Old 12-24-2012, 07:56   #1 (permalink)
ASSANDHCDMA's Avatar
Member: 1169871
Thanks Meter: 175
Nokia 2700 And 5130 after 2 Sec. charger not supported Solution
Here is the solution For Charger Not Supported After 2 Sec
100% tested solution
If problem not solve after changing 47k then Follow that
our old stuff
Nokia c2-03 Display light going off after few sec.
Old 12-24-2012, 15:22   #2 (permalink)
ramesh pilli's Avatar
Member: 1342063
Sonork: 200200
Thanks Meter: 49
5130 after 2 Sec. charger not supported Solution not success my phone brother
Old 12-24-2012, 17:29   #3 (permalink)
Member: 1501765
5130 charger not support
last solution write pm but first backup rpl good luck
Old 12-25-2012, 08:06   #4 (permalink)
Member: 1169871
Thanks Meter: 175
Brother first change good 47k
also check bsi line
then try this solution i done many set 100% work
Old 12-25-2012, 08:08   #5 (permalink)
Member: 1169871
Thanks Meter: 175
brother this solution work when problem come after repair contact service or repair simlock or repair superdongle.
Old 05-01-2013, 17:07   #6 (permalink)
Member: 1447392
after check all bsi n btemp line, change 47k btemp still not working...
this solution work work pretty good on my 2690 set..
thanks bro,
Old 01-23-2015, 12:35   #7 (permalink)
Member: 1106078
Sonork: Rugga
Thanks Meter: 12
Nokia 5130, 2700 charger not support after few seconds (4sec) 1000% solution.
No need to write pm or rpl. Its 100% H/W fault.
Jump this 2 point near ground fuse.
Simple File Sharing and Storage.
Page generated in 0.21964 seconds with 9 queries
