05-22-2008, 17:14 | #1 (permalink) |
No Life Poster Join Date: Nov 2007
Member: 629694 Status: Offline Thanks Meter: 50 | 1600 flashed with 7.02. after tht imei ??????????? when i check its shws uem imei. can i restore or i have patch rpl plz help |
The Following User Says Thank You to kulwinder2002 For This Useful Post: |
05-23-2008, 06:57 | #3 (permalink) |
Freak Poster Join Date: May 2008 Location: MX-KEY is the BEST NOKIA TOOL
Member: 775560 Status: Offline Thanks Meter: 58 | dear sometime when flashing with nokia dct4/wd2 phone can couse the imei is ???????? beter you 1 backup the rpl using jaf box or, other box spcialy mx key dongle from i mobile indonesia , it can see the imei uem and imei flash also imei plain so you can can fine where is exacly the problem about imei ????? just cek the difrent from imei in backcasing with uem imei or flash imei , if the problam is imei uem same with backcasing but the imei flash is difrent than u can read ask to rpl than write to phone data1 only , but if the difrent is from uem imei , u can just change the uem ! if u want to use 2nd uem from other phone , u just read ask to rpl and write to phone using mx key ! |
NOKIA 1110/1112/1600 Battery low SolutionNOKIA 1110/1112/1600 Battery low Solution | gsm junction | Nokia Hardware & Hardware Repair | 3 | 05-06-2013 13:02 |
1600 imei ????? someone calculate my 1600 | julmars | Phone Unlocking Codes & Maps | 2 | 04-26-2009 03:58 |
Who knows charger pinout for Qualcomm GSP-1600 Satellite phone? | dimka | Hardware Repair by brands | 0 | 03-31-2002 21:00 |
3200 LOGS 1600 Picture Messages | GM | GSM Mobile Links | 0 | 02-09-2001 14:06 |
3200 LOGOS and 1600 PICTURE Messages | GM | GSM Mobile Links | 0 | 02-06-2001 17:58 |
