1208 light dim help please hi all master help me please...I have problem with nokia 1208,the light dim please help me ..........:confused: |
1 Attachment(s) Quote:
try to check one by one ... from the led, coil, driver, and the feet 3 try at the solder re all ........... hopefully help |
short the l.e.d .it should be work if dont then change light i.c |
plz check the keypad LED's are in series with the display LED's so short the keypad LED's one by one and eliminate the bad LED later i tried it |
After shorting the LED and changing the LCD IC, if still your problem is not solved then change the COIL. I think your problem will be solved. |
coil problem,tested by me many time,,good luck |
