02-24-2010, 22:25 | #1 (permalink) |
Registered User Join Date: Aug 2009
Member: 1087294 Status: Offline Thanks Meter: 252 | 1208 blue display no incoming outgoing only hang |
The Following 2 Users Say Thank You to bruightmobile For This Useful Post: |
02-26-2010, 22:38 | #7 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: pakistan Age: 71
Member: 241039 Status: Offline Thanks Meter: 4,170 | Quote:
which is true reply , check it out ,( i have changed lcd and strip and do jumpers from this forum but not solve) both are your post , 1208 never hanged due to flax Problem . Rashid Ahmed Nadeem | |
02-26-2010, 23:06 | #8 (permalink) | |
Freak Poster Join Date: Mar 2008 Location: india
Member: 731839 Status: Offline Thanks Meter: 45 | Quote:
02-26-2010, 23:12 | #9 (permalink) | |
Member: 1087294 Status: Offline Thanks Meter: 252 | Quote:
but it is true my problem solved by change strip when i post i have two strips and two lcds i change both but same. than when i bought a third strip and change set is ok so i send here my problem solved if i have done any mistake sorry again | |
02-27-2010, 02:49 | #10 (permalink) | |
I think its misunderstanding . its clear now after change third flex , You did not mention in your reply, its OK now , Thanks Rashid Ahmed Nadeem | |
nokia 1200 blank display & 1208 blue display solution | mobilecitycbk | Nokia Hardware & Hardware Repair | 4 | 11-27-2017 23:01 |
6030 blue lcd no incoming no outgoing | sachin_udai | Nokia Hardware & Hardware Repair | 6 | 10-21-2007 08:00 |
V6060 No incoming Outgoing Calls | aberiya | Motorola CDMA | 0 | 11-21-2004 10:28 |
Sagem 9xx no incoming, outgoing calls | Chuk | Sagem Hardware Repair Area | 9 | 02-03-2002 06:08 |
Sagem 9xx no incoming, outgoing calls | Chuk | Hardware Equipments for GSM | 0 | 01-27-2002 18:30 |
