1208 prblem help set is on ok but not fectory set plz help Phone Restarted... Backing up PM Field 208 as RPL... Setting local mode... Failed! Aborting! Failed to backup imei... Flashing Done! Operation took 0 minutes 31 seconds... After flash processing... Waiting for phone to boot... Failed! Aborting! and not pm write plz |
try to easy cable bro |
bro i try but result same plz other sloution |
rehot flash chip.................... |
dear.change um ic tray thisssssssss |
there is a bsi resistance near uem(search forum for image) check or replace. if same try to reball uem then check. |
use fbus cabel 4 pins .. .. (..)this 2 pin(LASTPIN) cencel 100% tested |
u have u tried with flashig with any other device or with other file bro if not first try it |
