Old 08-13-2008, 19:30   #1 (permalink)
vishal123123's Avatar
Member: 463150
Thanks Meter: 91
3110c restart with and without sim
3110 set was restarting after 10 to 12 sec its version was 6.02 now i flashed the phone with version 6.60 and the phone is still restarting now every 2 to 3 second with or with out sim....
is it a hardware problem or any other solution
The Following User Says Thank You to vishal123123 For This Useful Post:
Old 08-13-2008, 19:55   #2 (permalink)
Teepat's Avatar
Member: 599669
Thanks Meter: 115
software problem bro....... try flashing................................
Old 08-13-2008, 20:01   #3 (permalink)
Crazy Poster
Member: 239706
Thanks Meter: 4
problem flashing frere
Old 08-13-2008, 20:20   #4 (permalink)
taieeb's Avatar
Member: 781262
Thanks Meter: 90
sir i have same problem with 1200 i have flash with latest version but same result it hangs and phone restart again and again please tell me the solution its urgent
Old 08-14-2008, 09:02   #5 (permalink)
Member: 463150
Thanks Meter: 91
have any body solved similar type problem please share
Old 08-14-2008, 09:11   #6 (permalink)
Member: 430245
Thanks Meter: 30
i am giving u all brothers one solution i have to resolved many time in bb5 i just using jaf file sys format option then full ui option if sat is not dropted or water demige sat 10000% WILL B WORK it means just need to format cnt file ofter flash just cnt if u like
The Following 2 Users Say Thank You to hira152 For This Useful Post:
Old 08-14-2008, 16:42   #7 (permalink)
jkniji's Avatar
Member: 643992
Sonork: 100.1625367
Thanks Meter: 180
Br. flash with JAF and restarting problum will gone . this is try by me many time. please reply my posting.
Old 08-14-2008, 18:07   #8 (permalink)
Member: 463150
Thanks Meter: 91
i mentioned before i have already flashed the phone with jaf and ufs . i made file system format but before flashing now i will make it again and post result . but can any one share the process of erashing bb5 flash area. {if possible in detail}
Old 08-14-2008, 19:01   #9 (permalink)
Member: 751586
Sonork: 0858412346
Thanks Meter: 52
up firmware new u can ues not problem
Old 08-14-2008, 21:14   #10 (permalink)
Member: 639927
Thanks Meter: 6
STOP with this shi_t.Read RPL and replace flash ic from other crap.the problem must solver.cheers.
Old 08-14-2008, 21:28   #11 (permalink)
yasminato's Avatar
Member: 558412
Thanks Meter: 117
use jaf. format fs with mmc inside phone than format mmc with pc then reformat phone without mmc.it s no need to reflash the phone . if same prolem check hardware
post result
Old 08-14-2008, 21:42   #12 (permalink)
loyunk's Avatar
Member: 593871
Thanks Meter: 806
if you was try software do 100% its good,this trouble70% ram ic damage......good luck freind
Old 08-14-2008, 21:48   #13 (permalink)
loyunk's Avatar
Member: 593871
Thanks Meter: 806
you can try do flashing ufs2 micro if this software trouble,very good to execution flashing 3110c bb5......
Old 08-15-2008, 04:35   #14 (permalink)
Registered User
Member: 171336
Thanks Meter: 61
first remove mmc and check
i have the same problem
when i removed mmc phone is working well i replace mmc driver ic now is ok
Old 08-15-2008, 07:23   #15 (permalink)
.::AZEEM::.'s Avatar
Member: 336212
Sonork: 100.1585000
Thanks Meter: 4,912
Hear is tha Full tested solution
Backup rpl and pm than use this erase file and full erase than
full flash and restore rpl than use sx4 service
Tested and working 100000000%
File Type: rar BB5 Erase_RAPIDO_MCU.rar (192 Bytes, 106 views)
File Type: rar BB5Erase_RAPIDO_MCU.rar (390 Bytes, 74 views)
nokia 3110c dont starts with or without sim G.S.M Don Nokia Hardware & Hardware Repair 7 11-29-2008 17:16
3110c restart with sim rpssana Nokia Base Band 5 ( BB-5 ) 12 08-05-2008 09:16
China N95/6688 restart with or without SIM HELP PLS! gsmfriend Infinity-Box 4 01-18-2008 11:14
Different menu with and without SIM - don't want it gnoshi Siemens-Benq Flash Patching 1 06-01-2003 06:47
sagem 936 with and without sim phone display SIM VERROU UHK Infineon C16X M51 & ARM7 M52 BASED 0 09-16-2002 10:15
Page generated in 0.20000 seconds with 10 queries
