10-17-2007, 17:37 | #1 (permalink) |
Insane Poster Join Date: May 2007
Member: 508595 Status: Offline Thanks Meter: 14 | Nokia 1600 Blink FIRST IT WAS BLINKING SWITCH ON NOKIA LOGO COMES & DISAPPEAR REPEATED UNTIL THE BATTERY DISCONNECT. NO SWITCH IS WORKING THAT TIME THEN I TRIED TO FLASH THE PHONE AFTER FLASHING THE PHONE IS DEAD NOKIA 1600 DEAD AFTER FLASHING TRYING TO FLASH THE SHOWS THIS ERROR 1st Boot Ok, DCT4, UPP: 2201 Fl0: 0x01000000-0x013FFFFF,00EC2268,Sam K8S3215ETE Algorithm: u_amd.fia, Ver: 4.52.0 Algorithm Ok, MSID: 84DFCB610C749E4523B3F2C8B6 Decoded MSID: 3E4EBAE9-0044FFF5-AA000000 Encoded FAID: FE6C4F64-B18B8A6D-FDE21426 Area1: 0x011D0000-0x011DFFFF Erased, Time: 00:00 Area2: 0x011E0000-0x0137FFFF Erased, Time: 00:11 MCU Flashing Completed, Time: 00:09 Area1: 0x01380000-0x013BFFFF Erased, Time: 00:01 CNT Flashing Completed, Time: 00:01 Extracting Contents Package ... Init Local Mode Failed Contents Package Extracting Failed: Process Failed, Repowering Mobile PLS. HELP WHAT TO DO> REGARDS TARIK Last edited by tarikalikhan; 10-17-2007 at 17:43. |
10-17-2007, 17:44 | #2 (permalink) | |
No Life Poster Join Date: Jul 2004 Age: 46
Member: 73797 Status: Offline Thanks Meter: 19 | Quote:
if not solved, open phone and clean it thorougly and then flash | |
10-17-2007, 19:34 | #3 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 303845 Status: Offline Thanks Meter: 19 | hello friend i have solved this problem by using JAF Box i had flashedm the 1600 the problem has been solved plz use charger while flashing the phone |
The Following User Says Thank You to therocky8 For This Useful Post: |
10-20-2007, 10:09 | #5 (permalink) |
Member: 508595 Status: Offline Thanks Meter: 14 | Thanx for support but the problem not solved. after rehot & cleaning it shows two types of error one is uploaded to you and the next is 1st Boot Ok, DCT4, UPP: 2201 Fl0: 0x01000000-0x013FFFFF,00EC2268,Sam K8S3215ETE Algorithm: u_amd.fia, Ver: 4.52.0 Algorithm Ok, MSID: 843FE88AE54AA7A33DF20EC0C5 Decoded MSID: 3E4EBAE9-0044FFF5-A9000000 Encoded FAID: DA8F0AA0-475F1DA7-881A8039 Area1: 0x011D0000-0x011DFFFF Erased, Time: 00:00 Area2: 0x011E0000-0x0137FFFF Erased, Time: 00:10 Write Error: hDat 14, at: 0x0132C000:08 Process Failed, Repowering Mobile what was the problem, its happend only in nokia 1600, I have got three times these problem, and i an unable to repair it. I have downloaded the latest version of RH-64 but same problem persist. Its happend only in 1600 I dont know why? I have checked everything is ok. |
10-20-2007, 15:19 | #7 (permalink) | |
No Life Poster Join Date: Sep 2006
Member: 343326 Status: Offline Thanks Meter: 1,463 | Quote:
Brother try this . . . . . . . . . . . 1) Use fia file for full earase 2) After full earase flash the phone with lower version 3) If phone not show local mode on screen use higher version 4) If problem remain same try to on phone manually when Content Package Process is going. 5) After complete flash clear the UI setting. U R problem is solved by this method. Post result. | |
10-20-2007, 17:23 | #8 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | first try to clean pcb in u/s cleaner then flash it with lower version (v3.**) no matter you use jaf or ufs but jaf is the best if same problem remain then reflow uem only be careful it's glued post result |
1600 blinking | ziasim | Nokia Digital Core Technology 4 ( DCT-4 ) | 6 | 06-23-2007 06:56 |
1600 blinking please help me ..... | hamid123 | Nokia Digital Core Technology 4 ( DCT-4 ) | 5 | 05-26-2007 18:52 |
Nokia 1600 Blinking | sarojrkl | Nokia Hardware & Hardware Repair | 17 | 02-19-2007 13:44 |
flach nokia RH 64 nokia 1600 | lira | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 01-07-2006 17:26 |
