05-17-2009, 13:26 | #1 (permalink) |
Registered User Join Date: May 2009
Member: 1026865 Status: Offline Thanks Meter: 37 | 1209 failed aborting i flash with latest version but same..................... JAF version 1.98.63 Detected PKEY: 90010CB7 Card life counter: 95.90% P-key nokia module version 01.02 Detected UFS_USB V2.8 (c) SarasSoft 2007. version: 01.B1, Driver version: 0, Library version: 0 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ USB Cable Driver version: 7.0.2.0 FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-105\ Searching for default location of ini... Checking path: \Products\RH-105\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-105\ Scanning ini files... Checking path: \Products\RH-105\ Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-105\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.510 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.51ip CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh1050_nai5.51ip ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Changing flashing settings... Checking path: \Products\RH-105\ Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-105\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.510 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.51ia CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh1050_nai5.51ia ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Arabic,Farsi,French,Urdu Backing up PM Field 208 as RPL... Setting local mode... Failed! Aborting! Failed to backup imei... MCU: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.510 Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 88740089 <=> INTEL -> 28F640W18TE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x74888900 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_intel.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x5548; Loader chk: df Loader is ready... P-key nokia module version 01.02 MSID: 84AEFDF0AAC72FE040EC45FACB MSID decoded: 3E4EBAE9009DE04FAA000000 FAID: 05B47BEF7746C0F3F3E94D67 Operation took 0 minutes 16 seconds... Erasing... Found 5 interval(s) to erase Erasing area: 01000000 - 0100FFFF... Erasing area: 01010000 - 013AFFFF... Erasing area: 013B0000 - 013EFFFF... Erasing area: 017C0000 - 017EFFFF... Erasing area: 01FC0000 - 01FEFFFF... Operation took 0 minutes 44 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 22 seconds... Restarting MCU... PPM: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.51ia Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 88740089 <=> INTEL -> 28F640W18TE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x74888900 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_intel.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x5548; Loader chk: df Loader is ready... P-key nokia module version 01.02 MSID: 8458DB11D3AF5900CF67914032 MSID decoded: 3E4EBAE9009DE04FA9000000 FAID: A7B48A53CA75C7F6E31E398E Operation took 0 minutes 17 seconds... Erasing PPM... Found 2 interval(s) to erase Erasing area: 01240000 - 0124FFFF... Erasing area: 01250000 - 0137FFFF... Operation took 0 minutes 13 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 12 seconds... Restarting MCU... CNT: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh1050_nai5.51ia Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 88740089 <=> INTEL -> 28F640W18TE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x74888900 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_intel.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x5548; Loader chk: df Loader is ready... P-key nokia module version 01.02 MSID: 8458DB11D3AF5900CF67914032 MSID decoded: 3E4EBAE9009DE04FA9000000 FAID: A7B48A53CA75C7F6E31E398E Operation took 0 minutes 16 seconds... Erasing Content Pack... Found 1 interval(s) to erase Erasing area: 01380000 - 013AFFFF... Operation took 0 minutes 2 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 2 seconds... Restarting MCU... Operation took 0 minutes 0 seconds... Flashing Done! Operation took 3 minutes 1 seconds... After flash processing... Waiting for phone to boot... Failed! Aborting! |
05-19-2009, 08:01 | #7 (permalink) |
Freak Poster Join Date: Aug 2006
Member: 339455 Status: Offline Sonork: 100.1589401 Thanks Meter: 86 | Hello it seems that ,you flash it with lower firmware version . full erase and write preferd version,write pm,unlock,factory setting,and hope that your phone will be alive if they not have any result check hardware first for water damages. post result |
05-20-2009, 07:11 | #10 (permalink) | |
No Life Poster Join Date: Jan 2008 Location: Kabul Afghanistan
Member: 687312 Status: Offline Thanks Meter: 290 | Quote:
Mate just try with easy cable with battrey and if you have UFS+HWK try with it use battrey and easy cable 1: full erase 2: flash with 3 files 3: write a good pm 4: unlock and fullfactory setting WBR Nawab Sahoo | |
06-21-2009, 18:18 | #12 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: Kushtia,Bangladesh
Member: 597569 Status: Offline Sonork: 100.1593870 Thanks Meter: 271 | Quote:
1200, 1208 ,1209 faield aborting! Contact servic solution. | Dooha_Bd | Nokia Hardware & Hardware Repair | 15 | 11-26-2010 16:02 |
plz help 1209 Flashing Failed! Aborting!in jaf | shivamobiles | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 03-11-2009 13:56 |
