1208 big problem friend help me but urgent i have 1208 i flash with HWK & JAF which flashing local mode error show and when i turn on mobile then mobileshow me contact service reply hurry please |
use the latest version of 1208 rh105_05.800. write good pm and then unlock. thats all |
this is 1005 hardware problem cpu is dry reheat the cpu |
brother i,ll try to flash latest to latest and old to old version but problem not solve tell me more solution please |
brother i change local mode resistance but now show me booting error error log 1st Boot Err: Bad Resp UPP, FF FF FF 72 1st Boot Ok, 1 1st Boot Err: 00 00 Rebooting Mobile |
change uem make ask and download rpl file then write it it will be ok only the solution is change rpl |
mobilecitycbk change uem make ask and download rpl file then write it it will be ok only the solution is change rpl yes brother you are right its uem problem but why he don,t show local mode i change local mode resistance and now showing me booting error please help bro |
BRO TRY To REHOT CPU... .......................::::::::::::::::::::::SURAJ ::::::::::::::::::::::.......................... |
reheat flash ic then try..................... |
re work cpu and flash ic br |
bro first check power supply short if you find any shortage you must rehot UEM if not done reflow cpu still prob rework uem cpu one by one best of luck tips if droped its related CPU if water damage its related UEM www.spdevice.com |
i see ALL COMETMENT OK I M AGREE ALL MEMBER BUT I TELL U ALL MEMBER WHAT IS PROBLEM THIS IS NOT HARDWR PROBLEM THIS IS SOFTWER PROBLEM I TRY ASLO MANEY TIME JAF OR HWK BUT AFTER HARDWORKING TELL ME SINIOR MEMBER THIS IS INTEL FLASH CHIP BASED PHONE[1209] THIS IS SUPPORT ONLY UNIVERSAL YA MTBOX SO I SUGESST TO U PLZ CHEK IN UB YA MT AND POST HERE |
Dooon't rehot yet local mode not always is a hard problem in that model, only reason for local mode without previosly manipulate for software is water, is not your case bro, try this selec in flash settings factory set manual flash warranty and unlock add mcu ppm and cnt files if you don`t selec any file for cnt phone won't has tones.. then flash icon in operations once again it flashed soft ask for mcu,choose same version that you selected on lfash settings and ok post results |
friends my problem solve i flash with easy cable use box HWK ver 5.53 |
