08-10-2009, 00:38 | #1 (permalink) |
No Life Poster Join Date: Jun 2008 Location: Punjabi University India
Member: 788946 Status: Online Sonork: 100.1682685 Thanks Meter: 502 | 1208 Contents Package Extracting Failed thank 1st Boot: Ok, DCT4, UPP: 2292 [Rh-105] [2.0.8.5] 2nd Boot: u3_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x013FFFFF,00898872,Int 28F320W18 Algorithm: u3_intel.fia, Ver: 4.80.0 Algorithm Ok, MSID: 84EEB419481877F14A0BA27384 Decoded MSID: 3E4EBAE9-0045D85C-A8000000 Encoded FAID: 8A49FA2F-149F168A-83163478 IMAGE: rh105_05.710 Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00 Area2: 0x01010000-0x013AFFFF Erased, Time: 00:36 Area3: 0x013B0000-0x013EFFFF Erased, Time: 00:03 Area4: 0x017C0000-0x017EFFFF Out of Chip Bounds Area5: 0x01FC0000-0x01FEFFFF Out of Chip Bounds MCU Flashing Completed, Time: 00:18 IMAGE: rh1050_nai5.71mg Area1: 0x01380000-0x013AFFFF Erased, Time: 00:01 CNT Flashing Completed, Time: 00:01 Extracting Contents Package ... Init Local Mode Failed Contents Package Extracting Failed: Process Failed, Repowering Mobile |
The Following 2 Users Say Thank You to sr8787 For This Useful Post: |
08-10-2009, 01:02 | #2 (permalink) |
Freak Poster Join Date: Jun 2005 Location: EGYPT Age: 53
Member: 157001 Status: Offline Sonork: 100.1585825 Thanks Meter: 45 | Try to erase flash then flash it again if no try to change the cnt file if no rehot flash ic press thanks if problem solved |
The Following User Says Thank You to tayseer For This Useful Post: |
08-10-2009, 04:34 | #5 (permalink) | |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Quote:
1:- use easy cable or 2:-disable vpp pin from fbus cable. try and post result. all wil be ok. | |
08-10-2009, 05:06 | #8 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | Quote:
this is hardware problem loosing in flash ic or in ram rehot the flash ic & ram then only flash with CNT file | |
09-06-2009, 17:27 | #11 (permalink) | |
This is same intel chip ......... http://forum.gsmhosting.com/vbb/show...4&postcount=44 | |
Contents Package Extracting Failed | DonaldDuck69 | Twisterflasher | 32 | 08-06-2010 07:49 |
6230 contents package extracting failed? | torbay | UFS2 + UFS3-Tornadoflasher | 6 | 05-15-2008 09:29 |
Contents Package Extracting Failed for 6020 and 3220 | singapore | Nokia Digital Core Technology 4 ( DCT-4 ) | 16 | 02-16-2007 18:39 |
6101 Contents Package Extracting Failed | VinhHai | Nokia Hardware & Hardware Repair | 12 | 10-17-2005 01:27 |
Contents Package Extracting Failed | DonaldDuck69 | Twisterflasher | 0 | 02-09-2004 16:31 |
