Old 08-18-2008, 18:24   #1 (permalink)
Member: 621702
Thanks Meter: 21
1208 not charging
hello can anyone give me solition when phone not charging ?? f 100 is ok
The Following 3 Users Say Thank You to rockmyroot For This Useful Post:
Old 08-18-2008, 20:19   #2 (permalink)
jmustufa's Avatar
Member: 239231
Sonork: 100.1615723
Thanks Meter: 110
hi check this solution
regards
MAIMOON MOBILES
The Following 3 Users Say Thank You to jmustufa For This Useful Post:
Old 08-18-2008, 23:00   #3 (permalink)
Member: 679863
Thanks Meter: 24
bro use search button there are 100 solution . good luck.
The Following User Says Thank You to baker69 For This Useful Post:
Old 08-22-2008, 16:16   #4 (permalink)
Member: 637952
Thanks Meter: 17
http://rapidshare.com/files/13927504...rging.jpg.html
The Following User Says Thank You to mobicom2 For This Useful Post:
Old 08-23-2008, 10:37   #5 (permalink)
Member: 841926
Thanks Meter: 13
ok 100-100 no proplem now
The Following User Says Thank You to waleeddata For This Useful Post:
Old 08-23-2008, 12:51   #6 (permalink)
Member: 415770
Thanks Meter: 3
The Following User Says Thank You to abd-ghani For This Useful Post:
Old 08-31-2008, 19:41   #7 (permalink)
Member: 621702
Thanks Meter: 21
1200
regards
MAIMOON MOBILES
hello i practice this soulition but no charging plz help it is for charge or mic ?? if it is for mic can u tell me the charge soulition ????????????
Old 09-01-2008, 19:38   #8 (permalink)
jmustufa's Avatar
Member: 239231
Sonork: 100.1615723
Thanks Meter: 110
ok i m giving u a perfect pic the ic should be removed for charging as shown
REGARDS
MAIMOON MOBILES
The Following 2 Users Say Thank You to jmustufa For This Useful Post:
Old 09-01-2008, 19:54   #9 (permalink)
Member: 292506
hi if 1100 ringer not working what the solution anybody help me
Old 09-03-2008, 20:33   #10 (permalink)
jmustufa's Avatar
Member: 239231
Sonork: 100.1615723
Thanks Meter: 110
check this out n nest time use search button if solution not found then only post ur trouble
REGARDS
MAIMOON MOBILES
Old 06-03-2009, 12:49   #11 (permalink)
Member: 1043511
Thanks Meter: 28
1200 mic good solution brother
keep it up
Old 07-23-2009, 16:06   #12 (permalink)
merdjiosse's Avatar
Member: 479679
Thanks Meter: 53
pleaz use search buton
Old 07-23-2009, 16:37   #13 (permalink)
sun deang 168's Avatar
Member: 949912
Thanks Meter: 109
try this brother it ok 100%
Old 07-25-2009, 15:01   #14 (permalink)
chamak-liton's Avatar
Member: 735673
Thanks Meter: 3,101
try this pic.....
Old 07-25-2009, 15:06   #15 (permalink)
Member: 296067
Thanks Meter: 50
thk the solution...good
1208 not charging shaheb_anl Nokia Hardware & Hardware Repair 26 10-24-2012 13:13
1208 not charging solution here nilkamal Nokia Hardware & Hardware Repair 5 09-07-2010 19:29
1600 contact service 1200-1208 not charging another solution bro, teste GSMONNITIN Nokia Hardware & Hardware Repair 4 11-05-2008 10:29
1208 not charging problem pankajC Nokia Hardware & Hardware Repair 2 09-07-2008 10:01
1208 not charging solution here Mobile Tracker Nokia Hardware & Hardware Repair 0 07-29-2008 10:12
Page generated in 0.26554 seconds with 10 queries
