Old 06-12-2010, 13:48   #1 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
..::1202 contact service all locks open::..
all locks open
here is info
Version Info:
MCU SW version: V 04.03 29-06-09 RH-112 (c) Nokia
HW version: 1002
UEM version: 1328
UPP version: 8851
RFIC version: 0700
DSP version: ICPR81_09w22_U
LCD version: WIN:SERI:8a NT7542
PPM version: V 04.03 29-06-09 RH-112 (c) Nokia EL
ADSP SW version: p V 04.03\n29-06-09\nRH-112\n(c) NMP\nel
Product Info:
Production serial number: DRR326860
Product code: 0562271
Module code: 0203762
Basic production code: 0558505
Serial Numbers:
IMEI plain: 358251035686390
IMEI spare to net: 3A 85 52 01 53 86 36 09
IMEI SV to net: 33 85 52 01 53 86 36 19 F9
Other Info:
CS type : GSM/DCS1800
BSI: 4.6 KOhm
Imei net: 35825103568639
Version: SIMLOCK SERVER
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 000000000003000B
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
here is selftest
Phone Type: RH-112
ID Test name Startup Result
46 UEM_CBUS_IF Y passed
15 SLEEP_X_LOOP Y passed
3 EAR_DATA_LOOP Y passed
12 SIM_CLK_LOOP Y !failed !
13 SIM_IO_CTRL_LOOP Y !failed !
39 WARRANTY Y passed
33 SIM_LOCK Y passed
10 PPM_VALIDITY Y passed
43 LCD Y passed
41 FLASH_CHECKSUM N passed
30 RF_CHIP_ID N !failed !
52 KASUMI N passed
Old 06-12-2010, 13:54   #2 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
set is water damaged
heatup - may be ur luck works
Old 06-12-2010, 13:57   #3 (permalink)
GSM DON1's Avatar
Member: 1321028
Thanks Meter: 109
sir change lcd ............................
Old 06-12-2010, 14:08   #4 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
already changed lcd
Old 06-12-2010, 14:13   #5 (permalink)
MINH@J's Avatar
Member: 1115404
Sonork: 100.1618186
Thanks Meter: 134
Originally Posted by HUM View Post
already changed lcd
Give Hit On The Flasher
Old 06-12-2010, 14:16   #6 (permalink)
imran zafar's Avatar
Member: 328187
Thanks Meter: 1,687
what is condition of set ???? water damage ????
Old 06-23-2010, 05:46   #7 (permalink)
Member: 1005393
Thanks Meter: 4
same problem here is the logs
i tried it on mxkey
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010)
Rpl backup already exist (C:\mobileEx\3.4\data\backup\35826503507680_BACK.r pl).
Processing file: rh112_003.000 as MCU
[DCT4,DCT4 ALGORITHM] size: 2.29 MB
Supported Ids: 2293
ASIC ID: 0x2293 [UPPCosto ver: 2.0]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514
Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30
Performing Flash Authentication ...OK
UEM ID: 004614A2:2984DA60
Area [01000000-0100FFFF] erased in 1.343 s
Area [01010000-013AFFFF] erased in 1 min 13.046 s
Area [013B0000-013EFFFF] erased in 5.297 s
Area [017C0000-017EFFFF] erased in 0.485 s
Area [01FC0000-01FEFFFF] erased in 0.391 s
Flash programming ...
Programming completed in 27.109 s
File Processed in 1 min 59.250 s
Processing file: rh1120_nai03.00qa_demo as CNT
[DCT4,DCT4 ALGORITHM] size: 102.37 KB
Supported Ids: 2293
Area [01380000-013AFFFF] erased in 3.891 s
Programming completed in 1.422 s
Extracting Content Pack, File Server fake reply for CUI phone.
Content Pack extracted successfully in 0.219 s
File Processed in 23.422 s
Processing file: rh112_003.00ac as PPM
[DCT4,DCT4 ALGORITHM] size: 992.47 KB
Supported Ids: 2293
Area [01240000-0124FFFF] erased in 1.281 s
Area [01250000-0137FFFF] erased in 23.578 s
Programming completed in 10.594 s
File Processed in 46.453 s
Flashing completed in 3 min 18.625 s
After Flash Processing ...
Phone Type: RH-112
SW Version: V 03.00 14-11-08 RH-112 (c) NMP
Imei plain: 35826503507680-8
Product Code: 0562271
Cellular System: GSM
ASIC ID: 0x2293, type: 11
Ppm Id: AC
Language Pack:
- not available.
Imei net: 35826503507680
Counter: 0/3, 0/10
PROFILE_BITS: 0000000000030002
Total time to process is 3 min 32.812 s
Old 06-23-2010, 06:53   #8 (permalink)
shakeel145's Avatar
Member: 510445
Sonork: 100.1638301
Thanks Meter: 353
rehot uem check and post result
Old 06-23-2010, 06:56   #9 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,469
remove sim ic then check after remove sim ic phone show this same problem cs ?check power ic,power ic controlled by CTRL,DATA,CLOCK Bus
post result
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post:
Old 06-23-2010, 07:07   #10 (permalink)
~:Sujyot GSM Zone:~'s Avatar
Member: 48238
Sonork: 100.54361
Thanks Meter: 397
It is the problem due to SIM IC.
Just change it and get ur set ok.
WBR
Jyoti
Old 06-23-2010, 07:14   #11 (permalink)
Member: 1092450
Thanks Meter: 196
RapidShare: 1-CLICK Web hosting - Easy Filehosting
some time this problem plz chack it
Old 06-23-2010, 07:15   #12 (permalink)
mazmaz1's Avatar
Member: 339455
Sonork: 100.1589401
Thanks Meter: 86
Hello
Check hardware
it may be hardware issue.service the board and check it.
Old 06-23-2010, 07:25   #13 (permalink)
GSMTURBO's Avatar
Member: 479496
Sonork: 1592751
Thanks Meter: 404
bro just remove dubble regter post resultt
Old 06-25-2010, 15:15   #14 (permalink)
Crazy Poster
Member: 550684
Thanks Meter: 4
thannnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnks
Old 06-26-2010, 16:45   #15 (permalink)
Member: 247519
Thanks Meter: 2
My dear just reball upp 100% solution do't distrub inother ic just upp
Help: Forgot my 6110 user lock code!! GByte9 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 02-26-2016 14:52
Service Provider Lock 1-4 ? StompSC Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 06-27-2012 11:00
SP Lock 1&4 dw Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 11 06-26-1999 06:22
Need info for unliocking 2 lock (with pic microprocesors) Tomas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-26-1999 01:00
Page generated in 0.27650 seconds with 9 queries
