1202 battery put ..cannot on but i use power supply it can on....but i oso use power supply clip at bsi pin... |
can you tell the history of your phone ....................................... |
brother connect bsi with ground and try it on or flash your phone with out unlock it Br Asghar Hussain |
1202 1661 bsi line here |
yes bro check bsi line first |
i remove bsi resister,,now phone ok ...thanksss |
remove bsi resister ur problem will be solved |
1 Attachment(s) this is tested solution............................. |
1202 power supply on but battry dusenote power on change bsi resistence 100% tested |
