06-30-2009, 17:27 | #1 (permalink) |
No Life Poster Join Date: Apr 2009 Location: >>>JANNAT<<<
Member: 1012319 Status: Offline Thanks Meter: 617 | 1209 Contect service need help I was flash with hwk ufs micro 1st; I was Erase full flash, then flash with v5.80, write pm,unlock,then complete ui settings But problam still...here Self test result here All function are passed but 1 function show failed its function is last 2 second ST_RF_CHIP_ID_TEST...........Failed plz help me its urjunt thx in advance......... |
The Following 2 Users Say Thank You to sameer525kk For This Useful Post: |
06-30-2009, 17:38 | #2 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Pakistan
Member: 131118 Status: Offline Thanks Meter: 40 | Quote: Br |
The Following 2 Users Say Thank You to ejazkhan9 For This Useful Post: |
06-30-2009, 17:43 | #3 (permalink) |
Member: 1012319 Status: Offline Thanks Meter: 617 | Here is info MCU SW : V 5.80 14-11-08 RH-105 (c) NMP PPM SW : V 5.80 14-11-08 RH-105 (c) NMP MH Prd.Code: 0549920 Bpr.Code: 0515534 Prod.Sn : IDH985939 HW Vers : 2601 UEM : 1328 UPP : 8850 [2292] RFIC Ver: 0700 DSP Vers: ICPR62_08w31_UPP LCD Type: SDI:NAXv89 S6B33BD IMEI : 353202-03-303755-2 SL Conf : 001-01-00000000000 SL Prof : 800000000001000-B SL Var : 00003532020330375500 SL Aux : 000B0000 HW Sig : DE051375BFED23B3 Box Id : FFFFFFFFFFFFFFFF BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN Provider: GSM Test Equipment Plz help me/.......... |
06-30-2009, 20:04 | #5 (permalink) |
No Life Poster Join Date: Apr 2008 Location: karachi .. Age: 38
Member: 749969 Status: Offline Sonork: 100.1581886 Thanks Meter: 771 | just unlock with jaf and your problem will be solved |
The Following 2 Users Say Thank You to MYUNLOCKING For This Useful Post: |
06-30-2009, 20:10 | #6 (permalink) |
No Life Poster Join Date: Nov 2008 Location: UAE
Member: 890592 Status: Offline Sonork: 100.1581951 Thanks Meter: 4,429 | After Unlock Ur Problem Will Be Solve. If Not Solve Then Check Hardware Please Post Result |
The Following 2 Users Say Thank You to delower10 For This Useful Post: |
06-30-2009, 20:46 | #7 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Mirpur-1, Dhaka,Bangladesh
Member: 222009 Status: Offline Sonork: 100.1576751 Thanks Meter: 435 | just try once more with good easy cable tested many time on 1208/9 cs (with fbus cable it become cs) problem and solved with hwk erase , flash with any (greater then 4.xx) version wr pm and unlock ... u may check here http://forum.gsmhosting.com/vbb/show...30#post4598230 Last edited by sharmin; 06-30-2009 at 20:51. |
The Following 2 Users Say Thank You to sharmin For This Useful Post: |
07-01-2009, 05:50 | #10 (permalink) |
Freak Poster Join Date: Dec 2007 Location: Bhilwara(Rajasthan)India
Member: 643992 Status: Offline Sonork: 100.1625367 Thanks Meter: 180 | Brother if sim ic will demage with water. then some cases mobile will goes in "Contect Service" so change the sim ic may be solve your problume .i will do this job many time. |
The Following User Says Thank You to jkniji For This Useful Post: |
07-01-2009, 06:45 | #11 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Attock Pakistan
Member: 1002064 Status: Offline Sonork: 100.1594824 Thanks Meter: 131 | Quote:
cuz simlock area is looking good Br | |
07-01-2009, 07:10 | #12 (permalink) |
Cheater -Don't Deal with him- Join Date: Jun 2009 Location: PAKISTAN/UAE
Member: 1050335 Status: Offline Sonork: 100.1602801 Thanks Meter: 4,174 | ..::Brother to 1:-Erase 2:-Flash 4.11 version with jaf box 3:-Write good pm 4:-Unlock ..::So your problem solved this is tried me::.. |
The Following User Says Thank You to RIZWANJAT For This Useful Post: |
07-01-2009, 08:55 | #15 (permalink) |
No Life Poster Join Date: Jan 2009
Member: 946381 Status: Offline Thanks Meter: 150 | I was flashed 1209 mobile phone , but the complaint show the display is contact service , i cleaned charging jack, wr pm file & unlock option but phone not ok . pls help me |
1209 contact service plz help me | shamu | Nokia Hardware & Hardware Repair | 7 | 12-03-2009 18:15 |
1112 1209 contact service please help me | prakash40 | Nokia Hardware & Hardware Repair | 2 | 10-05-2009 16:22 |
1209 Contect service help | sameer525kk | HWK | 2 | 07-01-2009 06:03 |
1209 contect service | ranagaurav | Nokia Digital Core Technology 4 ( DCT-4 ) | 14 | 06-04-2009 05:01 |
6610i contect service need slotion | hira152 | Nokia Hardware & Hardware Repair | 6 | 05-07-2007 13:45 |
