replace both lcd & flex then check. |
The Following User Says Thank You to .:SARCAR:. For This Useful Post: |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
