1208 backlights always on and also auto keyguard working. Hi to all can someone help me in 1208 key guard and back light problem. (1) 1208 backlights always on and when i do off from setting thats are working but on normal not auto off. (2) auto keyguard not working but on pressing menu+* keypad lock working. i think it is S/W problem but after full erase and flash and written pm with JAF and mx key same condition. and after this i have cleaned with ctc and after this same condition. plz advise me how can i solve this? http://i39.tinypic.com/11wbrr4.gif |
here is the phone info. Version Info: MCU SW version: V 5.91 27-03-09 RH-105 (c) NMP HW version: 1602 UEM version: 1328 UPP version: 8850 RFIC version: 0700 DSP version: ICPR62_08w31_UPP LCD version: TPO:NAXvD6 ST7628 PPM version: V 5.91 27-03-09 RH-105 (c) NMP IA ADSP SW version: p V 5.91\n27-03-09\nRH-105\n(c) NMP\nia Product Info: Production serial number: DBN423924 Product code: 0549986 Module code: 0203484 Basic production code: 0515534 Serial Numbers: IMEI plain: 358095019374352 IMEI spare to net: 3A 85 90 05 91 73 34 05 IMEI SV to net: 33 85 90 05 91 73 34 75 F0 Other Info: CS type : GSM/DCS1800 BSI: 3.3 KOhm Imei net: 35809501937435 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 3.890 s |
just change light ic and keypad ic ur problem will solved brother........... 100% hardware................... |
read my post carefully dear i have mentioned manualy both are working. |
please send picture solution. |
check phone is water lock........... |
I think u should flash ur phone, some times i solved it after flash I think should be ok after flash |
clean usb connector or headset connetor..... it may help your problem... |
dear i think you are trying to say easy cable connector. because usb not supported in these type of phone. i already said that i have cleaned it with ctc. thanks any way for your comments. |
